Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Specifying probe locations in controlDict using dictionary file
Old   December 19, 2008, 11:09
Default In 1.5.x, the following code i
Vincent Tang
vincent is on a distinguished road
In 1.5.x, the following code in controlDict samples and writes to frontProbes/0/p and backProbes/0/p during run time
frontProbes
{<blockquote>type probes;
functionObjectLibs ( "libsampling.so" );
probeLocations ( ( -1 0 1) (-1 0 2) );
fields ( p );
backProbes
type probes;
probeLocations ( ( 1 0 1) (1 0 2) );
fields ( p );
</blockquote>
However, using dictionary files as the following code does will cause both sets of results to be written to probes/0/p resulting in an unusable output file.
frontProbes
{<blockquote> type probes;
dictionary frontProbesDict;
backProbes
type probes;
dictionary backProbesDict;
</blockquote>
The issue is caused by different OutputFilter initialization in Foam:: OutputFilterFunctionObject<outputfilter>::start()
OutputFilterFunctionObject.C
IOOutputFilter.C
IOOutputFilter.H
The modifications attached solves the problem by providing an additional constructor in IOOutputFilter. The new constructor allows OutputFilter to be constructed with specified name. I am new to OpenFOAM development. Could someone review the code changes to make sure it fits the OpenFOAM standards?
Thanks.
Vincent
vincent is offline   Reply With Quote
Old   December 24, 2008, 05:29
Default Thanks for the contribution, I
henry is on a distinguished road
Thanks for the contribution, I will review and apply it to 1.5.x after Christmas.
H
henry is offline   Reply With Quote
Old   December 30, 2008, 16:20
Default The changes you proposed are f
The changes you proposed are fine and the new constructor IOOutputFilter can replace the existing one with only minor change. I have applied these changes to 1.5.x.
Thanks
H
Old   December 31, 2008, 04:25
Default You forgot to check in the bug
Hrvoje Jasak
You forgot to check in the bug fix in probeLocations.C, line 47.
(/home/hjasak/OpenFOAM/OpenFOAM-1.5-dev/applications/utilities/postProcessing/sa mpling/probeLocations)
Hrv
Hrvoje Jasak
ControlDict for snappyHexMesh adn interFoam erik023 OpenFOAM Running, Solving & CFD 3 November 10, 2008 18:27
[mesh manipulation] RotateMesh Dictionary File titio OpenFOAM Meshing & Mesh Conversion 2 March 12, 2008 10:15
FoamXException by change in controlDict vladimir OpenFOAM Pre-Processing 2 March 14, 2007 14:32
Reading controlDict diegon OpenFOAM Running, Solving & CFD 1 February 6, 2007 12:31
Compilation problems and file locations Joel Siemens 3 February 11, 2003 12:42
