[OpenFOAM.org] wmake libso fails on Mac 10.10
Old   June 20, 2015, 12:31
Default wmake libso fails on Mac 10.10
Jack
Jack001 is on a distinguished road
I am trying to compile a turbulence model as a library using
wmake libso
however I get the following error readout:
SOURCE=gammaReThetatSST/gammaReThetatSST.C ;  mpicxx -m64 -fsignaling-nans  -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2  -DNoRepository -ftemplate-depth-100 -I/Users/oscarwilsby/OpenFOAM/OpenFOAM-2.3.x/src/turbulenceModels -I/Users/ow222/OpenFOAM/OpenFOAM-2.3.x/src/transportModels -I/Users/ow222/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/Users/ow222/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I/Users/ow222/OpenFOAM/OpenFOAM-2.3.x/src/turbulenceModels/incompressible/RAS/lnInclude -IlnInclude -I. -I/Users/ow222/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/ow222/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64GccDPOpt/gammaReThetatSST.o
dyld: Library not loaded: /usr/local/Cellar/open-mpi/1.8.4/lib/libopen-pal.6.dylib
  Referenced from: /usr/local/bin/mpicxx
  Reason: Incompatible library version: mpicxx requires version 9.0.0 or later, but libopen-pal.6.dylib provides version 8.0.0
/bin/sh: line 1: 50563 Trace/BPT trap: 5       mpicxx -m64 -fsignaling-nans -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -DNoRepository -ftemplate-depth-100 -I/Users/ow222/OpenFOAM/OpenFOAM-2.3.x/src/turbulenceModels -I/Users/ow222/OpenFOAM/OpenFOAM-2.3.x/src/transportModels -I/Users/ow222/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/Users/ow222/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I/Users/ow222/OpenFOAM/OpenFOAM-2.3.x/src/turbulenceModels/incompressible/RAS/lnInclude -IlnInclude -I. -I/Users/ow222/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/Users/ow222/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64GccDPOpt/gammaReThetatSST.o
make: *** [Make/darwinIntel64GccDPOpt/gammaReThetatSST.o] Error 133
So the problem seems to be with my version of some kind of library that mpicxx uses? I have no idea where to start with this problem so any help would be much appreciated!
Jack001 is offline   Reply With Quote
Patches for OpenFOAM 1.7 on MacOS X gschaider OpenFOAM Installation 101 September 21, 2011 05:37
OpenFoam 1.6-ext - error ./Allwmake in /src preibie OpenFOAM Installation 14 June 14, 2011 05:57
Problems Installing OF 1.6 32 bit bucksfan OpenFOAM Installation 19 August 4, 2009 01:36
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 04:41
[OpenFOAM] ParaFoam error message joey ParaView 1 October 2, 2006 13:28
