How should one debug a solver using KDevelop
Old   March 8, 2008, 14:56
Default Hello, what would you advice
kar
Kārlis Repsons
kar is on a distinguished road
what would you advice for a beginner? I did partially recompiled OpenFOAM with debug (ran into paraview problems). Can build an app using
EXE_INC = \
-I$(LIB_SRC)/finiteVolume/lnInclude -DFULLDEBUG -g -O0
Kārlis
kar is offline   Reply With Quote
Old   March 11, 2008, 08:30
Default Hello again, now I have more
kar
Kārlis Repsons
Hello again,
now I have more appointed problem: when I compile program and run it in gdb, I can debug it, but when start that app by KDevelop's "Debug->Start"(which also uses GDB by defaul) it just exits quickly.
Debugging versions are supposed to be much slower, right?
Switch between debug / opt version of build is "-DFULLDEBUG -g -O0" options or I've missed something?
What debugging environment have you found useful?
Some knowledge about debug will be appreciated here!
K.
Old   March 11, 2008, 10:13
Default Wrong, WM_COMPILE_OPTION is a
kar
Kārlis Repsons
Wrong, WM_COMPILE_OPTION is a switch!
Old   July 26, 2008, 16:13
Default Karlis, I have had the same
Kent S Kapitan
kent_kapitan is on a distinguished road
Karlis,
I have had the same problem. Have you found a solution ?
Kent Kapitan
kent_kapitan is offline   Reply With Quote
Old   July 27, 2008, 05:37
Default Kent, that was not very impor
kar
Kārlis Repsons
Kent,
that was not very important for me, so I used GDB through console sometimes. That can give useful information, but I missed something to integrate with KDevelop...
Old   July 28, 2008, 16:36
Default Karlis, Thanks. Fortunat
Kent S Kapitan
Karlis,
Thanks. Fortunately, I managed to figure it out and actually got it to work. I have posted a summary of the solution for others if your interested. Just search the message board for KDevelop. The trick turns out to be leaving the "Debugger Executable" blank in the Project Options Debugger dialog in KDevelop.
Wmake C and KDevelop for a Foam project roncresswell OpenFOAM Installation 21 January 27, 2010 12:00
debug in Fluent Miriam Main CFD Forum 0 September 2, 2008 05:21
About "debug=T" sammi Phoenics 0 June 14, 2008 07:18
Manage openfoam solver project in KDevelop probably the last linker error any suggestion is welcome lakeat OpenFOAM Installation 0 July 7, 2007 10:01
Why can not set breakpoints in debug lee Main CFD Forum 0 October 24, 2006 04:00
