November 6, 2015, 06:59 |
OpenFOAM 1.6-ext
London (United Kingdom)
Rep Power: 10 |
Hi, hopefully someone can help me or redirect me to the right place.
To outline my problem. I work with a cloud provider and a client has asked us to create a cluster with an OpenFOAM 1.6-ext deployment. To my understanding that it has to be this version due to an extension they are using. For various reasons ive been forced to use IntelMPI rather than OpenMPI, and have searched for a nice simple outline of how to build OpenFOAM with this in mind (ive never used OpenFOAM before, thats not my skillbase..) I found this resource http://www.hpcadvisorycouncil.com/pd..._Practices.pdf I modified the settings.sh and bashrc files as described, but the build just fails.. If someone is able point me in the right direction i would be grateful (if this is just plain not possible that would be very useful info too) Thanks Last edited by DavidCrossland; November 6, 2015 at 08:24. |
November 7, 2015, 05:18 |
Hrvoje Jasak
Rep Power: 33 |
Hi David,
I have just tried to build 1.6-ext on our Ubunru machine and it works without problems. The most sensitive place is third party so I would advise you to build is stage-by-stage and see where the problem is. I have 2 alternatives: - if you really cannot build,Wikk can provide a custom binary pack for you - you could spark to your client and have us upgrade the feature which is stopping them form following version upgrades. With foam-extend-3.2 this will be easy Good luck, Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
November 7, 2015, 11:23 |
Rep Power: 10 |
Hi, thanks for taking a look into this. We have previously built this on ubuntu, well a colleague did so. My problems is building it on SLES 12 against IntelMPI. I see in subsequent releases this is supported, but not for 1.6-ext. I made the adjustments outlined in the off I found but could not get it to build successfully. (on phone, sorry for short reply..)
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 14, 2016 03:19 |
Updating OpenFOAm 1.6 to 2.0 | fs82 | OpenFOAM | 1 | May 3, 2012 09:19 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
OpenFOAM Version 1.6 Released | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 0 | July 27, 2009 17:55 |
