Gas flow in micro pores
Old   October 3, 2005, 08:26
Default Gas flow in micro pores
Mark
Hi all,
I have just started an investigation into gas flow in micro pores of diameter 50 microns with a L/D ratio = 250 approx. I'm looking for any sources of information or anybody who has experience in the field. Has anyone here tried such an investigation before.
Can anybody help me out?
Thanx
Mark
Old   October 3, 2005, 09:46
Default Re: Gas flow in micro pores
diaw
Sounds like a problem dominated by diffusion. I would imagine that setting a pressure gradient across the model should get something moving. Be interesting to see how you model the pore interconnectivity.
For an overal look at porous problems, you may want to look at Bejan's work on porous media, then work some of it into porous-modelling models in some of the better-known software packages.
I guess it depends what kinds of information you are hoping to derive from your model as to exactly how you appraoch things.
diaw...
real gas simulation in ejector for supersonic flow rahul_bhad1 FLUENT 1 March 31, 2015 21:12
Need advice on softwares working for dilute gas flow Mason Main CFD Forum 4 July 22, 2010 15:55
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
Plug Flow Franck Main CFD Forum 3 September 4, 2003 05:57
flow in gas turbine Abdul Hafid Main CFD Forum 1 September 14, 1998 09:39
