February 26, 2010, 08:21 |
Bug in PV3FoamReader
Matteo Carpentieri
Rep Power: 17 |
Hi all
I may have found a bug in the paraFoam ParaView reader. I'm using OpenFoam 1.6.x with the packaged ParaView (3.6) from the ThirdParty directory. When I visualise data from R (the Reynolds stress tensor) I believe ParaView picks up the wrong components. The order of the 6-component array (symmTensorField) is intepreted by PV as Rxx Ryy Rzz Rxy Rxz Ryz, while the correct order in OpenFoam is Rxx Rxy Rxz Ryy Ryz Rzz. For example: I'm trying to visualise the boundary conditions for the inlet patch, so I know the values in advance. And I know that R is something like this: (<positive value> 0 <negative value> <positive value> 0 <positive value>) This, in OpenFoam means: xx xy xz yy yz zz When I try to visualise it with paraFoam, I see the correct values ONLY for xx. When i visualise yy i see all 0 values (like xy in the original data). When i visualise zz i see negative values (like xz in the original data) which is clearly wrong, since Rzz can't be negative. An so on... Cheers, Matteo |
March 11, 2010, 07:22 |
Mark Olesen
Rep Power: 40 |
This should now be fixed in the 1.6.x version.
March 11, 2010, 07:55 |
Matteo Carpentieri
Rep Power: 17 |
Serious bug in LES interface | fs82 | OpenFOAM Bugs | 21 | November 16, 2009 08:15 |
bug in Rcomponents utility | cedric_duprat | OpenFOAM Bugs | 1 | May 7, 2009 02:56 |
Please report this bug | egp | OpenFOAM Installation | 5 | December 8, 2006 12:56 |
Bug reports | Mattijs Janssens (Mattijs) | OpenFOAM | 0 | January 10, 2005 10:05 |
Forum y2k Bug | Jonas Larsson | Main CFD Forum | 1 | January 5, 2000 10:22 |
