[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch
Like Tree8Likes
Old   April 1, 2014, 08:59
nasir musa yakubu
esujby is on a distinguished road
Originally Posted by alexeym View Post
try rereading what I've written in my reply. I will repeat it here in bold:
1. the patch here is for OpenFOAM-2.3.x (git version), patch in the blog is for OpenFOAM-2.3.0 (release source packs).
so basically you're trying to apply patch for git version of OpenFOAM (acquired with git clone git://github.com/OpenFOAM/OpenFOAM-2.3.x.git) to the release packs (you've downloaded OpenFOAM-2.3.0.tgz and ThirdParty-2.3.0.tgz from openfoam.org). As a result it fails.
Hello Alexey,
Apologies for not making it very clear! the post i made on this thread was based on my previous installation attempts, which i followed the procedure on wiki, but i abandoned that particular method as i ve tried so many attempts and it didnt work.That been said, my latest installations attempts has been based on this your blogs installation method which is this:
http://matveichev.blogspot.co.uk/201...l#comment-form
i also got all the installation folders from there, tried to install it so many times but had problems applying the patch. i thought there was a problem with the patch on your blog and downloaded the other patch in this forum which is OpenFOAM-2.3.x-Mac.Patch but now that you have explained it to me, i would delete it straight away and only use the one on your blog which is OpenFOAM-2.3.0-2.Patch.
anyhows i have tried applying both patches but it didnt work but will try and follow the procedure on your blog from the beginning.
Ihave followed the exact same procedure as it is in your blog mr alex, but when it comes to applying the patches, i end up getting the following:
Last login: Tue Apr 1 16:26:19 on ttys001
nasirs-imac:~ nasiryakubu$ cd /Volumes/OpenFOAM-v2.3/OpenFOAM-2.3.0
nasirs-imac:OpenFOAM-2.3.0 nasiryakubu$ ls -lstr
total 208
0 drwxr-xr-x@ 5 nasiryakubu staff 782 11 Feb 11:59 wmake
0 drwxr-xr-x@ 16 nasiryakubu staff 646 11 Feb 11:59 tutorials
0 drwxr-xr-x@ 37 nasiryakubu staff 1292 11 Feb 11:59 src
0 drwxr-xr-x@ 6 nasiryakubu staff 272 11 Feb 11:59 doc
0 drwxr-xr-x@ 5 nasiryakubu staff 204 11 Feb 11:59 applications
8 -rw-r--r--@ 1 nasiryakubu staff 1587 11 Feb 11:59 README.org
16 -rw-r--r--@ 1 nasiryakubu staff 7611 11 Feb 11:59 README.html
72 -rw-r--r--@ 1 nasiryakubu staff 35647 11 Feb 11:59 COPYING
8 -rwxr-xr-x@ 1 nasiryakubu staff 932 11 Feb 11:59 Allwmake
104 -rw-r--r--@ 1 nasiryakubu staff 51144 1 Apr 15:59 OpenFOAM-2.3.0-2.patch
0 drwxr-xr-x@ 6 nasiryakubu staff 340 1 Apr 16:16 etc
0 drwxr-xr-x@ 3 nasiryakubu staff 2142 1 Apr 16:16 bin
nasirs-imac:OpenFOAM-2.3.0 nasiryakubu$ git apply OpenFOAM-2.3.0-2.patch
error: patch failed: applications/solvers/combustion/fireFoam/Make/options:36
error: applications/solvers/combustion/fireFoam/Make/options: patch does not apply
error: patch failed: applications/solvers/compressible/rhoSimpleFoam/rhoSimplecFoam/Make/options:13
error: applications/solvers/compressible/rhoSimpleFoam/rhoSimplecFoam/Make/options: patch does not apply
error: patch failed: applications/solvers/heatTransfer/chtMultiRegionFoam/chtMultiRegionSimpleFoam/Make/options:27
error: applications/solvers/heatTransfer/chtMultiRegionFoam/chtMultiRegionSimpleFoam/Make/options: patch does not apply
error: patch failed: applications/solvers/incompressible/adjointShapeOptimizationFoam/Make/options:6
