[PyFoam] Problems with installing PyFoam
Like Tree1Likes
Old   May 8, 2013, 16:46
Assistant Moderator
Bernhard Gschaider
Originally Posted by simone.rowing View Post
dear geschaider, after a bit of fiddling with the folders, we have the PyQt4 installed and able to import it in python. the vtk package must also be installed, however it shows the following erro after runnung the code "pyFoamVersion.py"
Installed libraries:
Gnuplot              :  No      Not a problem. Version from ThirdParty is used
ply                  :  No      Not a problem. Version from ThirdParty is used
Numeric              :  No      Not supported anymore. No need to install it
/Applications/Paraview_3.98.1.app/Contents/Python/numpy/random/__init__.py:87: RuntimeWarning: compiletime version 2.6 of module 'mtrand' does not match runtime version 2.7
  from mtrand import *
numpy                :  Yes      version: 1.6.2
matplotlib           :  Yes      version: 1.1.1
psyco                :  No      Not a problem. Acceleration not possible
hotshot              :  Yes
profile              :  Yes
cProfile             :  Yes
PyQt4                :  Yes
PyQt4.Qwt5           :  No      Only an alternate plotting back-end
vtk                  :  Error: Could not import vtkCommonComputationalGeometryPython
No      Not a problem. Only used for some utilities
Tkinter              :  Yes      version: $Revision: 81008 $
mercurial            :  No      Not a problem. Used for experimental case handling
nose                 :  No      Only needed for running the unit-tests (developers only)
twisted              :  Yes      version: 11.0.0
pandas               :  No      Not yet used. Maybe handling of timelines will be reimplemented with it
scipy                :  No      Not yet used. Possibly use signal-fitting etc
not entirely sure what to do next, many thanks for the help so far.
Please always poste the complete output of the utility and let me judge what is needed. As far as I can see you still got the Paraview-binaries in the PYTHONPATH. At the very least this breaks numpy (because you use Python 2.7, Paraview 2.6). Not sure, but this probably also breaks VTK.
So remove all parts pointing to the Paraview-installation from the PYTHONPATH and retry
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   May 8, 2013, 17:13
Simone Martini
simone.rowing is on a distinguished road
Ok, I do in this way:
run Python
import sys
print sys.path
import paraview
import vtk
MacBook-di-Simone:~ simomartini$ python
Python 2.7.1 (r271:86832, Jul 31 2011, 19:30:53)
[GCC 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2335.15.00)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> import sys
>>> print sis
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
NameError: name 'sis' is not defined
>>> quit()
>>> import sys
>>> print sys.path
['', '/Users/simomartini', '/Applications/Paraview_3.98.1.app/Contents/Python', '/Applications/Paraview_3.98.1.app/Contents/Python/paraview', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC', '/Library/Python/2.7/site-packages']
>>> import paraview
>>> import vtk
  File "/Applications/Paraview_3.98.1.app/Contents/Python/paraview/vtk/__init__.py", line 7, in <module>
    from vtkCommonCorePython import *
ImportError: No module named vtkCommonCorePython
and this in my pyFoamVersion.py
MacBook-di-Simone:~ simomartini$ pyFoamVersion.py
Machine info: Darwin | MacBook-di-Simone.local | 11.4.2 | Darwin Kernel Version 11.4.2: Thu Aug 23 16:25:48 PDT 2012; root:xnu-1699.32.7~1/RELEASE_X86_64 | x86_64 | i386
Python version: 2.7.1 (r271:86832, Jul 31 2011, 19:30:53)
PYTHONPATH: :/Applications/Paraview_3.98.1.app/Contents/Python:/Applications/Paraview_3.98.1.app/Contents/Python/paraview
Location of this utility: /usr/local/bin/pyFoamVersion.py
OpenFOAM () of the installed versions ['2.2.0']
  This version of OpenFOAM uses the old calling convention
pyFoam-Version: 0.6.0
Path where PyFoam was found (PyFoam.__path__) is ['/Library/Python/2.7/site-packages/PyFoam']
Configuration search path: [('file', '/etc/pyFoam/pyfoamrc'), ('directory', '/etc/pyFoam/pyfoamrc.d'), ('file', '/Users/simomartini/.pyFoam/pyfoamrc'), ('directory', '/Users/simomartini/.pyFoam/pyfoamrc.d')]
Configuration files (used): []
hotshot              :  Yes
profile              :  Yes
cProfile             :  Yes
PyQt4                :  Yes
simone.rowing is offline   Reply With Quote
Old   May 8, 2013, 17:32
Assistant Moderator
Bernhard Gschaider
As I suspected: Paraview is in the PYTHONPATH. Completely erase the path with 'unset PYTHONPATH' and retry
The VTK-version that comes with Paraview is NO help. For some technical reason (you'll have to research that yourself) the version of VTK that comes with Paraview is modified and in parts behaves differently. Make sure you use the version from MacPorts (I think I described that before)
Old   May 8, 2013, 18:25
Simone Martini
this is my version of ports
MacBook-di-Simone:~ simomartini$ port
MacPorts 2.1.3
Entering interactive mode... ("help" for help, "quit" to quit)
[Users/simomartini] >
the pyFoam doesn't recognize the vtk and the installation with port that you already suggested didn't work with python. Do you know another way to install vtk to work with pyFoam. I tried to use Homebrew but I have not had any success.
