How to upgrade centFOAM
Old   August 6, 2012, 16:14
Default How to upgrade centFOAM
sukye is on a distinguished road
I have installed centFOAM early this May. How can I upgrade it to include OpenFOAM 2.1.1? Thanks.
sukye is offline   Reply With Quote
Old   August 7, 2012, 03:41
akidess's Avatar
Anton Kidess
Compile from source: http://www.openfoam.org/download/source.php
Edit: Alternatively rerun the centFOAM script. It has been updated to include OF-2.1.1 recently
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   August 7, 2012, 05:59
Retired Super Moderator
Bruno Santos
Don't forget to update the centFOAM.py script first, by downloading the latest version from here: http://sourceforge.net/projects/centfoam/files/
Old   August 7, 2012, 12:09
Thank you Bruno and Anton!
Old   August 13, 2012, 14:23
when I input "blockMesh", the error comes
$HOME/centFOAM/OpenFOAM/ThirdParty-2.1.1/platforms/linux64Gcc/openmpi-1.5.3/lib/libmpi.so.1: ELF file OS ABI invalid
I know it means that the Application Binary Interface is non compatible between binaries used. How to fix this issue?
Old   August 13, 2012, 15:55
Bruno Santos
That's strange... what does the following command output?
uname -m
If it does not output "x86_64", then that's the reason why you're getting that message.
Old   August 13, 2012, 15:57
yes, the output is "x86_64"
uname -m
Old   August 13, 2012, 16:09
Bruno Santos
After you installed CentFOAM, did you modify anything in your personal "~/.bashrc" file?
Or better yet, did you change the reference from 2.1.0 to 2.1.1 or is there a repeated/similar line?
Old   August 13, 2012, 16:12
alias netgen="$HOME/centFOAM/netgen-4.9.14-svn//bin/./start_netgen"
alias engrid="$HOME/centFOAM/engrid-1.3//bin/./start_engrid"
alias paraview="$HOME/centFOAM/paraview-3.10.1//bin/start_paraview"
alias gmsh="$HOME/centFOAM/gmsh-2.5.0//bin/./start_gmsh"
alias OF21=". $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1//etc/bashrc"
alias paraFoam='paraFoam -builtin'
OF21
Old   August 13, 2012, 16:15
Bruno Santos
OK, what does this output:
ldd $(which blockMesh)
This should give you a list of libraries to which blockMesh is expected to load.
Old   August 13, 2012, 16:18
Right. But I still dont know which ones are missing.
Old   August 13, 2012, 16:20
Bruno Santos
I forgot to indicate that this command will show what libraries it's expected to load and from where it will try to load them!
This way we can try to figure out if there are any 32bit libraries that it is trying to load!
Old   August 13, 2012, 16:24
Thanks.
        libblockMesh.so => $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libblockMesh.so (0x00002b23eb280000)
        libmeshTools.so => $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libmeshTools.so (0x00002b23eb4b8000)
        libdynamicMesh.so => $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libdynamicMesh.so (0x00002b23eb939000)
        libOpenFOAM.so => $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so (0x00002b23ebe29000)
        libdl.so.2 => /lib64/libdl.so.2 (0x0000003a64200000)
        libstdc++.so.6 => $HOME/centFOAM/OpenFOAM/ThirdParty-2.1.0/platforms/linux64/gcc-4.6.2/lib64/libstdc++.so.6 (0x00002b23ec56a000)
        libm.so.6 => /lib64/libm.so.6 (0x0000003a63e00000)
        libgcc_s.so.1 => $HOME/centFOAM/OpenFOAM/ThirdParty-2.1.0/platforms/linux64/gcc-4.6.2/lib64/libgcc_s.so.1 (0x00002b23ec86f000)
        libc.so.6 => /lib64/libc.so.6 (0x0000003a63a00000)
        libpthread.so.0 => /lib64/libpthread.so.0 (0x0000003a64600000)
        libtriSurface.so => $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libtriSurface.so (0x00002b23eca85000)
        libfiniteVolume.so => $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so (0x00002b23eccf8000)
        libPstream.so => $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so (0x00002b23ededc000)
        libz.so.1 => /usr/lib64/libz.so.1 (0x0000003a64a00000)
        /lib64/ld-linux-x86-64.so.2 (0x0000003a63600000)
        libfileFormats.so => $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfileFormats.so (0x00002b23ee0e7000)
        libmpi.so.1 => $HOME/centFOAM/OpenFOAM/ThirdParty-2.1.0/platforms/linux64Gcc/openmpi-1.5.3/lib/libmpi.so.1 (0x00002b23ee2f0000)
        libnsl.so.1 => /lib64/libnsl.so.1 (0x0000003a6d800000)
        libutil.so.1 => /lib64/libutil.so.1 (0x0000003a72400000)
No 32bit libraries were called.
Old   August 13, 2012, 16:32
Bruno Santos
Maybe it doesn't load any 32bit libraries, but then why is every single OpenFOAM related library being called from "OpenFOAM-2.1.0" and "ThirdParty-2.1.0" instead of the ones from 2.1.1?