error: applications/solvers/incompressible/adjointShapeOptimizationFoam/Make/options: patch does not apply
error: patch failed: applications/solvers/incompressible/simpleFoam/SRFSimpleFoam/Make/options:11
error: applications/solvers/incompressible/simpleFoam/SRFSimpleFoam/Make/options: patch does not apply
error: patch failed: applications/solvers/lagrangian/icoUncoupledKinematicParcelFoam/Make/options:21
error: applications/solvers/lagrangian/icoUncoupledKinematicParcelFoam/Make/options: patch does not apply
error: patch failed: applications/solvers/lagrangian/icoUncoupledKinematicParcelFoam/icoUncoupledKinematicParcelDyMFoam/Make/options:27
error: applications/solvers/lagrangian/icoUncoupledKinematicParcelFoam/icoUncoupledKinematicParcelDyMFoam/Make/options: patch does not apply
error: patch failed: applications/solvers/lagrangian/reactingParcelFilmFoam/Make/options:30
error: applications/solvers/lagrangian/reactingParcelFilmFoam/Make/options: patch does not apply
error: patch failed: applications/solvers/multiphase/multiphaseEulerFoam/Make/options:17
error: applications/solvers/multiphase/multiphaseEulerFoam/Make/options: patch does not apply
error: patch failed: applications/utilities/mesh/generation/blockMesh/Make/options:6
error: applications/utilities/mesh/generation/blockMesh/Make/options: patch does not apply
error: patch failed: applications/utilities/mesh/generation/snappyHexMesh/Make/options:1
error: applications/utilities/mesh/generation/snappyHexMesh/Make/options: patch does not apply
error: patch failed: applications/utilities/mesh/manipulation/renumberMesh/Make/options:1
error: applications/utilities/mesh/manipulation/renumberMesh/Make/options: patch does not apply
error: patch failed: applications/utilities/miscellaneous/foamDebugSwitches/Make/options:42
error: applications/utilities/miscellaneous/foamDebugSwitches/Make/options: patch does not apply
error: patch failed: applications/utilities/parallelProcessing/reconstructParMesh/Make/options:4
error: applications/utilities/parallelProcessing/reconstructParMesh/Make/options: patch does not apply
error: patch failed: applications/utilities/postProcessing/dataConversion/foamToEnsight/Make/options:1
error: applications/utilities/postProcessing/dataConversion/foamToEnsight/Make/options: patch does not apply
error: patch failed: applications/utilities/postProcessing/miscellaneous/execFlowFunctionObjects/Make/options:9
error: applications/utilities/postProcessing/miscellaneous/execFlowFunctionObjects/Make/options: patch does not apply
error: patch failed: applications/utilities/postProcessing/turbulence/R/Make/options:10
error: applications/utilities/postProcessing/turbulence/R/Make/options: patch does not apply
error: patch failed: applications/utilities/postProcessing/turbulence/createTurbulenceFields/Make/options:5
error: applications/utilities/postProcessing/turbulence/createTurbulenceFields/Make/options: patch does not apply
error: patch failed: applications/utilities/postProcessing/velocityField/Pe/Make/options:12
error: applications/utilities/postProcessing/velocityField/Pe/Make/options: patch does not apply
error: patch failed: applications/utilities/postProcessing/wall/wallShearStress/Make/options:7
error: applications/utilities/postProcessing/wall/wallShearStress/Make/options: patch does not apply
error: patch failed: applications/utilities/postProcessing/wall/yPlusLES/Make/options:8
