OpenFOAM-2.2.x failed to compile on OpenSUSE 12.3
Old   March 21, 2013, 04:49
Default OpenFOAM-2.2.x failed to compile on OpenSUSE 12.3
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
Dear OpenFOAMers,
I am wondering if anyone has compiled OpenFOAM-2.2.x successfully on OpenSUSE 12.3 64 bit?
I got the following errors. It will be appreciated if someone can shed some light on this.
Thanks!
Pei-Ying
make[1]: Leaving directory `/home/phsieh/OpenFOAM/ThirdParty-2.2.x/scotch_6.0.0/src/check'
rm -f ../bin/* ../include/* ../lib/*
Build Tecio
optional component was not found
Done ThirdParty Allwmake
+ wmakePrintBuild -check
same version as previous build
+ wmakeLnInclude OpenFOAM
wmakeLnInclude: linking include files to OpenFOAM/lnInclude
+ wmakeLnInclude OSspecific/POSIX
wmakeLnInclude: linking include files to OSspecific/POSIX/lnInclude
+ Pstream/Allwmake
+ wmake libso dummy
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file UPstream.C
Making dependency list for source file UIPread.C
Making dependency list for source file UOPwrite.C
SOURCE=UPstream.C ; wmakeScheduler g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -IlnInclude -I. -I/home/phsieh/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.2.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64Gcc46DPOpt/UPstream.o
SOURCE=UIPread.C ; wmakeScheduler g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -IlnInclude -I. -I/home/phsieh/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.2.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64Gcc46DPOpt/UIPread.o
SOURCE=UOPwrite.C ; wmakeScheduler g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -IlnInclude -I. -I/home/phsieh/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.2.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64Gcc46DPOpt/UOPwrite.o
ssh: connect to host jali port 22: No route to host
make: *** [Make/linux64Gcc46DPOpt/UIPread.o] Error 255
make: *** Waiting for unfinished jobs....
^C
phsieh2005 is offline   Reply With Quote
Old   March 24, 2013, 13:57
Retired Super Moderator
Bruno Santos
Greetings Pei-Ying,
The only error I can see is:
which is a very strange error... it looks like you had something running in the background using &, such as:
ssh jali &
which was probably launched before Allwmake.
As for:
Build Tecio
That's normal and not an error .
Best regards,
Bruno
Old   March 24, 2013, 15:32
Pei-Ying Hsieh
Hi, Bruno,
Thanks for the reply! You have been very kind to offer help, as always.
I have been fooling around the ssh stuffs in opensuse 12.3, but, no luck.
Both openFoam-2.1.x and 2.2.x compiled successfully on opensuse 12.2. But, both failed on opensuse 12.3 with the same issue. There is something different between opensuse 12.2 and 12.3.
Pei-Ying
Old   March 25, 2013, 16:08
Bruno Santos
Hi Pei-Ying,
I think I now understand what's going on! You're using "wmakeScheduler"!
I suggest that instead of using something like this:
export WM_SCHEDULER=wmakeScheduler
export WM_HOSTS="aaa:1 bbb:4"
export WM_NCOMPPROCS=$($WM_SCHEDULER -count)
export WM_COLOURS="black blue green cyan red magenta yellow"
You use only this:
export WM_NCOMPPROCS=4
This way you specify that you only want to use a single machine for compiling, but with 4 parallel processes!
______
In the mean time, try to diagnose if ssh works locally:
ssh localhost
And to the target machine, first check if it can be found:
ping jali
Additionally, I think that for using wmakeScheduler, you'll need to configure your ssh keys for being able to use a key based (and without password) connection to the trusted machines: https://help.ubuntu.com/community/SSH/OpenSSH/Keys
Best regards,
Bruno
Old   March 25, 2013, 18:18
Pei-Ying Hsieh
Thanks a lot Bruno!
You are an angel. You were correct. WM_SCHEDULER is the cause of the issue.
Pei-Ying
Transient boundary conditions Jarrod Sinclair (Sinclair) OpenFOAM Running, Solving & CFD 133 May 6, 2015 06:21
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Can anybody help me to solve the list errors while compiling Openfoam 15 on Opensuse 103 32bit coompressor OpenFOAM Installation 0 November 12, 2008 19:53
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