PYTHONPATH: :/Users/simomartini/projects/ParaView-bin/lib/site-packages/
numpy                :  Yes      version: 1.5.1
matplotlib           :  No      Only Gnuplot-plotting possible
hotshot              :  Yes
profile              :  Yes
cProfile             :  Yes
PyQt4                :  Yes
vtk                  :  No      Not a problem. Only used for some utilities
twisted              :  Yes      version: 12.3.0
Old   May 8, 2013, 18:44
Assistant Moderator
Bernhard Gschaider
MacPorts 2.1.3
I already explained it to you in a previous post (http://www.cfd-online.com/Forums/ope...l#post423691): install the vtk from MacPorts! I assumed you've already done that and the library was "shadowed" by the paraview-version
Old   May 10, 2013, 05:35
Simone Martini
I already install the vtk5! but I really don't know why this doesn't work.
MacBook-di-Simone:~ simomartini$ sudo port install vtk5 +python27 +qt4_mac
Password:
--->  Computing dependencies for vtk5
--->  Deactivating vtk5 @5.10.1_0+tcltk+x11
--->  Cleaning vtk5
--->  Activating vtk5 @5.10.1_0+python27+qt4_mac
--->  Cleaning vtk5
--->  Scanning binaries for linking errors: 100.0%
--->  No broken files found.
Machine info: Darwin | dhcp-201-211.wireless.soton.ac.uk | 11.4.2 | Darwin Kernel Version 11.4.2: Thu Aug 23 16:25:48 PDT 2012; root:xnu-1699.32.7~1/RELEASE_X86_64 | x86_64 | i386
hotshot              :  Yes
profile              :  Yes
cProfile             :  Yes
PyQt4                :  Yes
Old   May 11, 2013, 06:17
Assistant Moderator
Bernhard Gschaider
Password:
--->  Cleaning vtk5
--->  Cleaning vtk5
hotshot              :  Yes
profile              :  Yes
cProfile             :  Yes
PyQt4                :  Yes
Which python-version are you using? From the version reported I guess the apple-version in /usr/bin/python (but please verify with "which"). I use the MacPorts-version and the variant +python27 of vtk5 assumes that. Either select the MacPorts-version with "port select python python27" or reinstall vtk5 without that option (but I haven't tested that)
Old   May 7, 2014, 05:51
Default error messages running pyFoamPlotRunner
  #28
mmartin is on a distinguished road
hello
i installed pyFoam on a rhel server but if i run pyFoamPlotRunner
with the syntax
pyFoamPlotRunner.py <OFsolver> -case CASE
pyFoamPlotRunner.py <OFsolver> (in the case folder)
i get following error messageTraceback (most recent call last):
File "/usr/bin/pyFoamPlotRunner.py", line 3, in ?
from PyFoam.Applications.PlotRunner import PlotRunner
File "/usr/lib/python2.4/site-packages/PyFoam/Applications/PlotRunner.py", line 6
from .PyFoamApplication import PyFoamApplication
SyntaxError: invalid syntax
i would be happy about any help or recommendations
i m running pyFoam0.6.2
mmartin is offline   Reply With Quote
Old   May 7, 2014, 07:01
Assistant Moderator
Bernhard Gschaider
Originally Posted by mmartin View Post
hello
with the syntax
At first: please add output in the CODE-tag (that's be the # in the toolbar above). It makes it much easier to spot where the ^ is actually pointing to.
