[OpenFOAM.org] Paraview not found when installing OpenFoam to Ubuntu 14.04 |
May 29, 2014, 23:29 |
Riccardo
Rep Power: 11 |
Hi, It's now a while that I try to install Openfoam to Ubuntu 14.04 LTS 64bit. I followed precisely the instructions in here: http://openfoamwiki.net/index.php/In...u#Ubuntu_14.04
Now everything goes fine until step 9 of the process where the make.log reports the one and only error: Code:
ERROR: ParaView not found in /home/riccardo/OpenFOAM/ThirdParty-2.3.0/platforms/linux64Gcc/ParaView-4.1.0 Any hint on how to get this resolved? thank you Last edited by tabsquare; May 30, 2014 at 11:26. Reason: Removed unnecessary infos |
May 31, 2014, 13:17 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Riccardo and welcome to the forum!
This is either the 2nd or 3rd time that someone spots that error message during the build of OpenFOAM. I'll have to change the instructions on the wiki to build ParaView before OpenFOAM. Please run these commands: Code:
cd $WM_THIRD_PARTY_DIR ./makeParaView4 -qmake $(which qmake-qt4) > log.makePV 2>&1 I ask this because I haven't been able to reproduce the same error when following those instructions on Ubuntu 14.04 edit: I've updated the instructions on the wiki, so the numbering of the steps is now different! The old #11 is now #9 and the old #9 is now #10 Best regards, Bruno
May 31, 2014, 21:49 |
Riccardo
Rep Power: 11 |
Thank you! I'll try to follow what you suggested as soon as I can! The best I could do for the moment is to run ParaFoam with the -builtin option and this works acceptably well. I don't know however what the the difference should be...
June 1, 2014, 21:56 |
Riccardo
Rep Power: 11 |
I tried the new installation workflow but unfortunatly I still end up with the same error when I try running paraFoam, namely:
riccardo@riccardo-K53SV:~/OpenFOAM/riccardo-2.3.0/run/tutorials/incompressible/icoFoam/cavity$ paraFoam FATAL ERROR: ParaView reader module libraries do not exist Please build the reader module before continuing: cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers ./Allwclean ./Allwmake Code:
[ 44%] Building CXX object VTK/Rendering/Core/CMakeFiles/vtkRenderingCore.dir/vtkDataSetMapper.cxx.o Scanning dependencies of target vtkIOXdmf2CS In file included from /usr/local/cuda/include/cuda_runtime.h:59:0, from <command-line>:0: /usr/local/cuda/include/host_config.h:82:2: error: #error -- unsupported GNU version! gcc 4.5 and up are not supported! #error -- unsupported GNU version! gcc 4.5 and up are not supported! ^ [ 44%] Building CXX object Wrapping/ClientServer/CMakeFiles/vtkIOXdmf2CS.dir/vtkSILBuilderClientServer.cxx.o [ 44%] Building CXX object Wrapping/ClientServer/CMakeFiles/vtkFiltersModelingCS.dir/vtkRibbonFilterClientServer.cxx.o CMake Error at cuda_compile_generated_CUDAConvolutionDriver.cu.o.cmake:206 (message): Error generating /home/riccardo/OpenFOAM/ThirdParty-2.3.0/build/linux64Gcc/ParaView-4.1.0/Plugins/SciberQuestToolKit/SciberQuest/CMakeFiles/cuda_compile.dir//./cuda_compile_generated_CUDAConvolutionDriver.cu.o make[2]: *** [Plugins/SciberQuestToolKit/SciberQuest/CMakeFiles/cuda_compile.dir/./cuda_compile_generated_CUDAConvolutionDriver.cu.o] Error 1 make[1]: *** [Plugins/SciberQuestToolKit/SciberQuest/CMakeFiles/vtkSciberQuest.dir/all] Error 2 make[1]: *** Waiting for unfinished jobs.... Code:
[ 97%] Building NVCC (Device) object Plugins/SciberQuestToolKit/SciberQuest/CMakeFiles/cuda_compile.dir//./cuda_compile_generated_CUDAConvolutionDriver.cu.o In file included from /usr/local/cuda/include/cuda_runtime.h:59:0, from <command-line>:0: /usr/local/cuda/include/host_config.h:82:2: error: #error -- unsupported GNU version! gcc 4.5 and up are not supported! #error -- unsupported GNU version! gcc 4.5 and up are not supported! ^ CMake Error at cuda_compile_generated_CUDAConvolutionDriver.cu.o.cmake:206 (message): Error generating /home/riccardo/OpenFOAM/ThirdParty-2.3.0/build/linux64Gcc/ParaView-4.1.0/Plugins/SciberQuestToolKit/SciberQuest/CMakeFiles/cuda_compile.dir//./cuda_compile_generated_CUDAConvolutionDriver.cu.o make[2]: *** [Plugins/SciberQuestToolKit/SciberQuest/CMakeFiles/cuda_compile.dir/./cuda_compile_generated_CUDAConvolutionDriver.cu.o] Error 1 make[1]: *** [Plugins/SciberQuestToolKit/SciberQuest/CMakeFiles/vtkSciberQuest.dir/all] Error 2 make: *** [all] Error 2 --- Installation complete for paraview-4.1.0 |
June 2, 2014, 05:45 |
Rep Power: 12 |
I had the same problem as tabsquare after I switched to 14.04. I have therefore been using an independent ParaView installation - I would just create an empty document in the case folder named view.foam, and that would allow me to load things in ParaView. However, when doing multiphase examples, the different phases and their interface are not shown in ParaView if I proceed as described above. In an earlier installation where paraFoam worked, this was not the case. Does anyone know why?
