March 5, 2012, 06:12 |
crash:parallel run and writetime?
mauricio
Rep Power: 17 |
Hello every1!
i'm trying to run a case here in parallel. I have AMI cyclic patches. I say this cuz with non cyclic patchs there's no crash! when i run the case in 1 core no crashes occur, but when i run it in parallel, as amazing as it seems, the code crashes exactly at the time when the code is supposed to run data. crash Code:
Time = 100 DILUPBiCG: Solving for Ux, Initial residual = 0.0088670851, Final residual = 8.2588747e-06, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.006774242, Final residual = 4.4254254e-06, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 0.0065591327, Final residual = 3.0181564e-06, No Iterations 2 DILUPBiCG: Solving for h, Initial residual = 0.017110962, Final residual = 1.5308887e-05, No Iterations 2 DICPCG: Solving for p_rgh, Initial residual = 0.029165174, Final residual = 2.8152129e-05, No Iterations 77 time step continuity errors : sum local = 0.00040282475, global = -3.6998014e-05, cumulative = 0.016089871 rho max/min : 0.99440505 0.99214534 DILUPBiCG: Solving for epsilon, Initial residual = 0.00090743349, Final residual = 9.3285783e-06, No Iterations 2 bounding epsilon, min: 1.015437e-16 max: 22767.272 average: 594.21879 DILUPBiCG: Solving for k, Initial residual = 0.0047676626, Final residual = 2.1129995e-06, No Iterations 4 [3] #0 Foam::error::printStack(Foam::Ostream&)[1] #0 Foam::error::printStack(Foam::Ostream&)[0] #0 Foam::error::printStack(Foam::Ostream&)[2] #0 Foam::error::printStack(Foam::Ostream&) in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [1] #1 Foam::sigSegv::sigHandler(int) in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/li in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so in "/" opt/OpenFOAM-2.1.0[3] #1 /platforms/linuxGFoam::sigSegv::sigHandler(int)ccDPOpt/lib/libOpenFOAM.so" [2] #1 Foam::sigSegv::sigHandler(int)bOpenFOAM.so" [0] #1 Foam::sigSegv::sigHandler(int) in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [1] #2 Uninterpreted: [1] #3 Foam::externalWallHeatFluxTemperatureFvPatchScalarField::write(Foam::Ostream&) const in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [3] #2 Uninterpreted: [3] #3 in Foam::externalWallHeatFluxTemperatureFvPatchScalarField::write(Foam::Ostream&) const"/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [2] #2 Uninterpreted: [2] #3 Foam::externalWallHeatFluxTemperatureFvPatchScalarField::write(Foam::Ostream&) const in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [0] #2 Uninterpreted: [0] #3 Foam::externalWallHeatFluxTemperatureFvPatchScalarField::write(Foam::Ostream&) const in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libcompressibleTurbulenceModel.so" [1] #4 in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libcompressibleTurbulenceModel.so" [3] #4 in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libcompressibleTurbulenceModel.so" [2] #4 in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libcompressibleTurbulenceModel.so" [0] #4 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::writeEntry(Foam::word const&, Foam::Ostream&) constFoam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::writeEntry(Foam::word const&, Foam::Ostream&) constFoam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::writeEntry(Foam::word const&, Foam::Ostream&) constFoam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::writeEntry(Foam::word const&, Foam::Ostream&) const in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/bin/buoyantSimpleFoam" [3] #5 in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/bin/buoyantSimpleFoam" [1] #5 in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/bin/buoyantSimpleFoam" [0] #5 in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/bin/buoyantSimpleFoam" [2] #5 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::writeData(Foam::Ostream&) constFoam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::writeData(Foam::Ostream&) constFoam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::writeData(Foam::Ostream&) constFoam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::writeData(Foam::Ostream&) const in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/bin/buoyantSimpleFoam" [3] #6 Foam::regIOobject::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/bin/buoyantSimpleFoam" [2] #6 Foam::regIOobject::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/bin/buoyantSimpleFoam" [1] #6 Foam::regIOobject::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/bin/buoyantSimpleFoam" [0] #6 Foam::regIOobject::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [1] #7 Foam::objectRegistry::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [3] #7 