May 16, 2013, 10:58 |
Inconsistency in gcc component versions
P.A.
Rep Power: 17 |
Hi Foamers,
I am trying to install OF2.2.x from the git source on CentOS6.4 64bit (from march 12th) in a virtual box container on an openSuSe12.3 host, for testing purposes. CentOS6.4 comes with a slightly outdated version of gcc (4.4.7) which is not sufficient for OF2.2.x. (Beside this, the cmake version from the CentOS repo is also way too old for the included ParaView). Anyway, I made my way through the essentials of the ThirdParty stuff, but got stuck in the OpenFOAM compilation because of an error with a "triad::... " class definition (which was already comprehensively commented on by wyldckat (thank you for that!) in http://www.cfd-online.com/Forums/ope...edhat-el5.html). I concluded I had to use a more recent version of gcc. So I run the makeGcc47 script in ThirdParty and had to download gcc and the well known additions with the following versions: gmp-5.0.2 mpfr-3.0.1 mpc-0.9 gcc-4.7.1 I had to add the configure option --disable-multilib in makeGcc47, and gcc-4.7.1 compiled. In OpenFOAM-2.2.x/etc/config/settings.sh I set foamCompiler=ThirdParty and export WM_COMPILER=Gcc47 However, when I run Allwmake in OpenFOAM-2.2.x with this newly compiled gcc-4.7.1, the script stops because gcc version 4.7.2 (not 4.7.1 as in the ThirdParty section) is expected due to the default settings in etc/config/settings.sh. Along with this, it also expects gmp_version=gmp-5.0.4 mpfr_version=mpfr-3.1.0 mpc_version=mpc-0.9 So the whole OF2.2.x package as drawn from the git repo needs 2 compilers? Am I the only one who runs into this inconsistency? Why is it there? As a solution I simply altered the version numbers in the respective section of settings.sh to the ones I have in ThirdParty, and everything seems to compile fine (still running). I hope someone can shed some light on this, and perhaps my findings may help someone else too. Best regards, Pascal. |
May 16, 2013, 17:19 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Pascal,
You can choose the version when building Gcc 4.7 like this: Code:
./makeGcc47 gcc-4.7.2 And since the makeGcc47 script allows for defining the version at runtime, they probably didn't bother changing the version number. And/or who made the package for the ThirdParty folder didn't have the latest scripts... Either way, you can report this at OpenFOAM's bug tracker: http://www.openfoam.org/mantisbt/my_view_page.php edit: By the way, this isn't the first time this happens... if you check the other "makeGcc*" scripts and compare to "settings.sh", you'll see that the versions don't always match up... Best regards, Bruno
Last edited by wyldckat; May 16, 2013 at 17:21. Reason: see "edit:" and changed "bashrc" to "settings.sh" |
May 17, 2013, 08:09 |
P.A.
Rep Power: 17 |
Hello Bruno,
thank you for the quick response! That makes things clearer. I must admit, I didn't look closely enough at the option parsing capability of makeGcc47. If I understand this right, one could circumvent the problems by giving the following options according to what is set for the respective gcc version in settings.sh? E.g. for gcc-4.7.2: ./makeGcc47 gmp-5.0.4 mpfr-3.1.0 mpc-0.9 gcc-4.7.2 That should do the trick, right? I will try to make my first bug report with this issue, as you recommended. Regards, Pascal. |
May 17, 2013, 17:37 |
#4 | |
Bruno Santos
Rep Power: 128 |
Hi Pascal,
Best regards, Bruno
Momentum source coefficient, cylindrical coordinates, circumferential component? | polakse | CFX | 15 | January 18, 2016 02:40 |
Patches for OpenFOAM 1.7 on MacOS X | gschaider | OpenFOAM Installation | 101 | September 21, 2011 05:37 |
Gerris software installation | mer | Main CFD Forum | 2 | November 12, 2005 08:50 |
Diffusion component at inlet | Balaji | FLUENT | 2 | August 8, 2005 07:37 |
UDF component in Cyliderical Velocity? | Hongchan Kim | FLUENT | 3 | April 24, 2001 12:20 |
