foam-extend-3.1
Old   July 9, 2014, 08:03
Default foam-extend-3.1
Ashwani
AshwaniAssam is on a distinguished road
While trying to compile foam-extend-3.1 following the instruction given in doc/buildInstructions/Ubuntu/Ubuntu_14.04, most of the solvers got compliled. For dbns dolver under compressible flow, I am getting following error.
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -I/home/ashwani/foam/foam-extend-3.1/src/finiteVolume/lnInclude -I/home/ashwani/foam/foam-extend-3.1/src/thermophysicalModels/basic/lnInclude -I/home/ashwani/foam/foam-extend-3.1/src/thermophysicalModels/specie/lnInclude -I/home/ashwani/foam/foam-extend-3.1/src/turbulenceModels/compressible/turbulenceModel -I/home/ashwani/foam/foam-extend-3.1/src/dbns/lnInclude -IlnInclude -I. -I/home/ashwani/foam/foam-extend-3.1/src/foam/lnInclude -I/home/ashwani/foam/foam-extend-3.1/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/dbnsTurbFoam.o -L/home/ashwani/foam/foam-extend-3.1/lib/linux64GccDPOpt \
-lfiniteVolume -lbasicThermophysicalModels -lspecie -lcompressibleTurbulenceModel -lcompressibleRASModels -lcompressibleLESModels -ldbns -lfoam -liberty -ldl -lrt -lm -o /home/ashwani/foam/foam-extend-3.1/applications/bin/linux64GccDPOpt/dbnsTurbFoam
/usr/bin/ld: cannot find -ldbns
collect2: error: ld returned 1 exit status
When I ran ./foamInstallationTest I got the following error:
Executing ./foamInstallationTest:
Checking basic setup...
Shell: bash
Host: ashwani-Lenovo-E4430
OS: Linux version 3.13.0-30-generic
Checking main foam-extend env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/ashwani/foam yes yes
$WM_PROJECT_USER_DIR /home/ashwani/foam/ashwani-3.1 no no
$WM_THIRD_PARTY_DIR ...wani/foam/foam-extend-3.1/ThirdParty yes yes
Checking the foam-extend env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/ashwani/foam/foam-extend-3.1 yes yes yes
$FOAM_APPBIN ...3.1/applications/bin/linux64GccDPOpt no yes
$FOAM_SITE_APPBIN ...ni/foam/site/3.1/bin/linux64GccDPOpt no no
$FOAM_USER_APPBIN ...3.1/applications/bin/linux64GccDPOpt no no
$WM_DIR /home/ashwani/foam/foam-extend-3.1/wmake yes yes yes
Checking the foam-extend env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN .../foam-extend-3.1/lib/linux64GccDPOpt no yes
$FOAM_SITE_LIBBIN ...ni/foam/site/3.1/lib/linux64GccDPOpt no no
$FOAM_USER_LIBBIN ...foam/ashwani-3.1/lib/linux64GccDPOpt no no
$MPI_ARCH_PATH /usr yes no yes
Third party software
Software Version Location
WARNING: gcc version does not match gcc supplied with this release of foam-extend
Supplied version: 4.3.3
User version : 4.8.2
Minimum required: 4.3.1
gcc 4.8.2
WARNING: Conflicting installations:
foam-extend settings : /bin/gcc
current path : /usr/bin/gcc
CRITICAL ERROR
gzip 1.6 /bin/gzip
tar 1.27.1 /bin/tar
icoFoam
foam-extend settings : /home/ashwani/foam/foam-extend-3.1/applications/bin/linux64GccDPOpt/icoFoam
current path :
CRITICAL ERROR
Summary
Base configuration ok.
The foam installation contains 2 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
done.
Can anyone please help. I have OpenFOAM 2.3.0 also installed via source on the same machine. And I using aliases to switch between the two. I am able to run other solvers within foam-extend-3-1.
AshwaniAssam is offline   Reply With Quote
Old   July 15, 2014, 07:30
Jens
jensi_t is on a distinguished road
Hi Ashwani,
i've a similar problem with dbns on a sles cluster. I didn't solve it yet but i think that it has s.th. to do with the ThirdParty applications. Some of them create libraries in the usr/bin/ directory by default which needs root permission. E.g. for mesquite I tried to change the prefix as I don't have root access. It didn't help..
For you perhaps compiling ThirdParty as root helps.
If you or someone else found the answer please post it as fast as possible .
Thank you,
Jens
jensi_t is offline   Reply With Quote
Old   July 23, 2014, 08:59
Jens
i still didn't solve the problem. ext 3.1 works on my local suse(gcc4.8.1) machine so perhaps the compiler i use is too old (gcc 4.5.0). DId you try to update it? When I compile the src/dbns libraries I got the following error:
ThirdParty/packages/ParMGridGen-1.0/platforms/linux64GccDPOpt/lib/libMGridGen.so: undefined reference to `memcpy@GLIBC_2.14'
A colleague said that this also indicates a gcc problem.
Hope someone can help us.
Cheers,
Jens
Old   August 1, 2014, 08:02
Jens
Hey guys,
this is my last try. Does anybody know why ParMGridGen is asking for GLIBC_2.14. I successfully compiled fe31 on an CentOS 6.3 cluster where
ldd --version gives ldd (GNU libc) 2.12
so 2.14 shouldn't be required (SLES System has 2.11.1).
Thanks for your help!
Jens
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
