September 29, 2008, 12:03 |
Hi all,
I installed OF1
Kai Liu
Rep Power: 17 |
Hi all,
I installed OF1.5 on my Fedora 9 system simply by extractiong all the binary packages as described in README. When I tested it with icoFoam's cavity case, the blockMesh and the solver icoFoam worked well, but the paraFoam programme told me it could not find a reader of the case. Now I can only use foamToVTK to see the result. So what is the problem and how to solve it? Regards, Kai |
September 29, 2008, 13:41 |
Hi
You need QT4.3.x and yo
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi
You need QT4.3.x and you need to compile paraFoam from scratch. Look in the README file for further informations. It should be noted that on Fedora 9, QT4.4.x is the default, thus you need to download the source for QT4.3.x and compile that be yourself as well. Further you will probably be needing libmpfr<something> for the gcc-compiler to be working. Good luck, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
October 1, 2008, 02:50 |
Hi Niels,
Thanks you for yo
Kai Liu
Rep Power: 17 |
Hi Niels,
Thanks you for your advice. Yes, I tried the buildParaView3.3-cvs method mentioned in README and failed. The reason may be QT version incompliant as you said. Now, should I delete the qt-4.4.1 on my system before installing qt4.3, or just simply compile qt4.3 in the case of qt4.4.1 existing ? Regards, Kai |
October 1, 2008, 03:14 |
You don't need to install qt4.
Matthias Kern
Rep Power: 17 |
You don't need to install qt4.3!
I just compiled paraview using qt4.4.2. Simply uncomment the qt check in the CMakeLists.txt. There is a line starting with MESSAGE(SEND_ERROR "QT ${QTVERSION }.... Add a # in front. It compiled without error and runs perfectly. Didn't even crach once since a use it. regards, Matthias |
October 1, 2008, 03:31 |
Note that even a slight mis-ma
Mark Olesen
Rep Power: 40 |
Note that even a slight mis-match in qt versions can cause problems. I had paraview and the OpenFOAM reader module compiled with qt 4.3.3.
One of the machines had qt 4.3.1 installed, which meant that paraview started okay, but the reader module didn't load. Updating all the workstations to the same qt4.3.3 version eliminated the problem. |
October 1, 2008, 12:36 |
Hi Matthias,
Thanks a lot
Kai Liu
Rep Power: 17 |
Hi Matthias,
Thanks a lot! I just followed your advice and successfully recompiled the paraFoam with qt-4.4.1. It runs well now. I cannot understand why the install guide says that versions older or newer than qt-4.3.x are not allowed. Best regards, Kai |
October 2, 2008, 02:31 |
Hi Kai,
If you scan the par
Mark Olesen
Rep Power: 40 |
Hi Kai,
If you scan the paraview mailing lists, you'll see that building with various qt versions, or even debug vs. release, is a constantly recurring topic. The qt API might change a little between versions, the cmake files might be too stringent in allowing/disallowing particular qt versions, there may be qt bugs that paraview triggers in particular qt versions, or simply that the paraview developers have compiled with a particular version and don't know if it works well with a newer/older version. I hope this explains why the install guide really isn't misleading. What if the install guide stated "you should use qt-4.3.x, unless you change the CMakeLists.txt, clean out all the old build remnants (and cmake cache files, and it might be necessary to remove the entire paraview directory and do a fresh cvs checkout too) and pray that all goes well when you compile against a different qt version"? Scan the paraview mailing lists and you'll see what I mean. I am personally grateful for the buildParaview script provided with OpenFOAM - it has greatly improved my success rate with building paraview! |
[OpenFOAM] Problem with paraFoam | wandeklein | ParaView | 1 | October 9, 2008 16:12 |
[OpenFOAM] Parafoam problem | mochzeen | ParaView | 12 | September 22, 2008 17:46 |
OF15 paraFoam Update GUI not functional | aunola | OpenFOAM Installation | 1 | July 28, 2008 00:32 |
ParaFOam problem | luca | OpenFOAM Running, Solving & CFD | 1 | May 3, 2006 12:06 |
[OpenFOAM] Could anybody help me about the paraFoam problem | liugx212 | ParaView | 1 | February 3, 2006 11:06 |