What kind of RHEL? My guess is that it is not 6. Because the problem you have is one of the rare backward incompatibilities in Python. Relative imports were introduced with python 2.5 (so your Python seems to be 2.4 or older). Ah. Just saw it: it says 2.4 in the output
Options are:
- make the import absolute (just add PyFoam.Applications in front of the dot). Don't know where else this is required. Or make it "oldSchool"-relative by removing the dot in the front
- there are packages python26 or python27 for RHEL that give you a higher-version PyFoam in parallel to the system on (don't EVER replace the system-python on a RHEL-machine). Using that needs a little bit of trickery (especially if you use setup.py)
The reason why PyFoam uses the new-style relative import is that the old way does not work with Python 3 (PyFoam is compatible with python 2.x and 3.x but in order to get that I had to break compatibility with Pythons older than 2.5)
Old   May 7, 2014, 07:20
oh sorry i didnt knew that
its RHEL 5.10. I already sent your advices to our admin (i m not root)
Old   May 8, 2014, 04:35
Assistant Moderator
Bernhard Gschaider
OK. Recommended is installing a python26/27 binary package and virtualenv. Then create a virtual environment in which you install dependencies. That leaves the system-python clean and allows you to use bleeding-edge versions of the python-packages (if your sysadmin is nice he does this for you). I use a similar setup here (CentOS6 is a LITTLE more advanced than your 5 but for fast-moving libraries like Pandas or Matlab it is hopelessly outdated)
Old   October 19, 2015, 15:23
Default pyFoamDisplayBlockMesh.py raise e AttributeError: SetInput
  #32
Pekka is on a distinguished road
I have a similar problem as is reported earlier and I can not find solution to that. My os is rhel 7.1 and same problem occur with pyFoam version 0.6.1 and 0.6.4. Error message is also similar with both pyFoam version.
error:
[Pekka@Kone4 rotor]$ pyFoamDisplayBlockMesh.py constant/polyMesh/blockMeshDict
Using system-VTK
Status: blockMesh modified - Ready
 PyFoam WARNING on line 338 of file /home/Pekka/foam/foam-extend-3.2/ThirdParty/packages/PyFoam-0.6.4/platforms/noarch/lib/python2.7/site-packages/PyFoam/Applications/DisplayBlockMeshQt.py : While reading constant/polyMesh/blockMeshDict this happened: SetInput
  File "/home/Pekka/foam/foam-extend-3.2/ThirdParty/packages/PyFoam-0.6.4/platforms/noarch/bin/pyFoamDisplayBlockMesh.py", line 18, in <module>
    DisplayBlockMesh()
  File "/home/Pekka/foam/foam-extend-3.2/ThirdParty/packages/PyFoam-0.6.4/platforms/noarch/lib/python2.7/site-packages/PyFoam/Applications/DisplayBlockMeshQt.py", line 1338, in __init__
    nr=1)
  File "/home/Pekka/foam/foam-extend-3.2/ThirdParty/packages/PyFoam-0.6.4/platforms/noarch/lib/python2.7/site-packages/PyFoam/Applications/PyFoamApplicationQt4.py", line 37, in __init__
    exactNr=exactNr)
  File "/home/Pekka/foam/foam-extend-3.2/ThirdParty/packages/PyFoam-0.6.4/platforms/noarch/lib/python2.7/site-packages/PyFoam/Applications/PyFoamApplication.py", line 356, in __init__
    result=self.run()
  File "/home/Pekka/foam/foam-extend-3.2/ThirdParty/packages/PyFoam-0.6.4/platforms/noarch/lib/python2.7/site-packages/PyFoam/Applications/PyFoamApplicationQt4.py", line 59, in run
    self.setupGUI()
  File "/home/Pekka/foam/foam-extend-3.2/ThirdParty/packages/PyFoam-0.6.4/platforms/noarch/lib/python2.7/site-packages/PyFoam/Applications/DisplayBlockMeshQt.py", line 1369, in setupGUI
    valuesFile=self.opts.valuesFile)
  File "/home/Pekka/foam/foam-extend-3.2/ThirdParty/packages/PyFoam-0.6.4/platforms/noarch/lib/python2.7/site-packages/PyFoam/Applications/DisplayBlockMeshQt.py", line 339, in __init__
    raise e
and
[Pekka@Kone4 rotor]$ pyFoamVersion.py