Foam::objectRegistry::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [2] #7 Foam::objectRegistry::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [0] #7 Foam::objectRegistry::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [2] #8 Foam::objectRegistry::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [0] #8 Foam::objectRegistry::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [3] #8 Foam::objectRegistry::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [1] #8 Foam::objectRegistry::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [0] #9 Foam::Time::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [2] #9 Foam::Time::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [3] #9 Foam::Time::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [0] #10 Foam::regIOobject::write() const in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [2] #10 Foam::regIOobject::write() const in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [1] #9 Foam::Time::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [3] #10 Foam::regIOobject::write() const in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [2] #11 in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [0] #11 in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [1] #10 Foam::regIOobject::write() const in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [3] #11 in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" [1] #11 [2] in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/bin/buoyantSimpleFoam" [2] #12 __libc_start_main[0] in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/bin/buoyantSimpleFoam" [0] #12 __libc_start_main[3] in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/bin/buoyantSimpleFoam" [3] #12 __libc_start_main in "/lib/libc.so.6" [2] #13 in "/lib/libc.so.6" [0] #13 [1] in "/opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/bin/buoyantSimpleFoam" [1] #12 __libc_start_main in "/lib/libc.so.6" [3] #13 in "/lib/libc.so.6" [1] #13 [2] at /usr/src/packages/BUILD/glibc-2.11.3/csu/../sysdeps/i386/elf/start.S:122 [BR-SBC-WS-296L:29767] *** Process received signal *** [BR-SBC-WS-296L:29767] Signal: Segmentation fault (11) [BR-SBC-WS-296L:29767] Signal code: (-6) [BR-SBC-WS-296L:29767] Failing at address: 0x7447 [0] at /usr/src/packages/BUILD/glibc-2.11.3/csu/../sysdeps/i386/elf/start.S:122 [BR-SBC-WS-296L:29767] [ 0] [0xffffe40c] [BR-SBC-WS-296L:29767] [ 1] [0xffffe424] [BR-SBC-WS-296L:29767] [ 2] /lib/libc.so.6(gsignal+0x4f) [0xb59df8df] [BR-SBC-WS-296L:29767] [ 3] /opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so(_ZN4Foam7sigSegv10sigHandlerEi+0x61) [0xb60c0d61] [BR-SBC-WS-296L:29767] [ 4] [0xffffe400] [BR-SBC-WS-296L:29767] [ 5] /opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libcompressibleTurbulenceModel.so(_ZNK4Foam49externalWallHeatFluxTemperatureFvPatchScalarField5writeERNS_7OstreamE+0x38) [0xb735c908] [BR-SBC-WS-296L:29767] [ 6] buoyantSimpleFoam(_ZNK4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEE22GeometricBoundaryField10writeEntryERKNS_4wordERNS_7OstreamE+0x133) [0x80b0bd3] [BR-SBC-WS-296L:29767] [ 7] buoyantSimpleFoam(_ZNK4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEE9writeDataERNS_7OstreamE+0x12f) [0x80b448f] [BR-SBC-WS-296L:29767] [ 8] /opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam11regIOobject11writeObjectENS_8IOstream12streamFormatENS1_13versionNumberENS1_15compressionTypeE+0x3ff) [0xb5e5e86f] [BR-SBC-WS-296L:29767] [ 9] /opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam14objectRegistry11writeObjectENS_8IOstream12streamFormatENS1_13versionNumberENS1_15compressionTypeE+0x94) [0xb5e61e34] [BR-SBC-WS-296L:29767] [10] /opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam14objectRegistry11writeObjectENS_8IOstream12streamFormatENS1_13versionNumberENS1_15compressionTypeE+0x94) [0xb5e61e34] [BR-SBC-WS-296L:29767] [11] /opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam4Time11writeObjectENS_8IOstream12streamFormatENS1_13versionNumberENS1_15compressionTypeE+0x391) [0xb5e85ea1] [BR-SBC-WS-296L:29767] [12] /opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam11regIOobject5writeEv+0x6b) [0xb5e5eccb] [BR-SBC-WS-296L:29767] [13] buoyantSimpleFoam() [0x806bb93] [BR-SBC-WS-296L:29767] [14] /lib/libc.so.6(__libc_start_main+0xfe) [0xb59cac2e] [BR-SBC-WS-296L:29767] [15] buoyantSimpleFoam() [0x8065291] [BR-SBC-WS-296L:29767] *** End of error message *** [BR-SBC-WS-296L:29765] *** Process received signal *** [BR-SBC-WS-296L:29765] Signal: Segmentation fault (11) [BR-SBC-WS-296L:29765] Signal code: (-6) [BR-SBC-WS-296L:29765] Failing at address: 0x7445 [BR-SBC-WS-296L:29765] [ 0] [0xffffe40c] [BR-SBC-WS-296L:29765] [ 1] [0xffffe424] [BR-SBC-WS-296L:29765] [ 2] /lib/libc.so.6(gsignal+0x4f) [0xb5a9f8df] [BR-SBC-WS-296L:29765] [ 