Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
error propeller case
Old   February 9, 2012, 07:56
Default error propeller case
stephane sanchi
openfoam_user is on a distinguished road
I encounter a problem when running the propeller tutorial with the pimpleDyMFoam solver. The problem occurs during the mesh generation process with the 'topoSet' command.
When I do the command:
topoSet -dict system/removeRedundantZones.topoSetDict
I get the following error message:
Create time
Create polyMesh for time = 0
Reading topoSetDict
Time = 0
mesh not changed.
--> FOAM FATAL ERROR:
object is not allocated
From function T& Foam::autoPtr<T>:perator()()
in file /shared/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/autoPtrI.H at line 118.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/shared/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/shared/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
in "/shared/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/topoSet"
#3 __libc_start_main in "/lib64/libc.so.6"
at /home/abuild/rpmbuild/BUILD/glibc-2.14.1/csu/../sysdeps/x86_64/elf/start.S:116
Abort
Has someone experienced the same kind of error ?
Some days ago I was able to run the tutorial without any errors !
Best regards,
Stephane.
openfoam_user is offline   Reply With Quote
Old   February 9, 2012, 12:02
Retired Super Moderator
Bruno Santos
Greetings Stephane,
I think the problem is related to the following modification: https://github.com/OpenFOAM/OpenFOAM...e9db7af6d19b40
Please report this on the official bug tracker: http://www.openfoam.com/mantisbt/my_view_page.php
Best regards,
Bruno
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Transient case running with a super computer microfin FLUENT 0 March 31, 2009 11:20
Doubt in unsteady case vijay FLUENT 1 April 24, 2006 11:11
Turbulent Flat Plate Validation Case Jonas Larsson Main CFD Forum 0 April 2, 2004 10:25
