Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Rfiles of wrong type in tutorialcases
Old   October 7, 2007, 15:52
Default This is not a bug, just a mino
Assistant Moderator
Bernhard Gschaider
This is not a bug, just a minor inconvenience: If in simpleFoam/pitzDaily the turbulenceModel is changed to LRR, then runs end with
FOAM FATAL IO ERROR : unexpected class name volTensorField expected volSymmTensorField
while reading object R
Editing R to
- change the type to volSymmTensorField
- have the tensors have 6 elements
fixes this
I think, this is due to the changes to the turbulence-models in 1.4 (Using the symmetry of R). Obviously the tutorial files never got changed
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   March 21, 2008, 12:28
Default Hi Everybody When I was ru
Onur Dundar
onurdundar is on a distinguished road
Hi Everybody
When I was running LRR or Launder gibson turbulence model I saw this error. The solution is changing the volumeTensorField to volumeSymmTensorField in R file in 0 time folder. And also you should change the the tensor to 9 elements to 6 elements one. the R filed tensor is in this
form (0 0 0 0 0 0 0 0 0)
change it to (0 0 0 0 0 0)
But last week I saw a file in the source of OF which contains default values of field files. and I thought that if it is changed, the problems will be disappear. However I did not do it because my case can be run in the command prompt without a problem. Today When I tried FoamX to open the same case it gave an error for R file. I think changing that file in OF source will be a permanent solution.
But I can not find that file now.
Now i have two question
1. Do you think is this solution be permanent solution of the problem.
2. do you have any idea where that files can be.
Thanks
onurdundar is offline   Reply With Quote
Where I am wronG lam OpenFOAM Running, Solving & CFD 3 August 8, 2007 03:56
[blockMesh] Run type type determination grtabor OpenFOAM Meshing & Mesh Conversion 4 February 23, 2007 06:05
error: CDR: invalid argument [1]: wrong type Marc FLUENT 0 July 24, 2006 05:59
what wrong with my udf? tristan FLUENT 0 April 20, 2006 04:27
HELP! function airfoil has wrong type: 29 != 43 Alex FLUENT 2 March 28, 2006 23:55
