I cant find openfoam for ubuntu 14.04 LTS
Like Tree1Likes
  • 1 Post By upender
Old   April 30, 2014, 09:46
Default I cant find openfoam for ubuntu 14.04 LTS
sajad
seju is on a distinguished road
Dear Foamer
I wanna install openFoam in ubuntu 14.04 LTS but this package doesn't exist in [HTML]http://www.openfoam.org/download/ubuntu.php [/HTML. I hurry up for install openfoam. do you have any Idea or news about install openfoam in ubuntu 14.04 LTS?
best regards
Sajad
seju is offline   Reply With Quote
Old   April 30, 2014, 11:44
blacksquirrel is on a distinguished road
openfoam-2.3.0 for Ubuntu 14.04:
http://openfoamwiki.net/index.php/In...M-2.3.0/Ubuntu
blacksquirrel is offline   Reply With Quote
Old   April 30, 2014, 11:57
sajad
Originally Posted by blacksquirrel View Post
thanks for reply Mr. I wanna install openfoam 2.2.1 Im so sorry. I forgot said that
best regards
Sajad
Old   April 30, 2014, 13:16
Retired Super Moderator
Bruno Santos
Greetings to all!
@seju:
You'll have to install from source code, as blacksquirrel implied.
Since you're trying to use Ubuntu 14.04, which is very similar to Ubuntu 13.10 when it comes to building OpenFOAM from source code, therefore you should be able to follow these instructions that are means for Ubuntu 13.10: http://openfoamwiki.net/index.php/In...u#Ubuntu_13.10
Best regards,
Bruno
Old   May 12, 2014, 03:36
Default Check up
Gareth
bullmut is on a distinguished road
Hi Foamers,
So i am installing OF@#) on my pc, which has ubuntu 14 on it.
I followed the instructions as per this thread.
I could not attach the full tar ball of my make.log, so edited the error sections, if you need the full file that can be arranged. To continue..
I have a few questions - :
1) Should i move the OpenFOAM folder as is to /opt/ ? Does this affect functionality or dependicies?
2) The only error i found in the log1 was that paraView was not present but this step was done later.. does it matter?
3) The metis option was not present when i made the third part folder. Again is this a problem, can i resolve it later or now?
Thanks in advance guys
File Type: gz make.log2.tar.gz (879 Bytes, 4 views)
bullmut is offline   Reply With Quote
Old   May 12, 2014, 15:33
Bruno Santos
Greetings Gareth,
There is no particular big error indicated in the log file you provided. The last error is fixed if you continue following the instructions... or at least it should.
Keep in mind that it's the first error message that will likely indicate what went wrong.
As for your questions:
  1. Placing OpenFOAM at "/opt" is only useful if you share the machine with other people and those people need access to OpenFOAM.
  2. As indicated above, just continue following the instructions.
  3. Metis is optional and is not a strict necessity. This is because Scotch is installed by default.
Best regards,
Bruno
Old   August 27, 2014, 05:27
Question error at source command
upender singh
upender is on a distinguished road
i am following the instructions at http://openfoamwiki.net/index.php/In...M-2.3.0/Ubuntu.
at first, every thing goes well.
but the moment i type
source $HOME/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc WM_NCOMPPROCS=4 WM_MPLIB=SYSTEMOPENMPI
it gives me an error like:
bash: /home/upender/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc: No such file or directory
please help
upender is offline   Reply With Quote
Old   August 27, 2014, 05:33
Gareth
HI upender
Have you checked that the OpenFoam directory is located in the right place?
At step 4 were you in your home folder?
"cd ~"
Old   August 27, 2014, 05:48
upender singh
hi bullmut
yes i was in my home folder then
i have checked the entries in the gui
the home/openfoam/openfoam-230/etc exists
In the etc folder, i do not have a bashrc subfolder.
but a bashrc file exists
Old   August 27, 2014, 06:03
Gareth
The baschrc is not a folder but a file, when you extracted the tgz file it should have been uncompressed along with everything else...
If that is not the case you can try a different repository
http://www.openfoam.org/download/git.php
Old   August 27, 2014, 06:08
upender singh
yes the file exists
but i cant understand y that error occured
Old   August 27, 2014, 06:14
Gareth
gosh i just saw your reply
"home/openfoam/openfoam-230/etc exists"
where as when you tried "source $HOME..." it was looking for "/home/upender/OpenFOAM/..."
The variable $HOME is sending it to the wrong place..
You should redefine that variable accordingly.. the location or file structure of your setup needs to match the variables in your environment else it will be looking in the wrong place.
I suggest you check those environment variables before you continue as they are used later during installation
Old   August 27, 2014, 06:28
upender singh
i just checked the variable
HOME=/home/upender
now, since i am new to linux, i dont really know how to sort this out.
ive been mugging with this since last night.
please help
Old   August 27, 2014, 13:18
upender singh
my previous problem is solved. i have somehow reached to step 10,ie, building open foam.
when i type
./Allwmake > make.log 2>&1
it says: Permission denied.
then i used
sudo chmod -R o+w $WM_PROJECT_DIR
and retyped
the log was generated but in a few seconds.
i tried to read it and it says permission denied every where
i have attached the log file for reference purpose.
please help
Old   August 30, 2014, 11:47
Bruno Santos
Greetings to all!
@upender: The error message you are getting appears all over the log file you provided. It seems to me that you were not able to follow with precision the installation instructions, and you possibly did not exit from root mode when you should have. But it's only an hypothesis.
You can try the following command, which hopefully will fix the problem:
sudo chown -R $USER:$USER $FOAM_INST_DIR
This will change the ownership of the whole OpenFOAM installation to your own user name, therefore allowing you to access the missing file.
If this still doesn't work, I strongly suggest that you start following again the instructions from the start, and be very careful to not miss any step/detail at all.
This of course implies that before you do this, you at least rename the main "OpenFOAM" folder, for example, by running:
mv $HOME/OpenFOAM $HOME/OpenFOAM.1st_try
Best regards,
Bruno
Old   August 30, 2014, 12:07
upender singh
hi Bruno
i found out something called gksu nautilus on ubuntu forums
i changed all permissions of this directory, built OpenFOAM successfully, and restored the permissions.
anyways, thank you for your reply.
your information is always valuable at some point.
wyldckat likes this.
OpenFOAM 2.2.0 and 2.1.0 side by side errors Neraste OpenFOAM Installation 2 June 12, 2013 04:55
OpenFOAM Training in Europe and USA hjasak OpenFOAM 0 August 8, 2008 05:33
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
OpenFOAM installation problem on Linux 32bit kumar OpenFOAM Installation 0 April 27, 2007 05:41
