Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Failing biconic25-55Run35 tutorial
Old   August 2, 2010, 14:21
Default Failing biconic25-55Run35 tutorial
Michael Wild
mwild is on a distinguished road
Is it just me (i.e. my customizations) or did one of the recent commits (I suspect 16e22e94a9df524af03f4f75c097ff3a19abc821) break the tutorials/compressible/rhoCentralFoam/biconic25-55Run35 tutorial case? blockMesh fails with
--> FOAM FATAL ERROR:
wedge wedge1 plane aligns with a coordinate plane.
    The wedge plane should make a small angle (~2.5deg) with the coordinate plane
    and the the pair of wedge planes should be symmetric about the coordinate plane.
    Normal of face 0 is (0 0 -1) , implied coordinate plane direction is (0 0 -1)
    From function wedgePolyPatch::initTransforms()
    in file /Users/mwild/Projects/OpenFOAM/src/OpenFOAM/meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 85.
mwild is offline   Reply With Quote
Old   August 3, 2010, 06:08
Mattijs Janssens
mattijs is on a distinguished road
Did you run the steps from the ../Allrun script? It modifies the polyMesh/points 'by hand' to create a proper wedge case. I see no problems with the resulting mesh.
Mattijs
mattijs is offline   Reply With Quote
Old   August 3, 2010, 07:31
Michael Wild
But blockMesh is run before that. It is blockMesh that is failing.
Old   August 3, 2010, 07:43
Mattijs Janssens
Remove the polyMesh/boundary file and re-run blockMesh.
Old   August 3, 2010, 09:02
Mattijs Janssens
I've updated in 1.7.x the maxWellU bc so it now restart properly. I've changed the 0/U file correspondingly. The refValue and valueFraction entries now have a '(non)uniform' tag like the value entry.
Thanks for reporting,
Mattijs
Old   August 3, 2010, 12:42
Michael Wild
Wrong thread?
Anyways, a bogus boundary file has bitten me in the "where it hurts" so many times, I should have figured it out... Sorry for the noise.
Michael
Old   August 3, 2010, 13:12
Mattijs Janssens
Call it pre-emptive posting ;-) You'd have noticed running biconic under valgrind.
Old   February 14, 2014, 03:58
Lee
SKLee is on a distinguished road
Hi guys,
I read the README file of the tutorial biconic25_55 of the solver rhoCentralFoam :" - The time 0 solution is a fairly well-converged solution to this simulation".
Is it the mesh from grid256.dat is the final mesh (i.e. not coarse mesh) for a converged solution of this case ?
Sung-Ki
SKLee is offline   Reply With Quote
Tutorial for subcooled nucleate boiling Asghari FLUENT 42 December 10, 2018 11:42
Problem on Fluent Tutorial: Horizontal Film Boilig Feng FLUENT 2 April 13, 2013 05:34
SI engine tutorial error non-positive volumes rackem FLUENT 12 November 22, 2010 08:06
STAR-CD Tutorial shekhar aryal STAR-CD 4 March 22, 2010 03:25
Rotor/stator tutorial, and how to... gilberto CFX 5 January 21, 2002 09:41