error: applications/utilities/postProcessing/wall/yPlusLES/Make/options: patch does not apply
error: patch failed: applications/utilities/postProcessing/wall/yPlusRAS/Make/options:10
error: applications/utilities/postProcessing/wall/yPlusRAS/Make/options: patch does not apply
error: patch failed: applications/utilities/preProcessing/applyBoundaryLayer/Make/options:8
error: applications/utilities/preProcessing/applyBoundaryLayer/Make/options: patch does not apply
error: bin/addr2line4Mac.py: already exists in working directory
error: patch failed: bin/paraFoam:68
error: bin/paraFoam: patch does not apply
error: patch failed: etc/bashrc:63
error: etc/bashrc: patch does not apply
error: patch failed: etc/config/CGAL.sh:31
error: etc/config/CGAL.sh: patch does not apply
error: patch failed: etc/config/paraview.sh:102
error: etc/config/paraview.sh: patch does not apply
error: patch failed: etc/config/settings.sh:46
error: etc/config/settings.sh: patch does not apply
error: patch failed: src/OSspecific/POSIX/POSIX.C:53
error: src/OSspecific/POSIX/POSIX.C: patch does not apply
error: patch failed: src/OSspecific/POSIX/clockTime/clockTime.H:37
error: src/OSspecific/POSIX/clockTime/clockTime.H: patch does not apply
error: patch failed: src/OSspecific/POSIX/fileStat.C:29
error: src/OSspecific/POSIX/fileStat.C: patch does not apply
error: patch failed: src/OSspecific/POSIX/printStack.C:31
error: src/OSspecific/POSIX/printStack.C: patch does not apply
error: patch failed: src/OSspecific/POSIX/signals/sigFpe.C:42
error: src/OSspecific/POSIX/signals/sigFpe.C: patch does not apply
error: patch failed: src/OSspecific/POSIX/signals/sigFpe.H:55
error: src/OSspecific/POSIX/signals/sigFpe.H: patch does not apply
error: patch failed: src/OpenFOAM/db/dictionary/functionEntries/codeStream/codeStream.C:30
error: src/OpenFOAM/db/dictionary/functionEntries/codeStream/codeStream.C: patch does not apply
error: patch failed: src/OpenFOAM/db/dynamicLibrary/codedBase/codedBase.C:228
error: src/OpenFOAM/db/dynamicLibrary/codedBase/codedBase.C: patch does not apply
error: patch failed: src/OpenFOAM/db/dynamicLibrary/dynamicCode/dynamicCode.C:38
error: src/OpenFOAM/db/dynamicLibrary/dynamicCode/dynamicCode.C: patch does not apply
error: patch failed: src/OpenFOAM/db/dynamicLibrary/dynamicCode/dynamicCode.H:98
error: src/OpenFOAM/db/dynamicLibrary/dynamicCode/dynamicCode.H: patch does not apply
error: patch failed: src/OpenFOAM/primitives/Scalar/doubleFloat.H:31
error: src/OpenFOAM/primitives/Scalar/doubleFloat.H: patch does not apply
error: patch failed: src/conversion/ensight/part/ensightPart.C:51
error: src/conversion/ensight/part/ensightPart.C: patch does not apply
error: patch failed: src/conversion/ensight/part/ensightPartIO.C:63
error: src/conversion/ensight/part/ensightPartIO.C: patch does not apply
error: patch failed: src/dynamicMesh/fvMeshDistribute/fvMeshDistributeTemplates.C:231
error: src/dynamicMesh/fvMeshDistribute/fvMeshDistributeTemplates.C: patch does not apply
error: patch failed: src/fvOptions/Make/options:13
error: src/fvOptions/Make/options: patch does not apply
error: patch failed: src/parallel/decompose/ptscotchDecomp/Make/options:8
error: src/parallel/decompose/ptscotchDecomp/Make/options: patch does not apply
error: patch failed: src/parallel/decompose/scotchDecomp/Make/options:12
error: src/parallel/decompose/scotchDecomp/Make/options: patch does not apply
