Invalid boundary type name
Old   June 7, 2008, 06:02
Default Hi, Am I definitely at odds
bloblo
blobloblo is on a distinguished road
Am I definitely at odds with openfoam ? When I try to set boundary conditions, the only choise I have for 'wall' is 'wallfunctions'. The only one I have for 'inlet' is 'pressureInlet', and so on, whereas I am sure I had in the past 'adiabaticWall', 'turbulentInlet', ....
The thing is, I can't even set it in the boundary file or I got :
Invalid boundary type name 'adiabaticWall'
What's the pb, according to you ?
Regards.
blobloblo is offline   Reply With Quote
Old   June 9, 2008, 11:21
Default Hi Bloblo! You're taking ab
Assistant Moderator
Bernhard Gschaider
Hi Bloblo!
You're taking about seeting the BCs in FoamX, right?
'adiabaticWall', 'turbulentInlet' etc are "only" the physicalTypes, which are
a) only used by FoamX
b) depend on the solver your project is under
So if you have an isothermal solver like icoFoam you won't get the boundaryCondition 'adiabaticWall', (because it doesn't make sense)
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Problem with boundary type Shanti FLUENT 2 May 27, 2012 04:19
Invalid thermal boundary condition azraf Siemens 2 July 18, 2008 04:52
invalid type for binary expression: double / funct Fiachra FLUENT 0 April 12, 2007 08:04
pdf_initial_enthalpy: Invalid pdf type mneo FLUENT 0 October 12, 2006 11:45
error: CDR: invalid argument [1]: wrong type Marc FLUENT 0 July 24, 2006 05:59
