Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Compilation fails on Linuxx86
Old   March 28, 2007, 07:33
Default The topmost error is: #######
Alexander Grahn
agrahn is on a distinguished road
meshes/polyMesh/polyPatches/derivedPolyPatches/cyclicPolyPatch/cyclicPolyPatch.d ep:248: warning: overriding commands for target `Make/linuxGcc4DPOpt/cyclicPolyPatcSOURCE=global/global.C ; g++ -m32 -Dlinux -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-30 -DWM_PROJECT_VERSION='"'1.
3'"' -I/home/grahn/OpenFOAM/OpenFOAM-1.3/src/zlib-1.2.1 -I/home/grahn/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -pthread -c $SOURCE -o
Make/linuxGcc4DPOpt/global.o
In file included from global/global.C:61:
/home/grahn/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/error.C:41:22: error: demangle.h: No such file or directory
/home/grahn/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/error.C: In static member function 'static void Foam::error::printStack(Foam:stream&)':
/home/grahn/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/error.C:193: error: 'auto_demangling' was not declared in this scope
/home/grahn/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/error.C:194: error: 'cplus_demangle' was not declared in this scope
make: *** [Make/linuxGcc4DPOpt/global.o] Error 1
Last error is:
SOURCE=foamInfoExec.C ; g++ -m32 -Dlinux -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-30 -I/home/grahn/OpenFOAM/Ope
nFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -pthread -c $SOURCE -o Make/linuxGcc4DPOpt/foamInfoExec.o
/home/grahn/OpenFOAM/OpenFOAM-1.3/wmake/bashScripts/mkObjectDir /home/grahn/OpenFOAM/OpenFOAM-1.3/applications/bin/linuxGcc4DPOpt/foamInfoExec
g++ -m32 -Dlinux -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-30 -I/home/grahn/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/ln
Include -IlnInclude -I. -fPIC -pthread Make/linuxGcc4DPOpt/foamInfoExec.o -L/home/grahn/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt \
-lOpenFOAM -liberty -o /home/grahn/OpenFOAM/OpenFOAM-1.3/applications/bin/linuxGcc4DPOpt/foamInfoExec
/usr/lib/gcc/i686-pc-linux-gnu/4.1.1/../../../../i686-pc-linux-gnu/bin/ld: cannot find -lOpenFOAM
collect2: ld returned 1 exit status
make: *** [/home/grahn/OpenFOAM/OpenFOAM-1.3/applications/bin/linuxGcc4DPOpt/foamInfoExec] Error 1
This is the output of 'gcc -v':
Using built-in specs.
Target: i686-pc-linux-gnu
Configured with: /var/tmp/portage/sys-devel/gcc-4.1.1-r3/work/gcc-4.1.1/configure --prefix=/usr --bindir=/usr/i686-pc-linux-gnu/gcc-bin/4.1.1 --includedir=/usr/lib/gcc/i686-pc-linux-gnu/4.1.1/include --datadir=/usr/share/gcc-data/i686-pc-linux-gnu/4.1.1 --mandir=/usr/share/gcc-data/i686-pc-linux-gnu/4.1.1/man --infodir=/usr/share/gcc-data/i686-pc-linux-gnu/4.1.1/info --with-gxx-include-dir=/usr/lib/gcc/i686-pc-linux-gnu/4.1.1/include/g++-v4 --host=i686-pc-linux-gnu --build=i686-pc-linux-gnu --disable-altivec --enable-nls --without-included-gettext --with-system-zlib --disable-checking --disable-werror --enable-secureplt --disable-libunwind-exceptions --disable-multilib --disable-libmudflap --disable-libssp --enable-languages=c,c++,java,fortran --enable-shared --enable-threads=posix --enable-__cxa_atexit --enable-clocale=gnu
Thread model: posix
gcc version 4.1.1 (Gentoo 4.1.1-r3)
And this is 'uname -a' output:
Linux fwss41 2.6.19-gentoo-r5 #1 SMP Mon Mar 12 11:46:45 CET 2007 i686 Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz GenuineIntel GNU/Linux
agrahn is offline   Reply With Quote
Old   March 28, 2007, 07:38
Default Try again after installing dem
henry is on a distinguished road
Try again after installing demangle.h which is required to compile OpenFOAM.
henry is offline   Reply With Quote
Old   March 28, 2007, 08:08
Default Henry, Is demangle.h the on
Alexander Grahn
Henry,
Is demangle.h the one that comes with libcwd
http://libcwd.sourceforge.net/index.html
Alexander
Old   March 28, 2007, 08:14
Default We use SuSE and demangle.h ins
We use SuSE and demangle.h installs automatically when the code development package is installed. I do not have any experience with Gentoo.
