Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Inactive debug switches for fvOption SemiImplicitSource
Old   August 27, 2014, 13:22
Default Inactive debug switches for fvOption SemiImplicitSource
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
I seem to be unable to report an issue with the mantis system. However, I post the information here, and will report it later, unless someone has an alternative explanation.
When I run the injection tutorial case from the twoPhaseEulerFoam tutorials and I add the following lines to controlDict no debug information is printed:
DebugSwitches
    scalarSemiImplicitSource    1;
    vectorSemiImplicitSource    1;
In the injection case both options are active, thus, I expect some debug information.
The class SemiImplicitSource contains some debug output like this:
    if (debug)
        Info<< "SemiImplicitSource<" << pTraits<Type>::typeName
            << ">::addSup for source " << name_ << endl;
in the method void Foam::fv::SemiImplicitSource<Type>::addSup()
The file semiImplicitSource.C contains the following "macro call"
makeFvOption(SemiImplicitSource, scalar);
The file makeFvOptions.H defines the called macro:
#define makeFvOption(Option, Type)                                            \
    defineTemplateTypeNameAndDebugWithName                                    \
        Option<Type>,                                                         \
        #Type#Option,                                                         \
        0        \
    option::adddictionaryConstructorToTable<Option<Type> >                    \
        add##Option##Type##dictionary##ConstructorTooptionTable_
The part of the code I suspect is:
#Type#Option
which is the stringification of both Type and Option. When called (with Type=scalar, Option=SemiImpicitSource)
the macro argument is
"scalar""SemiImplicitSource"
Compiling the file semiImplicitSource.C with the g++ option -E we gain the output of the preprocessor.
The macro
expands to
template<> const ::Foam::word SemiImplicitSource<scalar>::typeName("scalar""SemiImplicitSource");
template<> int SemiImplicitSource<scalar>::debug(::Foam::debug::debugSwitch("scalar""SemiImplicitSource", 0));
option::adddictionaryConstructorToTable<SemiImplicitSource<scalar> > addSemiImplicitSourcescalardictionaryConstructorTooptionTable_;
Here we also see the argument "scalar""SemiImplicitSource"
I wonder why there is no compiler error message, however, the debug switch does not work.
I think
#Type#Option
needs to be replaced with
Type##Option
as ## concatenates arguments instead of stringifying them.
GerhardHolzinger is offline   Reply With Quote
Old   August 31, 2014, 18:21
Retired Super Moderator
Bruno Santos
Greetings Gerhard,
Fortunately there is no bug, but in fact it's a missing feature.
The problem is that the flags defined in the case's "system/controlDict" only work in some situations. In this situation, you will need to define it at the level of the global "controlDict" or similar, such as:
$HOME/.OpenFOAM/2.3.x/controlDict
As for cases where it works or not, I found the following comment on this bug report: http://www.openfoam.org/mantisbt/view.php?id=640#c2737
Originally Posted by mattijs
The DebugSwitches entry in the case controlDict is pretty good (for non-templated classes). See e.g.
http://www.openfoam.org/version2.2.0...me-control.php
Therefore, the problem is in fact that this will not work for templated classes, such as "SemiImplicitSource".
As for your suggestion of using "Type##Option" instead of "#Type#Option", that's incorrect. The interpretation of the two is as follows:
  • "Type##Option" means that the resulting macro generated code will be a concatenation of the names defined for each macro:
    without any quotes. This would be interpreted as being code and not text.
  • "#Type#Option" means that the content of the two macro variables are to be converted to text:
    which the compiler will in turn automatically concatenate and convert to:
    "scalarSemiImplicitSource"
Best regards,
Bruno
Old   September 1, 2014, 02:59
Gerhard Holzinger
Originally Posted by wyldckat View Post
Greetings Gerhard,
Best regards,
Bruno
My guess was that the macros that create all this debug run-time magic need to get the data type passed instead of a string.
I will take another close look and compare the workings of the pre-processor magic with non-templated and templated classes.
Anyway, I will post my findings when I had a look.
Old   September 1, 2014, 03:55
Gerhard Holzinger
Some time ago I took a look at the non-templated macro magic of the SchillerNaumann drag model class, see the attached pdf.
There the macro
        /* Layout-provided Styles */ div.standard { margin-bottom: 2ex; }defineTypeNameAndDebug(SchillerNaumann, 0);
is with the type name un-stringyfied, this leads me to the assumption, that in the templated case, the macro should also be provided with the unstringyfied type name.
The macro above is defined as
        /* Layout-provided Styles */ div.standard { margin-bottom: 2ex; }      //- Define the typeName and debug information
  #define defineTypeNameAndDebug(Type, DebugSwitch)                             \
      defineTypeName(Type);                                                     \
      defineDebugSwitch(Type, DebugSwitch)
after some further macro expansion we end up with
       /* Layout-provided Styles */ div.standard { margin-bottom: 2ex; }      defineTypeNameWithName(Type, Type::typeName_())
       /* Layout-provided Styles */ div.standard { margin-bottom: 2ex; }      int Type::debug(::Foam::debug::debugSwitch(Name, DebugSwitch))
       /* Layout-provided Styles */ div.standard { margin-bottom: 2ex; }      registerDebugSwitchWithName(Type, Type, Type::typeName_())
The argument Type is needed to correctly address namespaces and datatypes.
However, I still have to look more closely into the templated stuff.
Old   March 22, 2015, 07:06
Bruno Santos
Hi Gerhard,
The ability to also control the debug flags for template classes has been implemented in the OpenFOAM-dev repository: https://github.com/OpenFOAM/OpenFOAM-dev/
It was implemented in this commit: https://github.com/OpenFOAM/OpenFOAM...09b8cb4b967baa
Best regards,
Bruno
Old   March 23, 2015, 03:07
Gerhard Holzinger
Hi Bruno,
thanks for the hint.
Allow me a related off-topic question.
Is the OpenFOAM-dev repo something new or newly made public? I started noticing links and references to this repo a few month ago.
Cheers Gerhard
Old   March 28, 2015, 16:06
Bruno Santos
Quick answer: OpenFOAM-dev repo was started soon after OpenFOAM's 10th year anniversary:
debugswitch, fvoptions, semi-implicit-source
create the file *.foam phongstar OpenFOAM 12 October 14, 2018 18:06
[OpenFOAM] could not open file .vtk in paraview ali_atrian ParaView 8 August 27, 2014 10:31
Debug Switches Peter Müller OpenFOAM Programming & Development 2 September 30, 2013 02:23
Eclipse - case debug error Bufacchi OpenFOAM 1 February 7, 2012 15:15
