problem about uniting some volumes
Old   March 25, 2012, 13:46
Default problem about uniting some volumes
light
lighterz is on a distinguished road
Greetings,
Well, I'm new here and also to CFD..
My final project is using CFD...
Imagine that a cylinder (pipe) has a bend 90 degree...
and I'm supposed to put 4 small cylinders into the big cylinder(pipe)...
If we cut the pipe the cross section area would be a circle...
so the position of the 4 small cylinders would be at the top, bottom, left, and right at the arc of the circle.
the problem is the uniting process is successfully done for the 2 cylinder which is at left and right..but it turns disappointing when I'm trying to unite the top an bottom..I hope the readers are understand since the problem might be blurry to you..thank you..
lighterz is offline   Reply With Quote
problem importing mesh into gambit tsm554 FLUENT 7 December 3, 2010 22:15
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 05:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
gambit error uniting two volumes Ralf Schmidt FLUENT 3 January 30, 2006 08:51
problem in CFX solver about isolated volumes Yuan CFX 2 August 16, 2004 22:54
