September 7, 2009, 01:43 |
Force bug in 1.5-dev???
Steve Hansel
I've constructed a 2d 10mx10m wind tunnel with a 1m diameter cylinder right in the middle. I've blown air in the +x direction at several different speeds and used the libforces.so library to get the force on the cylinder.
In every case the largest force ends up in the -Y direction due to pressure. I would expect it to be in the +X direction. The small force in the pressure X component actually points upwind. In paraFoam the pressure appears to be equal on the +Y and -Y side of the cylinder. The only asymmetry is in the X direction. Were there any known bugs in 1.5 that swapped the force components? Steve |
September 7, 2009, 17:31 |
Steve Hansel
Update to this problem. I made my mesh 3x finer at the surface and now the forces are at least going in the right direction. Maybe this was all a mesh problem.
Urgently Need the code of Lift force and VM force | Kai Yan | Main CFD Forum | 0 | July 16, 2008 07:07 |
plotting force magnitude | force | Siemens | 6 | July 11, 2008 04:19 |
DEFINE_CG_MOTION and pressure force | Teo Fumagalli | FLUENT | 0 | April 11, 2008 10:25 |
pressure force and viscous force | CFD | FLUENT | 0 | March 7, 2006 01:03 |