June 2, 2014, 15:35 |
Bruno Santos
Rep Power: 128 |
Greetings to all!
@Riccardo: Many thanks for the log file! Now it's very clear what the problem is... and I have to point the finger at CUDA for being such a pain in the #$"!$$"#% This issue was detected some time ago and the possible solutions can be found here: http://www.cfd-online.com/Forums/ope...on-driver.html Assuming you don't need CUDA, please follow these steps: Code:
cd $WM_THIRD_PARTY_DIR sed -i -e 's=CUDA_FOUND=OFF=g' ParaView-4.1.0/Plugins/SciberQuestToolKit/SciberQuest/CMakeLists.txt ./makeParaView4 -qmake $(which qmake-qt4) > log.makePV 2>&1 And if it does, then run: Code:
cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers wmSET $FOAM_SETTINGS ./Allwclean ./Allwmake Bruno
June 2, 2014, 17:00 |
Riccardo
Rep Power: 11 |
Hello Bruno! I'm happy , this worked great as I don't have to use CUDA ParaFoam interface as it is now, appears to have more options than what I could see when using the builtin option (maybe just an impression).
I really appreciate the help, hopefully this will be a valuable info for others too! Thank you very much! Last edited by tabsquare; June 2, 2014 at 22:29. |
June 7, 2014, 09:06 |
Rep Power: 12 |
Thanks for the support wyldckat! My own problem, however, seems to be of a different kind than tabsquare's. The following parts from my log file seem noteworthy:
[ 4%] Building CXX object ThirdParty/QtTesting/vtkqttesting/CMakeFiles/QtTesting.dir/moc_pqWidgetEventTranslator.cxx.o Linking C shared library ../../../../lib/libvtklibxml2-pv4.1.so [ 4%] Built target vtklibxml2 Linking CXX shared library ../../../lib/libQtTesting.so [ 4%] Built target QtTesting make: *** [all] Error 2 Command exited with non-zero status 2 258.06user 14.59system 0:37.62elapsed 724%CPU (0avgtext+0avgdata 197300maxresident)k 63136inputs+126688outputs (58major+5923131minor)pagefaults 0swaps Done make Installing ParaView to /home/nc2613/OpenFOAM/ThirdParty-2.3.0/platforms/linux64Gcc/ParaView-4.1.0 [ 0%] Built target vtksys [ 0%] Generating vtkUnicodeCaseFoldData.h ... Code:
[ 92%] Compiling Qt help project PacMan.qhp qhelpgenerator: could not exec '/usr/lib/x86_64-linux-gnu/qt5/bin/qhelpgenerator': No such file or directory make[2]: *** [Plugins/TestPlugin/doc/PacMan.qch] Error 1 make[1]: *** [Plugins/TestPlugin/CMakeFiles/PacMan.dir/all] Error 2 make: *** [all] Error 2 --- Installation complete for paraview-4.1.0 Set environment variables: export ParaView_DIR=/home/nc2613/OpenFOAM/ThirdParty-2.3.0/platforms/linux64Gcc/ParaView-4.1.0 export PATH=$ParaView_DIR/bin:$PATH export PV_PLUGIN_PATH=$FOAM_LIBBIN/paraview-4.1 --- Done Regards, N Last edited by wyldckat; June 7, 2014 at 10:09. Reason: Added [CODE][/CODE] |
June 7, 2014, 10:14 |
Bruno Santos
Rep Power: 128 |
Hi Nikolac,
The problem in your case seems to be because the Qt5 installation is getting in the way of the building process. Specifically, this path: Code:
/usr/lib/x86_64-linux-gnu/qt5/ This is very strange, because if you used this command line: Code:
./makeParaView4 -qmake $(which qmake-qt4) > log.makePV 2>&1 Was there anything that you did specifically for installing and/or using Qt5? Best regards, Bruno
June 7, 2014, 11:06 |
Rep Power: 12 |
It baffles me too! I have used precisely this command with $(which qmake-qt4). I did not knowingly install or configure Qt5, I believe it must have come with the upgrade to 14.04. I have all the necessary Qt4 software installed, as described in your guide.