Machine info: Linux | Kone4 | 3.10.0-229.14.1.el7.x86_64 | #1 SMP Tue Sep 15 15:05:51 UTC 2015 | x86_64 | x86_64
Python version: 2.7.5 (default, Jun 24 2015, 00:41:19)
[GCC 4.8.3 20140911 (Red Hat 4.8.3-9)]
Python executable: /usr/bin/python
Python 2.7 is one development platform for PyFoam (along with Python 3)
PYTHONPATH: /home/Pekka/foam/foam-extend-3.2/ThirdParty/packages/PyFoam-0.6.4/platforms/noarch/lib/python2.7/site-packages:
Location of this utility: /home/Pekka/foam/foam-extend-3.2/ThirdParty/packages/PyFoam-0.6.4/platforms/noarch/bin/pyFoamVersion.py
 PyFoam WARNING on line 192 of file /home/Pekka/foam/foam-extend-3.2/ThirdParty/packages/PyFoam-0.6.4/platforms/noarch/lib/python2.7/site-packages/PyFoam/FoamInformation.py : Basedir /home/Pekka/OpenFOAM for fork openfoam does not exist or is not a directory
Version 3.2 Fork extend of the installed 2 versions:
extend-3.1 : /home/Pekka/foam/foam-extend-3.1
extend-3.2 : /home/Pekka/foam/foam-extend-3.2
pyFoam-Version: 0.6.4
ALERT: Reported version (0, 6, 4) is different from hardcoded version (0, 6, 4, 'development') -> probably inconsistent library installation
Path where PyFoam was found (PyFoam.__path__) is ['/home/Pekka/foam/foam-extend-3.2/ThirdParty/packages/PyFoam-0.6.4/platforms/noarch/lib/python2.7/site-packages/PyFoam']
Configuration search path: [('file', '/etc/pyFoam/pyfoamrc'), ('directory', '/etc/pyFoam/pyfoamrc.d'), ('file', '/home/Pekka/foam/foam-extend-3.2/ThirdParty/PyFoamSiteScripts/etc/pyfoamrc'), ('directory', '/home/Pekka/foam/foam-extend-3.2/ThirdParty/PyFoamSiteScripts/etc/pyfoamrc.d'), ('file', '/home/Pekka/.pyFoam/pyfoamrc'), ('directory', '/home/Pekka/.pyFoam/pyfoamrc.d')]
Configuration files (used): ['/home/Pekka/.pyFoam/pyfoamrc']
cython               :  No      Not used. Maybe will by used later to spped up parts of PyFoam
cProfile             :  Yes
docutils             :  No      Not necessary. Needed for RestructuredText to HTML conversion
hotshot              :  Yes
ipdb                 :  No      Not necessary. Only makes debugging more comfortable
IPython              :  No      Not necessary. But the interactive shell may be more comfortable
matplotlib           :  Yes      version: 1.2.0
mercurial            :  Yes      version: 2.6.2
nose                 :  Yes      version: 1.3.0
numpy                :  Yes      version: 1.7.1
openpyxl             :  No      Not a problem. Only used for exporting pandas-data to Excel-files (advanced)
pandas               :  No      Not a problem. Only used for handling of advanced data-handling
profile              :  Yes
PyQt4                :  Yes      version: 4.8.5
twisted              :  No      Not yet used. Possibly reimplement MetaServer with it
vtk                  :  Yes      version: 6.1.0
xlwt                 :  No      Not a problem. Only used for exporting pandas-data to Excel-files
xlrd                 :  No      Not a problem. Only used for importing Excel-files to pandas-data
Library locations
cProfile             : /usr/lib64/python2.7/cProfile.pyc
hotshot              : /usr/lib64/python2.7/hotshot/__init__.pyc
matplotlib           : /usr/lib64/python2.7/site-packages/matplotlib/__init__.pyc
mercurial            : /usr/lib64/python2.7/site-packages/mercurial/__init__.pyc
nose                 : /usr/lib/python2.7/site-packages/nose/__init__.pyc
numpy                : /usr/lib64/python2.7/site-packages/numpy/__init__.pyc
profile              : /usr/lib64/python2.7/profile.pyc
PyQt4                : /usr/lib64/python2.7/site-packages/PyQt4/__init__.pyc
Tkinter              : /usr/lib64/python2.7/lib-tk/Tkinter.pyc
vtk                  : /usr/lib64/python2.7/site-packages/vtk/__init__.pyc
Checking additional envirnoment variables
Checking for PYFOAM_DIR : Location of the PyFoam-installation. Not strictly necessary
PYFOAM_DIR set to /home/Pekka/foam/foam-extend-3.2/ThirdParty/packages/PyFoam-0.6.4/platforms/noarch
