[foam-extend.org] Multiple build flavors ... no out of tree? |
May 26, 2016, 18:17 |
John Wohlbier
I'm fairly new to building foam-extend-3.2, and have managed to get it to all work out. However, having multiple concurrent build flavors seems to be problematic.
For normal development work I typically have an optimized and debug build for each compiler I commonly use. At the minimum this is 4 builds, 2 for gcc and 2 for intel. Since foam-extend-3.2 doesn't seem to support out of tree builds this amounts to, unless I am missing something, 4 different repository checkouts and a build under each one? I'm not sure my disk quota will allow me to go up to 60GB ... Thanks. jgw |
May 27, 2016, 16:06 |
John Wohlbier
I see now that the build files are maintained within the tree under the flavor of the build, e.g., Linux64IccDPDebug. In that way one can have separate bashrc files for each flavor and maintain separate builds within the same tree. At least that's how it appears to work.
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
SU2 Parallel Build Install Issue | jclegg | SU2 | 4 | October 20, 2020 04:28 |
[OpenFOAM.org] Install openFOAM 3.0.1 in Ubuntu 16.04 LTS from Deb packs | Pier84 | OpenFOAM Installation | 4 | June 18, 2016 16:22 |
Building from Source on Windows using Cygwin64 | ericthefatguy | SU2 | 2 | May 12, 2015 18:23 |
SU2 3.0 build failure | waku2005 | SU2 Installation | 4 | January 24, 2014 12:40 |
