Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Peoblem with paraview on ubuntu 9.10 machine
Old   December 26, 2009, 15:15
Default Peoblem with paraview on ubuntu 9.10 machine
Nabeel
nabeels is on a distinguished road
Hello Foamers
I have installed openFOAM 1.6 on a ubuntu 9.10 machine with no compilation problems. When the cavity problem was run, I was able to see the progress of the solution till it ended successfully.
Unfortunately, when I came to view the results, nothing appeared in paraview when parafoam was executed. I was able to see the meshed domain (before calling the solver icofoam) but not the results. The version of Qt and paraview used are 4.5.2 and 3.6.1, respectively. I used vtk files to load them into paraview and they failed due the following error:
ERROR: In /home/dm2/henry/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/IO/vtkXMLParser.cxx, line 484
vtkPVXMLParser (0x39c02e0): Error parsing XML in stream at line 1, column 1, byte index 1: not well-formed (invalid token)
Root does not exist. Either state file could not be opened or it does not contain valid xml
vtkPVXMLParser (0x2f5cc40): Error parsing XML in stream at line 1, column 0, byte index 0: not well-formed (invalid token)
Any idea how to solve this problem with paraview?
What would be an alternative solution to see the results?
PS. I'm a beginner Linux and OpenFOAM user!
nabeels is offline   Reply With Quote
[OpenFOAM] Problem with parafoam on ubuntu 9.10 machine nabeels ParaView 0 December 25, 2009 23:12
Thumbs up Successful Installaton Of OpenFOAM-1.6 and Paraview in Ubuntu 9.04 AlanR OpenFOAM Installation 8 December 18, 2009 11:14
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
Successful Installaton Of OpenFOAM-1.6 and Paraview in Ubuntu 9.04 AlanR OpenFOAM Installation 21 September 17, 2009 11:27
[OpenFOAM] Paraview 3.4, ppa.launchpad.net and Ubuntu francois ParaView 1 May 29, 2009 09:07
