Pre-compiled disk images of version 2.1 for Mac?
Old   August 17, 2012, 15:49
Default Pre-compiled disk images of version 2.1 for Mac?
einat
einatlev is on a distinguished road
Hello
Thank you for all your work on OpenFOAM!
I recently installed the latest 2.1.x version of OpenFOAM on my Linux machine, using the source code from the git repository. I have also installed version 2.0 on my Mac laptop, using the pre-compiled disk images. Both work well. Now I'd like to run the new solver "optentialFreeSurfaceFoam", which was added in v.2.1.x, on my Mac, but I'd like to avoid having to build from scratch source code on the Mac, if possible. Are there any precompiled version 2.1 files out there?
Thanks!
Einat
einatlev is offline   Reply With Quote
Old   August 31, 2012, 06:50
Retired Super Moderator
Bruno Santos
This comes a bit late, but for your information:
Originally Posted by qzt View Post
I just uploaded the disk image (dmg file) of OpenFOAM-2.1.0 compiled on my macbookpro running lion (os 10.7).
Maybe someone having difficulty to compile or want to save some time can just use it.
http://bit.ly/QzxHFG
I think after mounting the disk image, one can try to source the bashrc and run the foamInstallationTest to see if it works on your mac.
Old   September 8, 2012, 17:03
einat
Thanks much.
Old   September 8, 2012, 17:47
einat
I'm running into problems installing the DMG file:
Anything I try to do, I get an error saying that this is a "read-only file system". I tried changing the disk-image name to .sparseimage instead of .dmg, and also to make the disk image writable to all users, but nothing helped. I tried using sudo, no help.
Any ideas??
Thanks!!
Einat
Old   September 9, 2012, 03:52
Bruno Santos
Hi Einat,
Why do you want to change that image to be read-write? You only need it for getting a working OpenFOAM installation!
Anything else can be written in your personal folders!
Best regards,
Bruno
Old   September 9, 2012, 10:27
einat
I didn't necessarily want to, but I get an error even when I try to create the "$USER-2.1.0" folder that the installation instructions call for. And I tried cleaning and re-building, b/c the instructions said it was a good idea, and I kept getting errors that it was read-only system...
Old   September 9, 2012, 11:50
Bruno Santos
It's simple (assuming nothing is mounted):
  1. Mount the read-only image at "/Volumes/OpenFOAM-v2.1" with case-sensitivity turned on (if that's a choice).
  2. Run these commands:
    cd ~
    mkdir OpenFOAM
    cd OpenFOAM
    ln -s /Volumes/OpenFOAM-v2.1/OpenFOAM-2.1.0 OpenFOAM-2.1.0
    ln -s /Volumes/OpenFOAM-v2.1/ThirdParty-2.1.0 ThirdParty-2.1.0
    It will create symbolic links to the mounted image, only linking the relevant folders.
  3. Source OpenFOAM's "bashrc":
    source ~/OpenFOAM-2.1.0/etc/bashrc
  4. Try running icoFoam:
    icoFoam -help
    If it works, you're ready to go!
Old   September 9, 2012, 12:02
einat
Got it. So to run a tutorial, I first need to copy it into a read-write folder of my own, and then run it? I tried that with icoFoam's cavity example and it seemed to work.
Old   September 9, 2012, 12:34
Bruno Santos
Yes, that's the idea. Actually, following the steps I outlined, you should be able to run the commands listed shown in the section Getting Started from http://www.openfoam.org/download/source.php
The same goes for solvers and libraries you may want to modify. For creating a modified solver, here is a good tutorial for it: http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam
Old   September 9, 2012, 19:23
einat
Awesome! thanks so much!
Old   October 12, 2012, 09:02
Default Problems with parafoam starting
  #11
Malachy O'Rourke
morourke is on a distinguished road
I followed the instructions and everything went fine until I went to run paraFoam. I got the following message. Any help appreciated.
dhcp-892b949a:~ malachyorourke$ paraFoam
FATAL ERROR: ParaView reader module libraries do not exist
Please build the reader module before continuing:
cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers
./Allwclean
./Allwmake
dhcp-892b949a:~ malachyorourke$ cd cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers
-bash: cd: cd: No such file or directory
./Allwclean
./Allwmake
dhcp-892b949a:~ malachyorourke$ cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers
dhcp-892b949a:PV3Readers malachyorourke$ ./Allwclean
+ wclean libso vtkPV3Readers
wclean vtkPV3Readers
+ PV3blockMeshReader/Allwclean
+ rm -f '/Users/malachyorourke/OpenFOAM/OpenFOAM-2.1.0/platforms/darwinIntel64Gcc46DPOpt/lib/libPV3blockMeshReader*'
+ rm -rf PV3blockMeshReader/Make
+ wclean libso vtkPV3blockMesh
wclean vtkPV3blockMesh
+ PV3FoamReader/Allwclean
+ rm -f '/Users/malachyorourke/OpenFOAM/OpenFOAM-2.1.0/platforms/darwinIntel64Gcc46DPOpt/lib/libPV3FoamReader*'
+ rm -rf PV3FoamReader/Make
+ wclean libso vtkPV3Foam
wclean vtkPV3Foam
dhcp-892b949a:PV3Readers malachyorourke$ ./Allwmake
+ '[' -d /Users/malachyorourke/OpenFOAM/ThirdParty-2.1.0/platforms/darwinIntel64Gcc46/paraview-3.12.0 -a -r /Users/malachyorourke/OpenFOAM/ThirdParty-2.1.0/platforms/darwinIntel64Gcc46/paraview-3.12.0 ']'
Malachy
morourke is offline   Reply With Quote
Old   October 12, 2012, 15:48
Bruno Santos
Greetings Malachy,
Read this:
http://openfoamwiki.net/index.php/Ho...using_ParaView - section "3 Installing and using ParaView"
Best regards,
Bruno
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 11:12
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 07:11
OpenFOAM-1.6 install cookbook MadsR OpenFOAM Installation 372 November 20, 2010 11:57
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
Troubles with compiled version of paraviewparafoam tgazz OpenFOAM Bugs 1 April 17, 2008 10:42