error: patch failed: src/renumber/SloanRenumber/Make/options:1
error: src/renumber/SloanRenumber/Make/options: patch does not apply
error: patch failed: src/renumber/zoltanRenumber/Make/options:2
error: src/renumber/zoltanRenumber/Make/options: patch does not apply
error: patch failed: wmake/rules/General/CGAL:10
error: wmake/rules/General/CGAL: patch does not apply
error: wmake/rules/darwinIntel64Clang/c: already exists in working directory
error: wmake/rules/darwinIntel64Clang/c++: already exists in working directory
error: wmake/rules/darwinIntel64Clang/c++Debug: already exists in working directory
error: wmake/rules/darwinIntel64Clang/c++Opt: already exists in working directory
error: wmake/rules/darwinIntel64Clang/c++Prof: already exists in working directory
error: wmake/rules/darwinIntel64Clang/cDebug: already exists in working directory
error: wmake/rules/darwinIntel64Clang/cOpt: already exists in working directory
error: wmake/rules/darwinIntel64Clang/cProf: already exists in working directory
error: wmake/rules/darwinIntel64Clang/general: already exists in working directory
error: wmake/rules/darwinIntel64Clang/mplibOPENMPI: already exists in working directory
nasirs-imac:OpenFOAM-2.3.0 nasiryakubu$ cd
nasirs-imac:~ nasiryakubu$ cd /Volumes/OpenFOAM-v2.3/ThirdParty-2.3.0
nasirs-imac:ThirdParty-2.3.0 nasiryakubu$ ls -lstr
total 248
8 -rwxr-x---@ 1 nasiryakubu staff 3864 6 Feb 15:31 makeQt
24 -rwxr-x---@ 1 nasiryakubu staff 9234 6 Feb 15:31 makeParaView4
24 -rwxr-x---@ 1 nasiryakubu staff 9152 6 Feb 15:31 makeParaView
8 -rwxr-x---@ 1 nasiryakubu staff 3643 6 Feb 15:31 makeLLVM
16 -rwxr-x---@ 1 nasiryakubu staff 6698 6 Feb 15:31 makeGcc48
16 -rwxr-x---@ 1 nasiryakubu staff 6773 6 Feb 15:31 makeGcc47
16 -rwxr-x---@ 1 nasiryakubu staff 6773 6 Feb 15:31 makeGcc46
16 -rwxr-x---@ 1 nasiryakubu staff 6778 6 Feb 15:31 makeGcc
8 -rwxr-x---@ 1 nasiryakubu staff 3349 6 Feb 15:31 makeCmake
8 -rwxr-x---@ 1 nasiryakubu staff 2484 6 Feb 15:31 AllwmakeLibccmio
8 -rwxr-x---@ 1 nasiryakubu staff 2170 6 Feb 15:31 Allclean
8 -rw-r-----@ 1 nasiryakubu staff 2682 6 Feb 16:46 README.org
24 -rw-r-----@ 1 nasiryakubu staff 10485 6 Feb 16:46 README.html
16 -rw-r--r--@ 1 nasiryakubu staff 6578 1 Apr 15:59 ThirdParty-2.3.0-1.patch
0 drwxr-xr-x 9 nasiryakubu staff 884 1 Apr 16:12 openmpi-1.6.5
0 drwxr-xr-x 9 nasiryakubu staff 1020 1 Apr 16:12 cmake-2.8.12.1
0 drwxr-xr-x 7 nasiryakubu staff 408 1 Apr 16:12 scotch_6.0.0
0 drwxr-xr-x 11 nasiryakubu staff 748 1 Apr 16:12 CGAL-4.3
0 drwxr-xr-x 19 nasiryakubu staff 1020 1 Apr 16:13 ParaView-4.1.0
24 -rwxr-xr-x 1 nasiryakubu staff 9237 1 Apr 16:18 makeCGAL
24 -rwxr-xr-x 1 nasiryakubu staff 10682 1 Apr 16:18 Allwmake
0 drwxr-xr-x 4 nasiryakubu staff 204 1 Apr 16:26 etc
nasirs-imac:ThirdParty-2.3.0 nasiryakubu$ git apply ThirdParty-2.3.0-1.patch
error: patch failed: Allwmake:52
error: Allwmake: patch does not apply
error: etc/wmakeFiles/scotch/Makefile.inc.i686_mac_darwin.shlib-OpenFOAM: already exists in working directory
error: patch failed: makeCGAL:128
error: makeCGAL: patch does not apply
thanks
nas
esujby is offline   Reply With Quote
Old   April 10, 2014, 19:44
Assistant Moderator
Bernhard Gschaider
Originally Posted by esujby View Post
Hello Alexey,
total 208
That and the output when you applied the regular patch-utility ("Reversed (or previously applied) patch detected!") lead me to the suspicion that you tried to apply the patch a second time. Could this be the case?
