July 17, 2008, 09:47 |
well, i just got the Op
Bernd Stöver
Rep Power: 17 |
well, i just got the OpenFOAM 1.5 and tried to compile. To do so, i got also the ThirdPartylinuxGcc.gtgz packet (so the binaries). Anyway, i did get the .bashrc modified and ran ./Allmake. Now after some time i found out, it didn't find the flex++. Since i didn't feel like editing the make script, i simply installed it from the debian distribution (i use debian testing = lenny: uname -a Linux client4 2.6.24-1-686 #1 SMP Thu May 8 02:16:39 UTC 2008 i686 GNU/Linux) Anyway compiling does produce a lot of lines so it was hard to get the first error messages. So i did ./Allmake>output.txt This way only the error messages went to the screen. And here is what i got: ./Allwmake >output.txt + cd . + cd wmake/src + make + cd /home/bs/OpenFOAM/ThirdParty + ./Allwmake ./Allwmake: line 10: ./Allwmake: Datei oder Verzeichnis nicht gefunden (this is file not found in German) + cd src + ./Allwmake + cd OpenFOAM + wmakeLnInclude . + cd Pstream + ./Allwmake + wmake libso dummy + case "$WM_MPLIB" in + export WM_OPTIONS=linuxGccDPOptOPENMPI + WM_OPTIONS=linuxGccDPOptOPENMPI + set +x + wmake libso mpi + wmake libo OSspecific/Unix + wmake libso OpenFOAM + wmake libso lagrangian/basic + wmake libso triSurface + wmake libso edgeMesh + wmake libso meshTools + wmake libso finiteVolume + cd decompositionAgglomeration + ./Allwmake + wmake libso decompositionMethods metisDecomp/metisDecomp.C:37:22: error: metis.h: Datei oder Verzeichnis nicht gefunden (which means file not found in German) metisDecomp/metisDecomp.C: In member function 'Foam::label Foam::metisDecomp::decompose(const Foam::List<int>&, const Foam::List<int>&, Foam::List<int>&)': metisDecomp/metisDecomp.C:268: error: 'METIS_WPartGraphRecursive' was not declared in this scope metisDecomp/metisDecomp.C:285: error: 'METIS_PartGraphRecursive' was not declared in this scope metisDecomp/metisDecomp.C:306: error: 'METIS_WPartGraphKway' was not declared in this scope metisDecomp/metisDecomp.C:323: error: 'METIS_PartGraphKway' was not declared in this scope make: *** [Make/linuxGccDPOpt/metisDecomp.o] Fehler 1 + '[' -d /home/bs/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/openmpi-1.2.6 ']' + wmake libso parMetisDecomp parMetisDecomp.C:41:25: error: parmetis.h: Datei oder Verzeichnis nicht gefunden and so on. Anybody has an idea of what's missing? |
July 17, 2008, 10:03 |
Since you have the machine in
Mark Olesen
Rep Power: 40 |
Since you have the machine in front of you, you're probably in a better position to see why it can't find the file, but maybe it's a permissions problem, since the chdir to "/home/bs/OpenFOAM/ThirdParty" was successful and the Allwmake script certainly exists in the tarball:
$ tar -tzf ThirdParty.General.gtgz | grep Allwmake Did you unpack it in the correct directory? Maybe you have ThirdParty/ThirdParty or something. Or did you just unpack the binaries? |
July 17, 2008, 16:49 |
O.k. this doesn't work since i
Bernd Stöver
Rep Power: 17 |
O.k. this doesn't work since i used the binary package ThirdPartylinuxGcc.gtgz and there is no Allwmake inside as it is already compiled. Now this should not be a problen should it?
July 18, 2008, 02:44 |
Yes it will definitely be a pr
Mark Olesen
Rep Power: 40 |
Yes it will definitely be a problem. As your post showed, the other libraries have no information about what can be found in these pre-compiled ThirdParty libraries.
It's really no different that trying to compile any C/C++ program without having /usr/include header files! |
July 21, 2008, 09:46 |
O.k. strange, but it is this w
Bernd Stöver
Rep Power: 17 |
O.k. strange, but it is this way. After installing some additional libraries it all worked fine. Thanx!
July 26, 2008, 10:18 |
Bernhard, I'm running Debian E
Gene
Rep Power: 17 |
Bernhard, I'm running Debian Etch and compiled the 32-bit OpenFOAM 1.5
Is there a log that is written for ./Allwmake because I, too, am having a problem installing. I had to compile from source the qt4.3.5 libs; which failed and I had to install the x11-dev libs which allowed qt to finish. But my ./Allwmake seems to keep failing "due to errors" however I don't know where to look to see what "errors" are occurring. Also, which additional libraries did you install to allow your version to complete without error? Does ParaView run for you? ParaView says it cannot find my qt shared objects; which I added to my path directly and verified they do exist. Thanks for your time! -Gene Brotherton USA |
July 31, 2008, 09:35 |
Hi Gene,
what i did, was si
Bernd Stöver
Rep Power: 17 |
Hi Gene,
what i did, was simply to write the standard output in a file: ./Allwmake > file.txt The rest of the output are the error-messages, they can be still quite a lot. Usually the important ones are nevertheless at the top. Now, all the libraries needed i installed from the debian package. Therefore i didn't compile qt, but i installed the qt-dev package (also for quite a lot of the other packages). This somehow worked. For Paraview i cannot say much yet. I didn't get around to use it yet. Bernhard |
August 4, 2008, 00:16 |
Thanks Bernhard! I did what y
Gene
Rep Power: 17 |
Thanks Bernhard! I did what you suggested by piping the output to a txt file so I could see the errors better. There were a lot more packages I had to install, (flex being one of them; I have never heard of flex before this). And finally I realized I had to copy the Qt libs from the default trolltech install directory to my /usr/libs directory. It appears OF did everything it was supposed to do expect the paraview build. I had to rebuild that by following the instructions on the OF web page, then paraview compiled and functioned normally.
I am still very new to the CFD world, but i think this software will help once I get the hang of things. Thanks again! -Gene |
August 13, 2008, 15:29 |
For the record, I would like t
#9 |
Srinath Madhavan (a.k.a pUl|)
Rep Power: 21 |
For the record, I would like to say that I was able to build the 1.5 version without any issues on Debian (testing) :-)
Problems compiling OpenFOAM15 on Debian Etch | geoffjay | OpenFOAM Installation | 1 | February 5, 2009 16:29 |
COMPILING PROBLEM | ammi | FLUENT | 1 | December 7, 2006 04:07 |
problem in compiling UDF | ammi reddy | FLUENT | 1 | December 1, 2006 06:45 |
Trouble compiling on Debian Etch | jkr | OpenFOAM Installation | 2 | April 14, 2006 14:56 |
PROBLEM COMPILING!!! PLEASE HELP! | Toni Cominceanu | FLUENT | 3 | May 17, 2005 02:12 |
