Vortex area measurement
Old   March 22, 2012, 00:22
Exclamation Vortex area measurement
fruitkiwi's Avatar
kiwi
fruitkiwi is on a distinguished road
Good days to everyone.
Recently has a meeting with on board when present a poster, When i point out that the vortex strength is high because the vortex area is large.
One of my boss (No cfd field) ask can you measure the vortex area?like measure a rectangular use height times width.
I personally think this is impossible to me to measure the vortex area in terms of quatitative,but just want to confirm, can we measure vortex area by calculate using 2*pi*r?
fruitkiwi is offline   Reply With Quote
Old   March 22, 2012, 00:50
cdf_user is on a distinguished road
This is not an informed answer.
Your english is not very clear but if you are trying to compare several systems using your vortex areas then you can use non-dimensionalized form of radius of vortex.
The vortex area also fluctuates with time so I am not sure if a simple pi*r*r would work.
cdf_user is offline   Reply With Quote
Old   March 22, 2012, 02:14
fruitkiwi's Avatar
kiwi
Hi, cdf_user.
THank you for your reply.
Because in the poster i only show the last time frame, and compare two different geometry at that time point and both geometry show me the different vortex area.but in my picture, there are a lot of vortex line surrounding a vortex ring.
I only look at size of vortex ring, then conclude the vortex strength is larger when vortex ring area is larger.
the 'strength' of a vortex-tube (also called vortex flux) [2] is the integral of the vorticity across a cross-section of the tube following Helmholtz's theorems.
Is my conclusion "vortex strength is larger when vortex ring area is larger." is still valid?
Old   March 22, 2012, 02:33
First of all vortex strength is NOT a function of area of the vortex but the curl of the velocity field of the vortex. This is a common sense answer from basic calculus 3 course from curl and divergence chapter.
A detailed answer to your question is in the book Vorticity and Vortex dynamics by J.Z. Wu on page 73, chapter 3 vortex kinematics.
I am a competitive undergraduate so I have limited knowledge about the vorticity topic. Hope this helps.
Old   March 22, 2012, 02:36
fruitkiwi's Avatar
kiwi
Thanks cdf_user.
You save my days.
Thank you. It solve my problem.
Old   May 18, 2012, 04:26
Horst
lostinicem is on a distinguished road
hey,
I also have a little problem with it; I have a 2-D problem and I have to measure the vortex in my geometry ( its a 2D diffuser). Can you give me some hints please?
lostinicem is offline   Reply With Quote
Old   May 21, 2012, 03:46
I am not an expert in this field and I havent even taken the course on vortex dynamics. I refer to the book Vorticity and vortex dynamics by J.Z. Wu for all vorticity related question. The answer to your question is definitely in that book. I currently dont have the book on me since I borrowed it from the library.
Old   June 13, 2012, 06:17
Horst
thank you cdf user,
well seems i found a way to do it with tecplot; but it dependends on the mesh quality ...
Problem with reference area alfaben STAR-CCM+ 3 April 21, 2020 09:46
Non overlap area fractions saisanthoshm88 CFX 11 September 17, 2015 18:42
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
turbulent scales of forced vortex and free vortex lcw Main CFD Forum 3 September 1, 2005 13:40