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   April 10, 2014, 20:08
Youngkook Kim
totalart is on a distinguished road
During compiling, following errors occurred. Can you advise me what the problem is? Thank you!
Make/darwinIntel64Gcc46DPOpt/STLsurfaceFormatASCII.C:312:23: fatal error: FlexLexer.h: No such file or directory
make: *** [Make/darwinIntel64Gcc46DPOpt/STLsurfaceFormatASCII.o] Error 1
Make/darwinIntel64Gcc46DPOpt/readSTLASCII.C:312:23: fatal error: FlexLexer.h: No such file or directory
make: *** [Make/darwinIntel64Gcc46DPOpt/readSTLASCII.o] Error 1
make: *** [/Users/youngkookkim/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib/libmeshTools.dylib] Error 1
make: *** [/Users/youngkookkim/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib/libedgeMesh.dylib] Error 1
make: *** [/Users/youngkookkim/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib/libfiniteVolume.dylib] Error 1
make: *** [/Users/youngkookkim/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib/liblagrangian.dylib] Error 1
make: *** [/Users/youngkookkim/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib/libgenericPatchFields.dylib] Error 1
make: *** [/Users/youngkookkim/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib/libdecompositionMethods.dylib] Error 1
make: *** [/Users/youngkookkim/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib/libdecompose.dylib] Error 1
make: *** [/Users/youngkookkim/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib/libreconstruct.dylib] Error 1
make: *** [/Users/youngkookkim/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib/libdistributed.dylib] Error 1
make: *** [/Users/youngkookkim/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib/librenumberMethods.dylib] Error 1
make: *** [/Users/youngkookkim/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib/libSloanRenumber.dylib] Error 1
make: *** [/Users/youngkookkim/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib/libconversion.dylib] Error 1
make: *** [/Users/youngkookkim/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib/libsampling.dylib] Error 1
make: *** [/Users/youngkookkim/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib/libextrudeModel.dylib] Error 1
make: *** [/Users/youngkookkim/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib/libdynamicMesh.dylib] Error 1
make: *** [/Users/youngkookkim/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib/libdynamicFvMesh.dylib] Error 1
make: *** [/Users/youngkookkim/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib/libtopoChangerFvMesh.dylib] Error 1
make: *** [/Users/youngkookkim/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib/librandomProcesses.dylib] Error 1
make: *** [/Users/youngkookkim/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib/libfluidThermophysicalModels.dylib] Error 1
totalart is offline   Reply With Quote
Old   April 10, 2014, 22:30
Youngkook Kim
Originally Posted by redAbbot View Post
I'm not having luck with the patch:
bash-3.2$ patch -p1<OpenFOAM-2.3.x-Mac.patch
patch unexpectedly ends in middle of line
patch: **** Only garbage was found in the patch input.
It's unclear to me if I have to install the SurfaceGCALFix patch, but I tried anyway and got a different error:
bash-3.2$ patch -p1<SurfaceCGALFix.patch
patching file applications/utilities/surface/surfaceFeatureExtract/surfaceFeatureExtract.C
Hunk #1 FAILED at 48.
