Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Problems when compiling OF1.7.0 on CentOS
Old   June 29, 2010, 09:03
Default Problems when compiling OF1.7.0 on CentOS
bhh
Bjorn H. Hjertager
bhh is on a distinguished road
I have problems compiling OF1.7.0 on CentOS. My system is:
CentOS-5.4 32 bit operating system (Red Hat Enterprise Linux 5.4)
c++ version is 4.4.0.
The problems may be viewed in the attached screenshots.
Can anybody help?
rgds
Bjorn
bhh is offline   Reply With Quote
Old   June 29, 2010, 09:26
Default install correct gcc
Eelco van Vliet
eelcovv is on a distinguished road
I had the same problem, and solved it by downloading and installing the correct versions of cmake and gcc. I used cmake 2.6.4 and gcc 4.3.3. Make sure you set the path and LD_LIBRARY_PATH variables to your gcc executable and library path, resp.
If you want to include python; there is a bug when you set the PYTHON_PATH variable in the makeParaview script.
Fix it by editing the tools/makeParaViewFunctions file with pythonInclude and pythonBin to with your path to your python include dir and library dir.
Eelco
eelcovv is offline   Reply With Quote
Old   June 29, 2010, 09:32
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
The first one looks like you don't have Cmake installed. You can just do 'yum install cmake', or download it and install it in your userspace.
The second screenshot doesn't give much information; it looks like it failed very early on, because it cannot find the openfoam library. You could have a problem with cpp and separators, which has just been fixed. If you look in the file OpenFOAM-1.7.0/wmake/rules/linux64Gcc/general. Does CPP have the option traditional-cpp?
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   June 30, 2010, 02:53
bhh
Bjorn H. Hjertager
Hi Laurence aand Eelco,
Thanks for your help. I downloaded cmake and I moved somwhat foreward, but now it complains about the qt version I have 4.3.3 and it needs version 4..5.0 or higher. Any suggestion how to install this?
rgds
Bjorn
Old   June 30, 2010, 04:41
What does it say? Qt-4.3.* should work fine?
You can either download qt-x11-opensource-src-4.5.3 from here:
ftp://ftp.trolltech.no/qt/source/
Or if you can yum:
yum install libqt4-devel
If you install it in your userspace, you'll have to add qt to your path I guess.
problems with compiling self defined class Victor OpenFOAM 6 June 21, 2010 02:54
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
Dissimilarity in compiling new BC in 32bit OpenSuSE 103 versus 64bit CentOS 50 versus 64bit SLED 100 sponiar OpenFOAM Running, Solving & CFD 3 February 26, 2008 06:31
Problems compiling UDFs under SuSE 10.2 George FLUENT 1 February 21, 2007 08:36
Problems on Compiling UDF in FLUENT Strawberi-KeatKeat FLUENT 1 October 4, 2006 01:50
