2.3.0 on fedora 19 problem
Like Tree2Likes
  • 1 Post By JonW
  • 1 Post By wyldckat
Old   February 21, 2014, 12:16
Default 2.3.0 on fedora 19 problem
Lucas Giger
luc.gig is on a distinguished road
I've got a problem downloading and installing the new verison on fedora 19..
[lucas@localhost ~]$ sudo rpm -i http://www.openfoam.org/download/fed...0-1.x86_64.rpm
curl: (22) The requested URL returned error: 404 Not Found
Fehler: überspringe http://www.openfoam.org/download/fed...0-1.x86_64.rpm - Übertragung fehlgeschlagen
somehow the link can't be found..
luc.gig is offline   Reply With Quote
Old   February 21, 2014, 16:06
Retired Super Moderator
Bruno Santos
Greetings Lucas and welcome to the forum!
Fedora is not officially supported in the latest OpenFOAM 2.3.0 release, as exemplified in the main download page: http://www.openfoam.org/download/ - and shown in the release notes: http://www.openfoam.org/version2.3.0/
They've replaced the respective support from Fedora to RHEL 6.x.
I don't known if they will ever have support for Fedora once again, but I've already reported that the menu link and page for Fedora is still hanging around: http://www.openfoam.org/mantisbt/view.php?id=1165
I won't have much time in the near future to write instructions on how to build OpenFOAM 2.3.0 on Fedora, but you can use the following instructions as a base reference: http://openfoamwiki.net/index.php/In...M-2.2.2/Fedora
Best regards,
Bruno
Old   February 23, 2014, 15:59
Jon Elvar Wallevik
JonW will become famous soon enough
Hi Bruno and Lucas
Your method Bruno, works fine for the 2.3.x on Fedora 20 - 64 bit.
For the paraview, I did almost as recommended for RHEL at http://www.openfoam.org/download/git.php
I did
cd $WM_THIRD_PARTY_DIR
./makeParaView4 -qmake $(which qmake-qt4)
cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers
wmSET
./Allwclean
./Allwmake
Doing the following
"export Paraview_VERSION=3.12.0" and
"./makeParaView -qmake $(which qmake-qt4)"
didn't go so well...
cheers
Jon
wyldckat likes this.
JonW is offline   Reply With Quote
Old   March 1, 2014, 18:58
Bruno Santos
Greetings Jon,
Many thanks for sharing your experience!
By the way, today I've finally written and tested the installation instructions for OpenFOAM 2.3.0 on Fedora 20: http://openfoamwiki.net/index.php/In...dora#Fedora_20
Best regards,
Bruno
JonW likes this.
conduction problem venkataramana OpenFOAM 3 December 1, 2013 07:30
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
FEDORA CORE and PARALLEL processing Tuks CFX 2 August 20, 2005 11:05