Checking for PYFOAM_SITE_DIR : Location of non-PyFoam-disctributions script. Set and used by some Foam-distributions
PYFOAM_SITE_DIR set to /home/Pekka/foam/foam-extend-3.2/ThirdParty/PyFoamSiteScripts
Site-specific scripts should be added to /home/Pekka/foam/foam-extend-3.2/ThirdParty/PyFoamSiteScripts/bin
Site-specific configurations can be added to /home/Pekka/foam/foam-extend-3.2/ThirdParty/PyFoamSiteScripts/etc
Site-specific library files can be added to /home/Pekka/foam/foam-extend-3.2/ThirdParty/PyFoamSiteScripts/lib Do NOT add to PYTHONPATH but import as PyFoam.Site
and
older pyFoam version
[Pekka@Kone4 angledDuctExplicit]$ pyFoamVersion.py
PYTHONPATH: /home/Pekka/foam/foam-extend-3.1/ThirdParty/packages/PyFoam-0.6.1/platforms/noarch/lib/python2.7/site-packages:
Location of this utility: /home/Pekka/foam/foam-extend-3.1/ThirdParty/packages/PyFoam-0.6.1/platforms/noarch/bin/pyFoamVersion.py
OpenFOAM (3, 1) of the installed versions []
pyFoam-Version: 0.6.1
Path where PyFoam was found (PyFoam.__path__) is ['/home/Pekka/foam/foam-extend-3.1/ThirdParty/packages/PyFoam-0.6.1/platforms/noarch/lib/python2.7/site-packages/PyFoam']
Configuration search path: [('file', '/etc/pyFoam/pyfoamrc'), ('directory', '/etc/pyFoam/pyfoamrc.d'), ('file', '/home/Pekka/.pyFoam/pyfoamrc'), ('directory', '/home/Pekka/.pyFoam/pyfoamrc.d')]
hotshot              :  Yes
profile              :  Yes
cProfile             :  Yes
PyQt4                :  Yes
vtk                  :  Yes
mercurial            :  Yes
Library locations
Thanks in advance
BR/Pekka
Pekka is offline   Reply With Quote
Old   October 24, 2015, 17:55
Retired Super Moderator
Bruno Santos
Quick answer @Pekka: VTK 6.1... I don't think that PyFoam is prepared for VTK 6.x, because the API changed considerably between VTK 5.x to 6.x.
How exactly did you install Qt 4.8 and VTK 6.1 in RHEL 7? Was it from the EPEL repositories?
Old   October 29, 2015, 14:34
Thank you Bruno!
Problem has been solved by downgrade vtk to older one. I compiled vtk-5.10.1-4 from fc19.src.rpm source package. vtk 6.1.0 is from epel repository.
BR/Pekka
wyldckat likes this.
Old   October 26, 2021, 11:25
Craig Thomas
mn14cat is on a distinguished road
Hello everyone
I know this thread is years old but I'm hoping someone will still be able help.
I'm trying to use the pyFoamDisplayBlockMesh function but keep getting the following error:
segmentation fault (core dumping).
with no further indication as to the cause of the error. I then set about compiling foam-extend 4 in debug mode which then gave me the following error:
mn14cat@mn14cat-XPS-13-7390:~/foam/mn14cat-4.1/run/tutorials/solidMechanics/elasticSolidFoam/plateHole$ pyFoamDisplayBlockMesh.py constant/polyMesh/blockMeshDict
VTK version 6
PyFoam WARNING on line 48 of file /home/mn14cat/foam/foam-extend-4.1/ThirdParty/packages/PyFoam-0.6.9/platforms/noarch/lib/python2.7/site-packages/PyFoam-0.6.9-py2.7.egg/PyFoam/Applications/DisplayBlockMeshQt.py : VTK version 6 currently unsupported
Segmentation fault (core dumped)
So my question is how would I go about downgrading my version of VTK and which version would be best to run displayMesh.py
thanks in advance and hopefully someone finds this.
mn14cat is offline   Reply With Quote
[swak4Foam] Problems installing swak4Foam in foam-extend-4.0 on Ubuntu 16.04 jock OpenFOAM Community Contributions 12 September 6, 2019 03:27
[OpenFOAM.com] v3.0+ Problems installing on Ubuntu 16.04 Evander OpenFOAM Installation 3 March 26, 2017 14:47
[OpenFOAM.org] Problems installing OF4.1 in Kubuntu 14.04 Outbound OpenFOAM Installation 5 February 2, 2017 07:54
[foam-extend.org] Problems installing foam-extend 3.0 aylalisa OpenFOAM Installation 9 April 23, 2015 16:17
Problems installing CFX on Sun Unix Platform Haley CFX 2 November 9, 2001 09:52