1 out of 1 hunk FAILED -- saving rejects to file applications/utilities/surface/surfaceFeatureExtract/surfaceFeatureExtract.C.rej
I had some error in applying SurfaceGCALFix patch, so I assumed the patch is not needed for 2.3. Do we need?? When I look at the errors above during the install, it seems I need it. Have you managed to install?
Old   April 10, 2014, 23:06
nasir musa yakubu
Hello gschaider,
It could be the case but i have always had the same result when i tried to apply the patch, always, i dont know why but i always did.
please can you advice me on how to clean up everything and all the applied patches and start the installation all over again, and advice me on which of the installation procedure is best suited for the new imac with mac maverick.
kind regards
nas
Old   April 13, 2014, 09:28
Assistant Moderator
Bernhard Gschaider
This patch was only necessary for 2.2 as it hasbeen included into the 2.3 patch
Old   April 13, 2014, 09:32
Assistant Moderator
Bernhard Gschaider
Hello gschaider,
kind regards
nas
You can always reverse-apply the patch (see man-page) but you might see similar problems here ... only in reverse.
The "safest" (but also most painful) way would be to remove the directory altogether, get the original sources again and apply the patch on this clean directory (you don't have to remove the old directory. Just move it out of the way)
Old   April 14, 2014, 20:20
Default Error in compiling
  #28
Pierluigi Morra
maCrobo is on a distinguished road
Hello everyone, I have some problems and I am very inexperienced, so I don't really know what I can do to try to fix them.
I followed the Wiki guide carefully, but the computer doesn't finish compiling OpenFOAM.
I downloaded OpenFOAM 2.3.x from git because I understood from previous posts that the patch presented in this thread is for that version; in fact I followed those instructions to download OpenFoam 2.3.x and the ThirdParty (as you can see on the instructions page it says ThirdParty-2.3.0).
Then I started to follow the Wiki guide carefully. I think I didn't miss anything. Once I launch ./Allwmake the process stops with a bunch of errors.
The first thing I thought is that I missed something written in the patch README file, but I did the --select part for the mpi (I chose openmpi-gcc46-fortran), I downloaded via Macports the files that take now the place of the old third party patch; I downloaded only one patch file called OpenFOAM-2.3.x-Mac.patch (I think it's correct).
I have the log file and I haven't closed my terminal window yet, so it has the results of the process. Anyway, attaching the log file is a bit easier for me, so I'm doing that; if you need more information let me know.
P.S.: everything took place under OSX 10.9.0
I had to split the log file because it was too heavy to be uploaded.
maCrobo is offline   Reply With Quote
Old   April 15, 2014, 03:20
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Well, below are just guesses:
1. As far as I can see in the message, there is no need for ThirdParty source pack as you should install dependencies (OpenMPI, Scotch, CGAL, Boost, GMP, MPFR) with MacPorts. So I will skip errors you've got during Scotch build.
2. Are you sure that git clone was done without errors? You've got these lines in your logs:
could not open file PointHit.H for source file global/global.Cver due to No such file or directory
could not open file PointHit.H for source file primitives/globalIndexAndTransform/globalIndexAndTransform.C due to No such file or dire
ctory
Can you run
find . -name 'PointHit.H'
in OpenFOAM-2.3.x folder? Will it find the file?
alexeym is offline   Reply With Quote
Old   April 15, 2014, 05:18
Pierluigi Morra
Can you run
I have to admit it was the first time I ever used that command. I did what you said and nothing happened, so I guess it doesn't find anything (I tried to find "Allwmake" and it gave me back a bunch of addresses).
When I downloaded I simply typed
git clone https://github.com/OpenFOAM/OpenFOAM-2.3.x.git
It seems that I removed the download, so the only thing I know is that it was complete because I manage to unzip it.
What else should I check?
Old   April 15, 2014, 05:38
Alexey Matveichev
Sorry, can't understand the phrase. Why unzip? git clone will create source tree for you so there's no need to unzip anything.