June 8, 2014, 11:34 |
#11 |
Bruno Santos
Rep Power: 128 |
Hi Nikolac,
OK, I've figured it out. As of Ubuntu 13.04, most Qt building-related applications now rely on "qtchooser" for selecting the Qt version we want for building our Qt-based applications. I've updated the wiki page accordingly: http://openfoamwiki.net/index.php/In...u#Ubuntu_14.04 The main difference is that we have to run the following command before we build ParaView and the OpenFOAM plugins for ParaView: Code:
export QT_SELECT=qt4 Best regards, Bruno
June 10, 2014, 05:47 |
#12 |
Rep Power: 12 |
Dear Bruno,
Thanks a lot, this worked like a charm! Regards, N |
August 21, 2014, 01:17 |
#13 |
Abhijit
Rep Power: 11 |
Hi ,
I tried installing OpenFOAM 2.3.0 on ubuntu 14.04. I was not able to install paraFoam4.1.0 properly. There was a cmake 2.8.8 or higher version requirement and i had cmake 2.8.7, i tried installing and compiling cmake version 2.8.12.1 but was unsuccessful. This was the error shown when i run paraFoam for the cavity case. Code:
FATAL ERROR: ParaView reader module libraries do not exist Please build the reader module before continuing: cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers ./Allwclean ./Allwmake Thanks |
August 30, 2014, 10:42 |
#14 |
Bruno Santos
Rep Power: 128 |
Greetings Jetfire,
Are you 100% certain that you are using Ubuntu 14.04? Because it's Ubuntu 12.04 that comes with CMake 2.8.7! Instructions for building OpenFOAM 2.3.0 on Ubuntu 12.04 are given here: http://openfoamwiki.net/index.php/In...u#Ubuntu_12.04 If you still have problems using the correct CMake version, please check the instructions given here: http://openfoamwiki.net/index.php/FA...7s_going_on.3F Best regards, Bruno
September 2, 2014, 00:26 |
#15 |
Abhijit
Rep Power: 11 |
@wyldckat
Thanks for your reply. I checked my version it's 12.04!. Installed OF 2.3.0 and paraFoam 4.1.0 successfully and they are running fine. |
September 28, 2014, 05:06 |
build order
#16 |
Alessandro
Hello wyldckat,
and thank you very much for all your great help in building OF and ParaView! I am following your instructions for a fresh build of OF-2.3.x on Mint 17, but please note that you cannot build ThirdParty folder as first, because you need wmake scripts as a prerequisite. When I attempted a pretty fresh build of ThirdParty I ended with: Code:
./Allwmake: 34: ./Allwmake: wmakeCheckPwd: not found Error: Current directory is not $WM_THIRD_PARTY_DIR The environment variables are inconsistent with the installation. Check the OpenFOAM entries in your dot-files and source them. Alex |
September 28, 2014, 05:40 |
#17 | |
Bruno Santos
Rep Power: 128 |
Greetings Alex,
The reason why I wrote that the ThirdParty folder should be first built is in the description of the respective step: Quote:
As for the error message you got, I believe the problem was that you hadn't updated the shell environment properly yet, because wmakeCheckPwd is a shell script and not a binary application like wmkdep. By the way, Mint 17 is based on which Ubuntu version? Best regards, Bruno |
September 28, 2014, 08:58 |
#18 |
Alessandro
Wow Bruno,
I must confess that I didn't expect such a fast reply! Thanks again. Well, I will detail my situation which is bit involved... I am trying to install 2.3.x in /opt/OpenFOAM/ on Mint 17, that is based on Ubuntu 14.04. So I tried to manage this by setting FOAM_INST_DIR as in the official instructions page and then by sourcing /etc/bashrc file. Then I tried step 8 from your wiki guide, ending with the problem above, i.e., Allwmake not finding the script. (Yes -sorry- it is a script!) So I tried to build OF first and everything in the log file seems good. I gave a try to foamInstallationTest which tells me that the environment variables FOAM_SITE_APPBIN, FOAM_USER_APPBIN, FOAM_SITE_LIBBIN, FOAM_USER_LIBBIN are not valid yet... I'll wait for your suggestions! Regards, Alex |
September 28, 2014, 09:08 |
#19 |
Bruno Santos
Rep Power: 128 |
Hi Alex,
You got really lucky today... I'm skimming through the forum threads while the computer is running some meshing tests... I wouldn't do so if my machine was quicker Quick answer to your question: http://openfoamwiki.net/index.php/In...with_the_Shell Not so quick answer:
Bruno |
September 28, 2014, 09:37 |
#20 |
Alessandro
Well Bruno,
if this is my lucky Sunday I will take advantage of this as much as I can! Sorry, but while you were typing your answer I couldn't wait any longer ...and I just tried to build again ThirdParty folder and then ParaView 4.1.0 as you suggested. Unfortunately PV build is stuck with some errors complaining about a lacking fortran compiler... which is pretty strange! Do I need it? I think I will end up with my naive attempt at installing directly in /opt/ and try to follow your advice of local building everything in $HOME and then moving it wherever I like. At least I could experiment a little without much concerns! Thanks again! Alex By the way: hope testing went well. Usually Sunday-testing is fine. |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
[OpenFOAM.org] Using OpenFOAM 2.3.0 from Deb pack in Ubuntu 14.04 + ParaView 5 from OpenFOAM 4.1 | ad2eb | OpenFOAM Installation | 12 | May 28, 2017 14:30 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
[OpenFOAM.org] (Script)OpenFOAM 2.3.0 and Paraview for Ubuntu 14.04 | p0kerus | OpenFOAM Installation | 2 | December 2, 2014 07:54 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