Old   March 28, 2007, 08:42
Default emerge binutils should solve
rafal zietara
rafal is on a distinguished road
emerge binutils
should solve the problem
rafal
rafal is offline   Reply With Quote
Old   March 28, 2007, 08:48
Default Thanks, Rafal, but binutils (2
Alexander Grahn
Thanks, Rafal, but binutils (2.16.1-r3) is already installed.
Alexander
Old   March 28, 2007, 09:13
Default Rafal, would you please try to
Alexander Grahn
Rafal, would you please try to find out to which package demangle.h belongs. This could be done with
equery belongs `locate -r '\<demangle.h\>'`
'equery' is part of the genoolkit package. Of course, package 'slocate' must be installed and the file name data base (updated automatically once a day by updatedb, started via crond) must be present.
Thanks,
Alexander
Old   March 28, 2007, 09:28
Default demangle.h is a part of the sy
rafal zietara
demangle.h is a part of the sys-devel/binutils.
I untar it and in /include there is demangle.h
rafal
Old   March 28, 2007, 09:40
Default I assume (didnt test) that unt
rafal zietara
I assume (didnt test) that untaring binutils and
putting demangle.h to /usr/include will solve the
problem(possibly) changing permissions of the file.
maybe you will need to copy in some other dependencies of demangle. binutils 2.16.1-r3 latest stable-should be the most appropriate.
hope this helps.
rafal
PS I dont remember how i did my OF working on Gentoo
but it was definitely gentoo way of doing things
Old   March 28, 2007, 09:50
Default demangle.h is indeed part of t
Alexander Grahn
demangle.h is indeed part of the binutils source file, but doesn't get installed when installing binutils.
I wish I could simply say
emerge openfoam
but
grahn@fwss41:~ $ emerge --search openfoam
Searching...
[ Results for search key : openfoam ]
[ Applications found : 0 ]
Old   April 26, 2007, 05:59
Default About missing demangle.h : att
  #11
Mattijs Janssens
mattijs is on a distinguished road
About missing demangle.h : attached a version of error.C (OpenFOAM/db/error/error.C) which does not use demangle.h but uses the cxxabi.h (which is present in most/all gcc installations).
error.C
Tested it on one machine and seems to compile and function ok. Please let me know if there are any problems with it.
mattijs is offline   Reply With Quote
Old   May 8, 2007, 08:37
Default Hi Mattijs, I replaced the
  #12
Frank Bos
lr103476 is on a distinguished road
Hi Mattijs,
I replaced the error.C in my OpenFOAM 1.3 installation with your latest version. The following errors occur:
/home/frankl/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/error.C:97: error: definition of implicitly-declared 'Foam::error::~error()'
/home/frankl/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/error.C: In static member function 'static void Foam::error::printStack(Foam:stream&)':
/home/frankl/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/error.C:327: error: 'class Foam::IFstream' has no member named 'getLine'
make: *** Waiting for unfinished jobs....
Any ideas?
Regards, Frank
Frank Bos
lr103476 is offline   Reply With Quote
Old   May 8, 2007, 09:23
Default The error.C file Mattijs poste
  #13
The error.C file Mattijs posted is for OpenFOAM-1.4.
Old   June 20, 2007, 05:03
Default Thanks, Mattijs, for providing
  #14
Alexander Grahn
Thanks, Mattijs, for providing `error.C' which resolves the demangle.h-missing-error.
Next, I had to install the termcap library. Almost no recent software links against it. Hasn't termcap been superseeded by terminfo for ages now?
Now, compilation fails due to a syntax error in file `gambitToFoam.C'. (The recently posted cumulative patch to OpenFOAM-1.4 has been applied.)
Any ideas? Thanks for your help.