Where did you clone the sources? I hope into the mounted image with case sensitive file system.
And as it seems there is no PointHit.H file, maybe you should clone repository once again.
Old   April 15, 2014, 06:25
Pierluigi Morra
Nevermind.
Yes, as it says in the guide I linked. I opened the Utility Disk, created a sparse image with:
Format: Mac OS Extended (Case-sensitive)
Partition: Rigid Disk
Image format: Sparse
(note: Image Formate is not Sparse-bundle, I chose Sparse)
Then I downloaded everything, took the result and moved it in the mounted image.
Before, I said that I unzipped it, but I actually don't remember; anyway, I was able to get inside the folder. I also remember the clone wasn't directly done inside the Sparse Image, there's a high possibility I copied it there later. I'll try to start everything again by cloning it directly in the sparse image.
Do you have any other ideas?
Old   April 15, 2014, 07:56
Alexey Matveichev
Do I get you right:
- First you've created a disk image with case SENSITIVE file system as it is required by OpenFOAM's file naming conventions.
- Then you create a clone of repository on case INSENSITIVE file system (basically loosing part of the source tree).
- And then you move the damaged source tree from case INSENSITIVE FS to case SENSITIVE FS.
I don't see the point in creating image with case sensitive FS in the first place with this way of cloning repository.
You should execute 'git clone ...' inside the folder where you've mounted disk image. And then proceed further with build.
Old   April 15, 2014, 18:13
Pierluigi Morra
Do I get you right:
Yes, you got it.
I tried again. This time I executed the "git clone" inside the Case Sensitive Sparse Image, so I should have the complete file.
Unfortunately some other errors poped up. I attach the Log File (split into two parts because of size issues).
This time it seems the scotch error is one of the first ones; I tried to execute the command "sudo port install scotch" and it seems it is installed, the same for all the other "port" adds I need.
I'll repeat what I did: I created the sparse image (case Sensitive), "git clone" in it, download ThirdParty-2.3.0.tgz and open it in the Sparse Image (not inside the OpenFoam-2.3.x folder, but in the same folder where OpenFoam-2.3.x is); from there on I follow the Wiki Guide.
Notes:
- after installing openmpi-gcc46 through Macports, I execute "sudo port select --set mpi openmpi-gcc46-fortran" (as suggested earlier on this thread)
- point 7 of 4.2 of the Wiki guide: I don't have the "wmake/rules/darwinIntel64Gcc4*"
- point 4 of 4.3 of the Wiki guide: the end of the file is before the last line where is written something like "----------End of File" or after?
- I didn't do point 6 of 4.3 of the Wiki guide because I don't have that file and someone on this post has said that it is actually useless to do it in this version
- point 8 of 4.3 of the Wiki guide: I have a slightly different string, the following "L$(BOOST_ARCH_PATH)/lib -lboost_thread$(BOOST_THREAD_EXTENSION)" that I modify to have "L$(BOOST_ARCH_PATH)/lib -lboost_thread-mt$(BOOST_THREAD_EXTENSION)"
Old   April 16, 2014, 04:11
Alexey Matveichev
Well, I've looked through your logs and was able to find only a few errors:
1. During compilation of scotch
gcc-mp-4.6 -O3 -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DSCOTCH_RENAME -Drestrict=__restrict -DSCOTCH_VERSION=6 -DSCOTCH_R
ELEASE=0 -DSCOTCH_PATCHLEVEL=0 dummysizes.c -o dummysizes -Xlinker --no-as-needed -lz -lm -lrt
ld: unknown option: --no-as-needed
collect2: ld returned 1 exit status
I'd rather surprised that you need to build scotch again as you've installed it through Macports. Any way Scotch decomposition seems to compile, though not sure it will be working.
