3D F1 Front Wing Domain Size
Old   April 1, 2012, 07:53
Default 3D F1 Front Wing Domain Size
Andy
andyjo22 is on a distinguished road
I have started working on a 3D analysis of an F1 front wing and was wondering what kind of domain sizing I should be using to take account of the wing tip vortices?
I have come across various indications one saying 3 times the span of the wing, the other saying just one times the span.
Cheers
andyjo22 is offline   Reply With Quote
Old   April 1, 2012, 08:27
siw
Stuart
siw will become famous soon enough
Give them both a try and see what consequences (if any) it has on the results that matter to your study. Treat it like you would with a mesh independence assessment.
Generally in external aerodynamics simulations the doman should be far enough away so that it does not effect the region of interest, because in real life there is no far-field boundary so it is an artificial but required feature for the simulation.
siw is offline   Reply With Quote
Old   April 3, 2012, 21:43
Martin Hegedus
Martin Hegedus is on a distinguished road
A lot depends on your boundary conditions, however,
the dependency of a 2D airfoil load on the farfield placement is negligible at about 150 times the chord. In general, for a 2D airfoil, 100 is probably OK, but I would not go less than 50. For real work at least. 3D shapes are a little more forgiving, so 50 times largest length scale is OK. Unfortunately everything is very nonlinear, so when you do your convergence test you need to pick a case which is about to "fall off the cliff" so to speak. In other words, the solution is on the verge of being kicked into a totally different solution space.
Martin Hegedus is offline   Reply With Quote
Optimum Size of Rotating Domain in MRF vismech STAR-CCM+ 5 April 24, 2020 00:15
Mesh domain size independancy check k.vimalakanthan Main CFD Forum 1 May 23, 2011 10:37
How to increase domain size for validation Zonexo Main CFD Forum 8 November 18, 2008 01:22
Fluid domain for a 3D wing Santiago Orrego. CFX 2 January 24, 2007 10:34
Size of rotating domain Adam CFX 4 November 28, 2006 10:28
