openfoam210 compilation error in mpicxx.h file
Like Tree1Likes
Old   August 14, 2012, 02:04
Alpesh
alvora is on a distinguished road
Hello Bruno,
Thank you for reply...
Foam compilation location is already ThirdParty...
I compile everything in Thirdparty..
by the way, flex version is 2.5.31,
Kind Regards
Alpesh
alvora is offline   Reply With Quote
Old   August 14, 2012, 02:08
Alpesh
Hi Bruno,
Thank you for reply,
I made this change before compiling...
By the way, the flex version is 2.5.31 in cluster...
Old   August 14, 2012, 04:33
Retired Super Moderator
Bruno Santos
I vaguely remember that you'll need at least flex 2.5.35... and I know I've already described how to build it here in the forum...
I can't look for it right now...
Basically, the reason why you're not being able to build ansysToFoam is because flex is outdated, or at least that's my deduction.
Old   August 14, 2012, 09:36
Alpesh
Hi Bruno,
Thank you..
I installed flex 2.5.35 and compiled... It's worked...
I got some information about how to install flex as Third Party on below web..
https://www.sharcnet.ca/help/index.php/OpenFOAM
Thank you very much again...
Kind Regards
Alpesh
Old   May 30, 2013, 16:27
Default hydra
  #25
ehk
ehsankf is on a distinguished road
Our setup do not support launching job using hydra.
That essentially means many of the ports hydra needs is not open.
Is it possible to run OpenFoam applications with out using hydra.
By default, hydra passes inherits environment variables from the shell on which mpiexec is launched,
and passes it to the launched processes.
ehsankf is offline   Reply With Quote
Old   June 8, 2013, 16:20
Bruno Santos
Greetings ehsankf,
If you don't want to use Hydra, then why don't you use the default MPI that OpenFOAM provides, namely Open-MPI?
Best regards,
Bruno
GPU Linear Solvers for OpenFOAM gocarts OpenFOAM Announcements from Other Sources 37 August 17, 2022 14:22
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