2. During SloanRenumber compilation
+ wmake libso SloanRenumber
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file SloanRenumber.C
SOURCE=SloanRenumber.C ;  g++-mp-4.6 -m64 -fsignaling-nans  -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter
 -Wold-style-cast -Wnon-virtual-dtor -O2  -DNoRepository -ftemplate-depth-100 -I/opt/local/include -I/Users/myName/OpenFOAM/OpenFOAM-2.
3.x/src/meshTools/lnInclude -I/Users/myName/OpenFOAM/OpenFOAM-2.3.x/src/parallel/decompose/decompositionMethods/lnInclude -I/Users/myNa
me/OpenFOAM/OpenFOAM-2.3.x/src/renumber/renumberMethods/lnInclude -IlnInclude -I. -I/Users/myName/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/
lnInclude -I/Users/myName/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64Gcc46
DPOpt/SloanRenumber.o
ld: library not found for -lboost_thread-mt-mt
make: *** [/Users/myName/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/lib/libSloanRenumber.dylib] Error 1
This is due to your last modification. Either you use
-L$(BOOST_ARCH_PATH)/lib -lboost_thread$(BOOST_THREAD_EXTENSION)
or
-L$(BOOST_ARCH_PATH)/lib -lboost_thread-mt
-mt actually is inside $(BOOST_THREAD_EXTENSION) variable.
3. And finally during compilation of driftFluxFoam
Undefined symbols for architecture x86_64:
  "Foam::twoPhaseMixture::twoPhaseMixture(Foam::fvMesh const&, Foam::dictionary const&)", referenced from:
      Foam::incompressibleTwoPhaseInteractingMixture::incompressibleTwoPhaseInteractingMixture(Foam::GeometricField<Foam::Vector<double
>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in incompres
sibleTwoPhaseInteractingMixture.o
ld: symbol(s) not found for architecture x86_64
make[2]: *** [/Users/myName/OpenFOAM/OpenFOAM-2.3.x/platforms/darwinIntel64Gcc46DPOpt/bin/driftFluxFoam] Error 1
And this is due to incomplete Make/options file of this application. I guess they forgot to put -ltwoPhaseMixture in EXE_LIBS.
Also there is error message from Paraview but it's normal as you don't need to build Paraview on OS X.
There were no more errors in your log files.
Old   April 16, 2014, 04:41
Pierluigi Morra
Many thanks, man. Really!
I don't know what to do here, because I actually don't know what files/folders I should modify/move to fix the problem as scotch is installed (...apparently).
or
Well, I'll change this and try again.
I guess I can't do anything for that, right?
Old   April 16, 2014, 04:53
Alexey Matveichev
It was not hard as I've just searched 'error' word in the files.
You can ignore this error right now, if there will be problem with scotch mesh decomposition method then you can start to worry and try to solve the problem.
Well, you can edit applications/solvers/multiphase/driftFluxFoam/Make/options file, add '-ltwoPhaseMixture \' line after 'EXE_LIBS = \' line and run Allwmake in applications/solvers/multiphase/driftFluxFoam folder. Or you can ignore the error if you don't plan to use this solver.
Old   April 16, 2014, 05:19
Pierluigi Morra
I did it and when I run ./Allwmake (while in "applications/solvers/multiphase/driftFluxFoam" folder) I have this answer on the Terminal:
+ wmake libso mixtureViscosityModels
./Allwmake: line 5: wmake: command not found
+ wmake libso relativeVelocityModels
./Allwmake: line 6: wmake: command not found
+ wmake
./Allwmake: line 7: wmake: command not found
Old   April 16, 2014, 05:24
Alexey Matveichev
And did you 'source etc/bashrc' before running the script? It seems that environment variables are not set up.
Old   April 16, 2014, 06:21
Pierluigi Morra
I didn't know of this source thing either... The problem here is that I don't understand the logic behind all these things I'm doing to compile OpenFoam... Anyway, I did it and it compiled that specific solver.
I have another question: should have I downloaded the patch directly in the Case Sensitive Image, or it is ok that I downloaded on my Downloads system folder where I usually download everything?
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 07:30
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 13:48
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 02:01
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
