Compilation error with OF 2.1.x
Old   September 18, 2012, 06:29
Default Compilation error with OF 2.1.x
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
I tried to update my OpenFOAM 2.1.x so I typed
git pull
and then
./Allwmake
This way I updated my OpenFOAM 2.1.x several times since I installed it. It always worked, until now.
Unfortunately, the compilation produces some error messages and stops.
Some errors are about files which aren't found:
DataEntryFwd.H
MapDimensionedFields.H
ParticleTrap.H
and some errors are about "undefined reference"
Foam:olyMesh::clearAdditionalGeom()
Foam:ointMesh::typeName
Foam:olyMesh::movePoints()
After the unsuccessful compilation some commands, presumably those affected by the compilation errors, are not found anymore.
GerhardHolzinger is offline   Reply With Quote
Old   September 18, 2012, 07:29
Retired Super Moderator
Bruno Santos
Greetings Gerhard,
It's somewhat simple: new files were added to the main OpenFOAM library. The simplest fix is this:
src
wclean libso OpenFOAM
wmake libso OpenFOAM
When it finishes building, you can run Allwmake once again. Whenever you see that a library does this, you can perform steps similar to these.
Best regards,
Bruno
Old   September 18, 2012, 07:33
Gerhard Holzinger
Thanks for the reply.
In the mean time I found a bug report about my problem and there the same solution is explained.
I should have been googling a little longer before posting my problem here.
http://www.openfoam.org/mantisbt/view.php?id=626
EDIT: It is you who (wyldckat) who posted the solution in the bug report. The world is a small one.
Old   September 18, 2012, 08:02
Gerhard Holzinger
There is still the error about the missing file particleTrap.H
Old   September 18, 2012, 08:30
Bruno Santos
OK, this time it stopped on this command:
wmake libso intermediate
Since I don't know by heart the location of this library, this is what I would do:
src
find . -name intermediate
Then cd to the given folder and do:
wclean libso
wmake libso
Then back to Allwmake
Old   September 18, 2012, 09:04
Gerhard Holzinger
I did it the brute force way
wclean all
./Allwmake
It took a while, but now it is working again.
Compilation error for OpenFOAM-ext on Ubantu 10.04 32 bit Sargam05 OpenFOAM Installation 13 March 22, 2014 05:21
Compilation error with OpenFOAM 2.1.x Martin_ OpenFOAM Installation 28 January 15, 2013 06:58
Compilation problems OF 2.1.x ivan_cozza OpenFOAM Installation 8 March 23, 2012 09:31
Compilation Error (V 1.7.1; Icc 12.1.0, OpenMPI 1.4.3) floydfan OpenFOAM Installation 7 December 20, 2011 05:56
Compilation Error.... Arnab Siemens 4 September 12, 2004 15:54
