[Mac OS X] unfortunate old PATCH of 2.1 in 2.2 ?
Old   May 18, 2013, 17:47
Default [Mac OS X] unfortunate old PATCH of 2.1 in 2.2 ?
FERRASSE
feras is on a distinguished road
All right I am a ro
I do the install as described in:
http://openfoamwiki.net/index.php/Ho...enFOAM_v21_Mac
but the link is now to 2.2 and not 2.1...
So I did the patch thing and I saw the mistake after....
Do you think it is a big problem or not?
feras is offline   Reply With Quote
Old   May 18, 2013, 18:34
Retired Super Moderator
Bruno Santos
Greetings Ferrasse and welcome to the forum!
As I mentioned in the email I had sent to you a few minutes ago, the correct patches for OpenFOAM 2.2.0 on Mac are provided on this thread: http://www.cfd-online.com/Forums/ope...-mac-os-x.html
It might work if you use the patches from 2.1 on 2.2, but I think Bernhard did some more necessary changes to the patches for them to work on OpenFOAM 2.2.
Best regards,
Bruno
Old   May 20, 2013, 10:05
Assistant Moderator
Bernhard Gschaider
The old patches might work but not all solvers will be compiled (and there are some improvements in the new patch concerning the selection of the MPI-implementation)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 11:25
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 02:34
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
