the ampltitude of capillary wave
Old   September 29, 2005, 01:53
Default the ampltitude of capillary wave
william
Hi,all. Does anyone read the paper of Juseok kim, 2005? ------" A continuous surface tension force Formulation for diffuse interface models", JCP, 2005.
From Eq. (32), the amplitude a(t) should be a complex number. Thus, I plot the real value of amplitude from theory.It seems the angular frequency from the figure is not the same as that of theory.
Old   September 29, 2005, 04:00
Default Re: the ampltitude of capillary wave
Junseok Kim
I got these values for the a(t) in the paper, check it out. And about the values of a(t), I sent an email to you already.
EE=[ 0.01 0.00971281 0.00890645 0.00766255 0.00607383 0.00424315 0.00227895 0.000290077 -0.00161954 -0.00335573 -0.00483822 -0.006004 -0.0068095 -0.00723187 -0.00726893 -0.0069383 -0.00627542 -0.00533081 -0.00416675 -0.00285347 -0.0014652 -0.000076173 0.00124317 0.00242954 0.00342965 0.00420242 0.00472042 0.00497058 0.00495409 0.00468564 0.00419194 0.00350976 0.00268355 0.00176277 0.000799125 -0.000156161 -0.00105495 -0.00185444 -0.00251912 -0.00302214 -0.00334625 -0.00348419 -0.00343854 -0.00322105 -0.00285164 -0.00235687 -0.00176834 -0.00112077 -0.000450075 0.000208487 0.000822103 0.00136193 0.00180438 0.002132 0.00233409 0.00240688 0.00235335 0.00218276 0.00190982 0.0015537 0.00113679 0.000683408 0.000218493 -0.000233737 -0.000650953 -0.00101376 -0.00130652 -0.00151797 -0.00164157 -0.00167555 -0.00162282 -0.00149051 -0.00128946 -0.00103341 -0.000738223 -0.000420895 -0.0000986915 0.000211773 0.000495334 0.00073898 0.000932395 0.00106835 0.00114291 0.00115545 0.00110855 0.00100765 0.000860684 0.000677483 0.000469235 0.000247813 0.0000251495 -0.000187376 -0.000379489 -0.000542478 -0.000669565 -0.000756143 -0.000799904 -0.000800831 -0.000761086 -0.000684786 -0.000577692];
Old   September 29, 2005, 06:29
william
Thanks. However,I did not want these data. It is no use.
Old   September 29, 2005, 12:17
Default Re: the ampltitude of capillary wave *NM*
Junseok Kim
Old   September 29, 2005, 12:20
Junseok Kim
try to solve it by using mathematica not matlab.
Wave Rotor simulation popezmark OpenFOAM 8 February 4, 2014 18:00
active wave absorb(about wave tank) zhaochuangang ANSYS 0 September 22, 2010 02:29
Scaling up a wave energy converter - free surface flow mark_l CFX 3 February 17, 2010 16:57
what is the condition to use the wave equation? mmff Main CFD Forum 0 January 26, 2010 04:25
DPM model w/ Wave model - errors in documentation HS FLUENT 0 April 12, 2006 04:37