3] /opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so(_ZN4Foam7sigSegv10sigHandlerEi+0x61) [0xb6180d61] [BR-SBC-WS-296L:29765] [ 4] [0xffffe400] [BR-SBC-WS-296L:29765] [ 5] /opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libcompressibleTurbulenceModel.so(_ZNK4Foam49externalWallHeatFluxTemperatureFvPatchScalarField5writeERNS_7OstreamE+0x38) [0xb741c908] [BR-SBC-WS-296L:29765] [ 6] buoyantSimpleFoam(_ZNK4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEE22GeometricBoundaryField10writeEntryERKNS_4wordERNS_7OstreamE+0x133) [0x80b0bd3] [BR-SBC-WS-296L:29765] [ 7] buoyantSimpleFoam(_ZNK4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEE9writeDataERNS_7OstreamE+0x12f) [0x80b448f] [BR-SBC-WS-296L:29765] [ 8] /opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam11regIOobject11writeObjectENS_8IOstream12streamFormatENS1_13versionNumberENS1_15compressionTypeE+0x3ff) [0xb5f1e86f] [BR-SBC-WS-296L:29765] [ 9] /opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam14objectRegistry11writeObjectENS_8IOstream12streamFormatENS1_13versionNumberENS1_15compressionTypeE+0x94) [0xb5f21e34] [BR-SBC-WS-296L:29765] [10] /opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam14objectRegistry11writeObjectENS_8IOstream12streamFormatENS1_13versionNumberENS1_15compressionTypeE+0x94) [0xb5f21e34] [BR-SBC-WS-296L:29765] [11] /opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam4Time11writeObjectENS_8IOstream12streamFormatENS1_13versionNumberENS1_15compressionTypeE+0x391) [0xb5f45ea1] [BR-SBC-WS-296L:29765] [12] /opt/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam11regIOobject5writeEv+0x6b) [0xb5f1eccb] [BR-SBC-WS-296L:29765] [13] buoyantSimpleFoam() [0x806bb93] [BR-SBC-WS-296L:29765] [14] /lib/libc.so.6(__libc_start_main+0xfe) [0xb5a8ac2e] [BR-SBC-WS-296L:29765] [15] buoyantSimpleFoam() [0x8065291] [BR-SBC-WS-296L:29765] *** End of error message *** -------------------------------------------------------------------------- mpirun noticed that process rank 2 with PID 29767 on node BR-SBC-WS-296L exited on signal 11 (Segmentation fault). -------------------------------------------------------------------------- Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application buoyantSimpleFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 2000; deltaT 1; writeControl adjustableRunTime; writeInterval 100; purgeWrite 0; writeFormat binary; writePrecision 8; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable yes; //maxCo 0.3; // Maximum diffusion number //maxDi 10.0; // ************************************************************************* // any inputs are welcome!! edit: it turns out the problem was with the boundary condition externalWallHeatFluxTemperature. I had changed this BC cuz it was printing out all 3 parameters h, Ta and q, regardless of its input. I had to change it cuz another application, wallHeatFlux wouldn't run if i had all 3 parameters so i change the code from this Code:
{ mixedFvPatchScalarField::write(os); temperatureCoupledBase::write(os); //if (q_ != 0) //{ q_.writeEntry("q", os); // this->writeEntry("value", os); //} //else //{ h_.writeEntry("h", os); Ta_.writeEntry("Ta", os); this->writeEntry("value", os); //} } Code:
{ mixedFvPatchScalarField::write(os); temperatureCoupledBase::write(os); if (q_ != 0) { q_.writeEntry("q", os); this->writeEntry("value", os); } else { h_.writeEntry("h", os); Ta_.writeEntry("Ta", os); this->writeEntry("value", os); } } Code:
if (dict.found("q") && !dict.found("h") && !dict.found("Ta")) { oldMode_ = fixedHeatFlux; q_ = scalarField("q", dict, p.size()); } else if (dict.found("h") && dict.found("Ta") && !dict.found("q")) { oldMode_ = fixedHeatTransferCoeff; h_ = scalarField("h", dict, p.size()); Ta_ = scalarField("Ta", dict, p.size()); } any hints?? thank you so much
Best Regards /calim "Elune will grant us the strength" Last edited by calim_cfd; March 5, 2012 at 06:38. Reason: new info-solution |
March 5, 2012, 17:13 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Calim,
First of all, I suggest that you update your OpenFOAM 2.1.0 to 2.1.x. AMI is a new feature as of 2.1.0 and a few bugs have already been found and fixed on 2.1.x. As for the other error with "dict"... I don't know which "dict" you're referring to. And without an error message, it's even more difficult to figure out what's wrong. Best regards, Bruno
March 5, 2012, 19:13 |
#3 | |
mauricio
Rep Power: 17 |
But anyway i'll have to make other modifications and create a different bc lib from this one, so i'll leave it for the moment. Plus i should have modified the application instead of the BC thanks for the feedback! and i'll definitely update OF.
Best Regards /calim "Elune will grant us the strength" |