Check in your "~/.bashrc" and see if you don't have more than one definition of "alias OF21"!? Because if you do, then you could/should:
  1. Remove the first call to OF21, which is loading 2.1.0.
  2. Rename the first "alias OF21=*" to "OF210", to avoid collision of definitions.
Then start a new terminal and try again!
For more on this subject: Advanced tips for working with the OpenFOAM shell environment
Old   August 13, 2012, 16:44
Sorry, I just changed OF21 to call 2.1.0 and did not realized it when ldd $(which blockMesh) was run.
Now everything should be pointed to 2.1.1 and the output is
$HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/blockMesh: error while loading shared libraries: $HOME/centFOAM/OpenFOAM/ThirdParty-2.1.1/platforms/linux64Gcc/openmpi-1.5.3/lib/libmpi.so.1: ELF file OS ABI invalid
Old   August 13, 2012, 16:53
Bruno Santos
Mmm... weird... OK, let's try to use the ThirdParty folder from 2.1.0 with OpenFOAM 2.1.1:
cd $HOME/centFOAM/OpenFOAM
mv ThirdParty-2.1.1 ThirdParty-2.1.1_real
ln -s ThirdParty-2.1.0 ThirdParty-2.1.1
Old   August 13, 2012, 17:29
Looks like GLIBCXX is missing.
$HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/blockMesh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/blockMesh)
$HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/blockMesh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/blockMesh)
$HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/blockMesh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libblockMesh.so)
$HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/blockMesh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libblockMesh.so)
$HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/blockMesh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libmeshTools.so)
$HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/blockMesh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libmeshTools.so)
$HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/blockMesh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libdynamicMesh.so)
$HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/blockMesh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libdynamicMesh.so)
$HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/blockMesh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so)
$HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/blockMesh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so)
$HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/blockMesh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libtriSurface.so)
$HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/blockMesh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libtriSurface.so)
$HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/blockMesh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so)
$HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/blockMesh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so)
$HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/blockMesh: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfileFormats.so)
        libblockMesh.so => $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libblockMesh.so (0x00002af24b456000)
        libmeshTools.so => $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libmeshTools.so (0x00002af24b68a000)
        libdynamicMesh.so => $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libdynamicMesh.so (0x00002af24bb14000)
        libOpenFOAM.so => $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so (0x00002af24c03d000)
        libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x0000003a6a200000)
        libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x0000003a69e00000)
        libtriSurface.so => $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libtriSurface.so (0x00002af24c79f000)
        libfiniteVolume.so => $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so (0x00002af24ca0f000)
        libPstream.so => $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so (0x00002af24dbf0000)
        libfileFormats.so => $HOME/centFOAM/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfileFormats.so (0x00002af24ddfa000)
        libmpi.so.1 => $HOME/centFOAM/OpenFOAM/ThirdParty-2.1.1/platforms/linux64Gcc/openmpi-1.5.3/lib/libmpi.so.1 (0x00002af24e002000)
Old   August 13, 2012, 17:44
Bruno Santos
OK, I'm guessing the GCC version used is different... try copying the GCC 4.6.2 build from 2.1.1 to 2.1.0:
cp -r $HOME/centFOAM/OpenFOAM/ThirdParty-2.1.1_real/platforms/linux64/gcc-4.6.2 $HOME/centFOAM/OpenFOAM/ThirdParty-2.1.0/platforms/linux64/gcc-4.6.2
If this doesn't work, check what GCC version OpenFOAM 2.1.0 is using:
ls -l   $HOME/centFOAM/OpenFOAM/ThirdParty-2.1.0/platforms/linux64/
You can remove the "gcc-4.6.2" and create a symbolic link to it, e.g.:
rm -r $HOME/centFOAM/OpenFOAM/ThirdParty-2.1.0/platforms/linux64/gcc-4.6.2
ln -s $HOME/centFOAM/OpenFOAM/ThirdParty-2.1.0/platforms/linux64/gcc-4.6.1   $HOME/centFOAM/OpenFOAM/ThirdParty-2.1.0/platforms/linux64/gcc-4.6.2
Old   August 13, 2012, 18:00
Why do we need to copy the GCC 4.6.2 build from 2.1.1 to 2.1.0, if we try to make 2.1.1 work?
2.1.0 is using gcc-4.6.2.
Thanks.
Old   August 14, 2012, 04:36
Bruno Santos
Because according to the other error message, the library "libstdc++.so" was not being found, which is located at GCC's lib folder.
This is why I was specifying the need for copying the other gcc version, because its folder was not being found and "/usr/lib64/libstdc++.so.6" is being picked up instead.
CentFOAM Python Script Installation: Error socon009 OpenFOAM Installation 2 May 26, 2012 09:36
Upgrade CPU or GPU which one is better RTAF Hardware 1 January 27, 2012 09:06
check wmake in CentFOAM pit OpenFOAM 12 November 24, 2010 16:59
CentFOAM updated/cleaned linnemann OpenFOAM Installation 0 June 1, 2010 15:40
Upgrade P4 1.5 to P4 2.6 JJJ FLUENT 3 May 29, 2004 10:30
