Trouble shooting about OpenFOAM installation in Ubuntu 12.04
Old   December 10, 2012, 21:23
Default Trouble shooting about OpenFOAM installation in Ubuntu 12.04
Huma Nait
Nait is on a distinguished road
I have tried to install OpenFOAM 2.1.x on Ubuntu 12.04 following the instruction on http://www.openfoam.org/download/git.php
However, when run the foamInstallationTest script, the following message shows:
Checking basic setup...
Shell: bash
Host: xutianhua-PC
OS: Linux version 3.2.0-34-generic-pae
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/xutianhua/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/xutianhua/OpenFOAM/xutianhua-2.1.x no no
$WM_THIRD_PARTY_DIR .../xutianhua/OpenFOAM/ThirdParty-2.1.x yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/xutianhua/OpenFOAM/OpenFOAM-2.1.x yes yes yes
$FOAM_APPBIN ...AM-2.1.x/platforms/linuxGccDPOpt/bin yes yes yes
$FOAM_SITE_APPBIN ...te/2.1.x/platforms/linuxGccDPOpt/bin no no
$FOAM_USER_APPBIN ...ua-2.1.x/platforms/linuxGccDPOpt/bin no no
$WM_DIR ...ianhua/OpenFOAM/OpenFOAM-2.1.x/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...AM-2.1.x/platforms/linuxGccDPOpt/lib yes yes yes
$FOAM_SITE_LIBBIN ...te/2.1.x/platforms/linuxGccDPOpt/lib no no
$FOAM_USER_LIBBIN ...ua-2.1.x/platforms/linuxGccDPOpt/lib no no
$MPI_ARCH_PATH ...1.x/platforms/linuxGcc/openmpi-1.5.3 yes yes yes
Third party software
Software Version Location
flex 2.5.35 /usr/bin/flex
./foamInstallationTest: 267: [: -lt: unexpected operator
./foamInstallationTest: 269: [: -gt: unexpected operator
./foamInstallationTest: 274: [: -lt: unexpected operator
./foamInstallationTest: 276: [: -gt: unexpected operator
./foamInstallationTest: 281: [: !=: unexpected operator
gcc /usr/bin/gcc
gzip 1.4 /bin/gzip
tar 1.26 /bin/tar
icoFoam
WARNING: Conflicting installations:
OpenFOAM settings : /home/xutianhua/OpenFOAM/OpenFOAM-2.1.x/platforms/linuxGccDPOpt/bin/icoFoam
current path :
CRITICAL ERROR
Summary
Base configuration ok.
The foam installation contains 1 critical error(s).
Review the output for warning messages and consult
the installation guide for troubleshooting.
Done
Then I run the ./Allwmake in the /src folder, the message in the attachment shows.
Then how can I solve the problem?
Thanks
Nait is offline   Reply With Quote
Old   December 12, 2012, 09:12
Retired Super Moderator
Bruno Santos
Greetings Huma Nait and welcome to the forum!
If I'm guessing this correctly, you have the Gold ld version installed by default, while OpenFOAM needs the BFD version of ld.
This has been already reported here: http://www.openfoam.org/mantisbt/view.php?id=685
The quickest solution is to uninstall the package "binutils-gold", rebuild OpenFOAM 2.1.x and after that install "binutils-gold" again.
Best regards,
Bruno
Old   December 12, 2012, 10:20
Huma Nait
Thanks to Bruno.
I have my unbuntu 12.04 reinstalled and the problems solved
Actually I suspect it is the influence of the ATI graphic card driver because I installed the driver before the installation of OF in my first try.
OpenFoam 2.0.0 installation Jan_Peters OpenFOAM Installation 86 April 27, 2012 05:32
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 12:38
OpenFOAM Installation Errors on Ubuntu 10.04 ozzythewise OpenFOAM Installation 1 June 19, 2010 05:59
Installation of OpenFOAM-1.6 on Ubuntu 9.10 marval OpenFOAM Installation 2 March 17, 2010 08:33
Trouble with installing OpenFOAM on Ubuntu Milos OpenFOAM Installation 16 November 16, 2009 02:44