Alexander
make[3]: Entering directory `/home/grahn/OpenFOAM/OpenFOAM-1.4/applications/utilities/mesh/conversion/gambit ToFoam'
SOURCE=gambitToFoam.L ; flex++ -f $SOURCE ; mv lex.yy.cc Make/linuxGcc4DPOpt/gambitToFoam.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-
parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IlnInclude -I. -I/home/grahn/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude -fPIC -pthread -c
Make/linuxGcc4DPOpt/gambitToFoam.C -o Make/linuxGcc4DPOpt/gambitToFoam.o
/usr/bin/m4:stdin:15917: Warning: excess arguments to builtin `m4_ifdef' ignored
lex.yy.cc: In member function 'virtual int yyFlexLexer::yylex()':
lex.yy.cc:14036: warning: use of old-style cast
lex.yy.cc:14052: warning: use of old-style cast
lex.yy.cc:14612: warning: use of old-style cast
lex.yy.cc: In member function 'int yyFlexLexer::yy_get_next_buffer()':
lex.yy.cc:14860: warning: use of old-style cast
lex.yy.cc:14883: warning: use of old-style cast
lex.yy.cc:14896: warning: use of old-style cast
lex.yy.cc:14917: warning: use of old-style cast
lex.yy.cc: In member function 'yy_state_type yyFlexLexer::yy_get_previous_state()':
lex.yy.cc:14965: warning: use of old-style cast
lex.yy.cc: In member function 'void yyFlexLexer::yyunput(int, char*)':
lex.yy.cc:15025: warning: use of old-style cast
lex.yy.cc:15026: warning: use of old-style cast
lex.yy.cc:15034: warning: use of old-style cast
lex.yy.cc: In member function 'int yyFlexLexer::yyinput()':
lex.yy.cc:15101: warning: use of old-style cast
lex.yy.cc: In member function 'virtual yy_buffer_state* yyFlexLexer::yy_create_buffer(std::istream*, int)':
lex.yy.cc:15181: warning: use of old-style cast
lex.yy.cc:15190: warning: use of old-style cast
lex.yy.cc: In member function 'virtual void yyFlexLexer::yy_delete_buffer(yy_buffer_state*)':
lex.yy.cc:15212: warning: use of old-style cast
lex.yy.cc:15215: warning: use of old-style cast
lex.yy.cc:15217: warning: use of old-style cast
lex.yy.cc: In member function 'void yyFlexLexer::yyensure_buffer_stack()':
lex.yy.cc:15344: warning: use of old-style cast
lex.yy.cc:15362: warning: use of old-style cast
lex.yy.cc: In member function 'void yyFlexLexer::yy_push_state(int)':
lex.yy.cc:15380: warning: use of old-style cast
lex.yy.cc:15383: warning: use of old-style cast
lex.yy.cc: In function 'void* yyalloc(yy_size_t)':
lex.yy.cc:15463: warning: use of old-style cast
lex.yy.cc: In function 'void* yyrealloc(void*, yy_size_t)':
lex.yy.cc:15475: warning: use of old-style cast
lex.yy.cc: In function 'void yyfree(void*)':
lex.yy.cc:15480: warning: use of old-style cast
gambitToFoam.L: In function 'int main(int, char**)':
gambitToFoam.L:685: error: expected `]' before ';' token
gambitToFoam.L:777: error: expected `}' at end of input
gambitToFoam.L:777: error: expected ',' or ';' at end of input
gambitToFoam.L:775: warning: unused variable 'faceIndex'
make[3]: *** [Make/linuxGcc4DPOpt/gambitToFoam.o] Error 1
make[3]: Leaving directory `/home/grahn/OpenFOAM/OpenFOAM-1.4/applications/utilities/mesh/conversion/gambit ToFoam'
make[2]: *** [gambitToFoam] Error 2
make[2]: Leaving directory `/home/grahn/OpenFOAM/OpenFOAM-1.4/applications/utilities/mesh/conversion'
make[1]: *** [conversion] Error 2
make[1]: Leaving directory `/home/grahn/OpenFOAM/OpenFOAM-1.4/applications/utilities/mesh'
make: *** [mesh] Error 2
This is the output from `gcc -v':
Configured with: /var/tmp/portage/sys-devel/gcc-4.1.2/work/gcc-4.1.2/configure --prefix=/usr --bindir=/usr/i686-pc-linux-gnu/gcc-bin/4.1.2 --includedir=/usr/lib/gcc/i686-pc-linux-gnu/4.1.2/include --datadir=/usr/share/gcc-data/i686-pc-linux-gnu/4.1.2 --mandir=/usr/share/gcc-data/i686-pc-linux-gnu/4.1.2/man --infodir=/usr/share/gcc-data/i686-pc-linux-gnu/4.1.2/info --with-gxx-include-dir=/usr/lib/gcc/i686-pc-linux-gnu/4.1.2/include/g++-v4 --host=i686-pc-linux-gnu --build=i686-pc-linux-gnu --disable-altivec --enable-nls --without-included-gettext --with-system-zlib --disable-checking --disable-werror --enable-secureplt --disable-libunwind-exceptions --disable-multilib --enable-libmudflap --disable-libssp --enable-languages=c,c++,java,fortran --enable-shared --enable-threads=posix --enable-__cxa_atexit --enable-clocale=gnu
Thread model: posix
gcc version 4.1.2 (Gentoo 4.1.2)
Old   June 20, 2007, 09:48
Default Looks like flex generated code
  #15
Assistant Moderator
Bernhard Gschaider
Looks like flex generated code that gcc doesn't understand. What does
flex++ -V
say?
