HowTo Make paraFoam from OpenFOAM15 work on OpenSuse11 by installing Qt435 in home directory
Old   April 11, 2009, 09:25
Pierpaolo is on a distinguished road
Thank you very much!
It worked here on both Gentoo and Pclinuxos.
Pierpaolo is offline   Reply With Quote
Old   April 19, 2009, 04:06
Nugroho Adi
mahaputra is on a distinguished road
Originally Posted by tckosvic View Post
Tammo,
I have worked through my missing make system and gotten Qt-4.3.5 to compile, make, and install into ThirdParty directory of OpenFOAM.
Now when I run paraFoam for the cavity case as in the example, I get message below:
tom@linux-l8tg:~/OpenFOAM/tom-1.5/run/tutorials/icoFoam/cavity> paraFoam
paraview: symbol lookup error: /home/tom/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/bin/libpqCore.s o: undefined symbol: _ZN14QObjectPrivate15checkWindowRoleEv
After this I went and recompiled paraFoam (7.2 step). When I ran paraFoam again I got the same message regarding undefined symbol.
I do not have enough capabilities with SUSE to diagnose problem any further.
Anyone have any ideas?
Thanks,
Tom Kosvic
Tammo and Thomas and All
i followed your instruction to install paraview, but i installed it for OpenFOAM-1.5-dev
but i got the error message like this below, when i tried to start paraview
simulation15@user-laptop:~$ paraview
paraview: symbol lookup error: /usr/lib/paraview/libpqCore.so: undefined symbol: _ZN11QFormLayout16staticMetaObjectE
and this error when tried to run paraFoam :
simulation15@user-laptop:~/OpenFOAM/simulation15-1.5-dev/run/tutorials/icoFoam/cavity$ paraFoam
could you please help me to solve this problem?
mahaputra is offline   Reply With Quote
Old   April 20, 2009, 22:43
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
Okay, allow me put it here, I found paraFoam didn't work on my OpenSUSE-11.0,
qmake --version shows 4.4.3, gcc is 4.4.0,
what have to note is the error:
/usr/lib/libpython2.5.so, needed by blah blah,
and I did:
ln -s /usr/lib/libpython2.6.so.1.0 /usr/lib/libpython2.5.so
and recompile util/postprocessing graphics/PV3FoamReader, then paraFoam works.
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   May 1, 2009, 06:48
Default paraFoam working with Qt 4.4.0
  #44
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Hi everybody,
I got ParaFoam to work on openSUSE 11.0 with Qt 4.4.0.
I am using OpenFOAM-1.5-dev.
I installed cmake 2.4-patch 6.
I compiled paraview the usual way and then the PV3FoamReader the usual way too.
It's ParaView-3.3-cvs.
So far paraFoam looks good, I tried it on the icoFoam tutorial case.
Kind Regards,
Philip
bigphil is offline   Reply With Quote
Old   May 28, 2009, 10:01
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Well, last time it worked and now I get this error when doing
sudo make install
make[1]: *** [.obj/release-shared/qapplication.o] Fehler 1
Any ideas whats wrong?
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   May 28, 2009, 10:14
sega's Avatar
Sebastian Gatzka
sudo make install
Just found in another forum that installing
xorg-dev
fixed the problem!
Old   May 30, 2009, 08:22
sega's Avatar
Sebastian Gatzka
After managing to compile the ParaView I am having trouble with my other linux software.
For example, when trying to run kate I get this symbol lookup error
sega@deepblue:~$ kate
kate: symbol lookup error: /usr/lib/libkde3support.so.4: undefined symbol: _ZN13QWidgetAction11eventFilterEP7QObjectP6QEvent
Seems to be a problem with this libkde3support?!
Old   June 2, 2009, 18:02
sega's Avatar
Sebastian Gatzka
After switching back to Qt 4.5.0 (deleting the Qt related entry in bashrc) I was able to suppress the error message and ParaView is still working!
Old   June 26, 2009, 11:18
Steve Hansel
hansel is on a distinguished road
Tammo,
Thanks,
Tom Kosvic
Tom, how did you solve this problem. In the next post I see you say it worked, but I don't see any post that suggested the fix.
hansel is offline   Reply With Quote
Old   June 26, 2009, 11:32
sega's Avatar
Sebastian Gatzka
I had some problems with symbol lookup errors, too.
Which distribution are you using?
I could fix the problem by deleting the Qt related entries in OpenFOAMs bashrc file on my Kubuntu 9.04 system.
Old   June 26, 2009, 13:43
Steve Hansel
I'm on Ubuntu 9.04. I originally had a working OpenFOAM system that I got by a combination of trying to install myself and the installation script that someone put out. But then I tried to upgrade to 1.5.x and messed everything up. (I should have left Thirdparty alone.)
I've compiled with several versions of QT (The one that 4.5 (I think, its the one that installs with package manager), 4.3.1 and 4.3.5. None of my compilations would run. I am currently trying the binary Thirdparty distribution, but I'm still getting the error about libPWCore.so (again trying different Qts) The strange thing is that library is right in the paraview tree, how can it be messed up?
Steve
Old   June 26, 2009, 13:47
Steve Hansel
I don't see any Qt related enteries in bashrc or settings.sh
Old   June 26, 2009, 17:01
sega's Avatar
Sebastian Gatzka
Originally Posted by wenterodt View Post
3.
add the following lines to your ~/OpenFOAM/OpenFOAM-1.5/etc/bashrc at the very end
# set QT related variables
QT=~/OpenFOAM/ThirdParty/Qt-4.3.5
export PATH=$QT/bin:$PATH
export LD_LIBRARY_PATH=$QT/lib:$LD_LIBRARY_PATH
I'm talking about these entries. Do you put them into OpenFOAM's bashrc?
I had to delete the entry to make it work on my Kubuntu 9.04
[OpenFOAM] ParaFoam error in OpenFOAM15 asaha ParaView 24 November 2, 2009 19:16
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 10:46
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 04:41
Howto install OpenFOAM on mandriva2009qt44 with Qt435 in home directory gzy_1228 OpenFOAM Installation 0 November 15, 2008 14:31
ParaFoam didnbt work Leosding (Leosding) OpenFOAM Installation 11 February 17, 2005 16:44