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   June 20, 2007, 10:03
Default It is actually flex that I am
  #16
Alexander Grahn
It is actually flex that I am using.
grahn@localhost:~$ flex -V
flex 2.5.33
This is what I found in the flex info manual:
You can also use `flex' to generate a C++ scanner class, using the
`-+' option (or, equivalently, `%option c++)', which is automatically
specified if the name of the `flex' executable ends in a '+', such as
`flex++'. When using this option, `flex' defaults to generating the
scanner to the file `lex.yy.cc' instead of `lex.yy.c'. The generated
scanner includes the header file `FlexLexer.h', which defines the
interface to two C++ classes.
As Allwmake complained about missing flex++, I simply created a hardlink `flex++' pointing to `flex'.
Old   June 20, 2007, 11:09
Default Your encountering what I encou
  #17
connclark
Your encountering what I encountered. Some versions of flex don't like "]]". You need to edit the corresponding .L file and put a space in between the to square closing brackets making it "] ]". You will probably need to do this to a few .L files to get through the compilation.
I also see your using Gentoo (cool)
See my thread here
http://www.cfd-online.com/OpenFOAM_D...tml?1181852126
Old   June 20, 2007, 11:26
Default Thanks, Conn, very much. Now O
  #18
Alexander Grahn
Thanks, Conn, very much. Now OpenFOAM compiles till the end.
But the next problem occurs when I try to run the examples from the `Getting Started' section of the README:
grahn@localhost:~/OpenFOAM/grahn-1.4/run/tutorials/icoFoam $ blockMesh . cavity
blockMesh: error while loading shared libraries: /usr/lib/libz.so: invalid ELF header
Old   June 21, 2007, 02:23
Default I offer merge this thread & th
  #19
Ruben I. Mukhamadeev
benru is on a distinguished road
I offer merge this thread & thread "Cumulative patch for OF-1.4" due to discussion of the same problems with code recompilation
Regards
benru is offline   Reply With Quote
Old   August 31, 2007, 03:31
Default FYI: I am compiling OF 1.4.
  #20
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
FYI:
I am compiling OF 1.4.1 on x86_64 as I type. I have found that using the error.C posted above results in the following compilation error:
SOURCE=graph/writers/jplotGraph/jplotGraph.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -DWM_PROJECT_VERSION='"'1.4.1'"' -I/home/madhavan/OpenFOAM/OpenFOAM-1.4.1/src/zlib-1.2.1 -IlnInclude -I. -I/home/madhavan/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/jplotGraph.o
global.o: In function `Foam::getSymbolForRaw(Foam:stream&, Foam::string const&, Foam::fileName const&, Foam::word const&)':
global.C.text+0x16b0): multiple definition of `Foam::getSymbolForRaw(Foam:stream&, Foam::string const&, Foam::fileName const&, Foam::word const&)'
printStack.o:printStack.C.text+0x2c0): first defined here
/usr/bin/ld: Warning: size of symbol `Foam::getSymbolForRaw(Foam:stream&, Foam::string const&, Foam::fileName const&, Foam::word const&)' changed from 1344 in printStack.o to 913 in global.o
global.o: In function `Foam::printSourceFileAndLine(Foam:stream&, Foam::HashTable<int,> const&, Foam::fileName const&, Foam::word const&)':
global.C.text+0x2560): multiple definition of `Foam::printSourceFileAndLine(Foam:stream&, Foam::HashTable<int,> const&, Foam::fileName const&, Foam::word const&)'
printStack.o:printStack.C.text+0x800): first defined here
/usr/bin/ld: Warning: size of symbol `Foam::printSourceFileAndLine(Foam:stream&, Foam::HashTable<int,> const&, Foam::fileName const&, Foam::word const&)' changed from 3093 in printStack.o to 3361 in global.o
global.o: In function `Foam::error::printStack(Foam:stream&)':
global.C.text+0x3290): multiple definition of `Foam::error::printStack(Foam:stream&)'
printStack.o:printStack.C.text+0x1420): first defined here
/usr/bin/ld: Warning: size of symbol `Foam::error::printStack(Foam:stream&)' changed from 5959 in printStack.o to 5643 in global.o
If I use the stock error.C the compilation proceeds without any problems.
NB: I built binutils and gcc from scratch, so obviously I am not missing demangle.H
msrinath80 is offline   Reply With Quote
OpenFOAM compilation fails on applicationsutilitiesmesh geoffjay OpenFOAM Installation 12 April 29, 2008 15:26
MergeMeshes fails on OF141 any fix hsieh OpenFOAM Bugs 3 January 29, 2008 19:31
Compilation fails on suse linux 101 su_junwei OpenFOAM Bugs 2 July 20, 2007 04:56
RunFoamX fails jvn OpenFOAM Installation 12 August 11, 2005 11:12
SOR Fails Near Walls Chih-Wei Chiu Main CFD Forum 0 May 9, 2002 01:05
