Configuration of MPICH
Old   August 24, 2006, 12:39
Default Hi Håkan, can you try attac
  #21
Mattijs Janssens
mattijs is on a distinguished road
Hi Håkan,
can you try attached argList.C and let me know whether that helps?
argList.C
mattijs is offline   Reply With Quote
Old   August 24, 2006, 13:43
Default Hi Mattijs, mpiexec can rea
  #22
Håkan Nilsson
hani is on a distinguished road
Hi Mattijs,
mpiexec can read the arguments from a file, and I tried that. However, the arguments in the file are just added as flags to the mpiexec command and we're back where we started.
I'll test your argList.C on monday when I get back to work.
If it doesn't work, is there any problem just removing the FatalError.exit() as long as I make sure that I start my computations correctly (giving the correct flags and arguments)?
Thanks for your efforts.
Håkan.
hani is offline   Reply With Quote
Old   August 25, 2006, 03:34
Default >removing the FatalError. It
  #23
Mattijs Janssens
It probably will set the root and case incorrectly.
Old   August 28, 2006, 03:24
Default Hi Mattijs, Actually, remov
  #24
Håkan Nilsson
Hi Mattijs,
Actually, removing FatalError seemed to work and set the root and case correctly.
Your argList.C above also seems to work, so I will stick to that one. What I am not really sure about is if you actually truncate argv? Then the extra flags are not needed by MPI_Init inside OpenFOAM? Or is MPI_Init run before argList.C?
It now seems like I don't have to do addValidParOptions for the extra flags, so there is still no check of consistency for those flags. But I can live with that.
Thanks for your help!
Håkan.
Old   August 29, 2006, 03:52
Default Thanks for testing. The 'ru
  #25
Mattijs Janssens
Thanks for testing.
The 'rule' is that MPI_Init strips off any of its arguments (which it added to start up the job). So after MPI_Init we should have a clean argument list.
You should now not need those extra addValidParOptions in your mpi/Pstream.C
Old   September 9, 2006, 07:58
Default Hi, What is the difference
  #26
Pei-Ying Hsieh
hsieh is on a distinguished road
What is the difference between MPICH and Lam? Does MPICH has a better performance than LAM?
Thanks!
Pei
hsieh is offline   Reply With Quote
Old   December 5, 2006, 13:37
Default Hi I got today the same messa
  #27
rafal zietara
rafal is on a distinguished road
Hi
I got today the same message
error. Without PBS everything
runs perfectly but when using
queue system than it is not so
pinky. Did you find any solution?
Is thre any trick to solve or
bypass the error?
thanks in advance
rafal
error:
[0] MPI Abort by user Aborting program !
[0] Aborting program
rafal is offline   Reply With Quote
Old   December 6, 2006, 01:18
Default The problem with additional fl
  #28
Håkan Nilsson
The problem with additional flags to mpiexec was solved when using Mattijs argList.C file in the previous entry:
http://www.cfd-online.com/cgi-bin/Op...=9626#POST9626
Håkan
Old   June 2, 2007, 03:08
Default Dear Friends I am using OF1
  #29
kumar
kumar2 is on a distinguished road
Dear Friends
I am using OF1.3. want to change from LAM to MVAPICH. i did the following
1) export WM_MPLIB=MPICH in bashrc
2) set all path to the MVAPICH library in .bashrc
But i get this error when i do wmake libso in /src/Pstream/
/usr/bin/ld: /usr/local/topspin/mpi/mvapich/gnu/lib/libmpich.a(probe.o): relocation R_X86_64_32 against `a local symbol' can not be used when making a shared object; recompile with -fPIC
/usr/local/topspin/mpi/mvapich/gnu/lib/libmpich.a: could not read symbols: Bad value
collect2: ld returned 1 exit status
make: *** [/home/kri_kuma/OpenFOAM/OpenFOAM-1.3/lib/linuxAMD64Gcc4DPOpt/mpich/libPstream.s o] Error 1
There is only a libmpich.a in /mvapich/lib
what should i do ?
Thanks a lot in advance
kumar
kumar2 is offline   Reply With Quote
Old   June 6, 2007, 17:26
Default Dear all, Any comments on
  #30
kumar
Dear all,
Any comments on the previous post which is once again repeated here.
Dear Friends
what should i do ?
kumar
Old   June 6, 2007, 17:46
Default These are just guesses: 1.
  #31
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
1. Try to link against a shared library (file extension *.so) as opposed to a static on (*.a). In other words build the MPI library with --with-shared or whatever is the appropriate argument. If you're linking against a pre-built library, try to see if you can find whether it was build with 'shared library' suppprt.
2. Make sure that WM_64 is set to on (assuming you are in 64 bit mode).
msrinath80 is offline   Reply With Quote
Old   June 6, 2007, 18:08
Default Hi pUI Thanks a lot for the
  #32
kumar
Hi pUI
Thanks a lot for the prompt reply. I only vaguly understand what you say and hopefully my sysad will help me from here.
kumar
MPICH r2d2 OpenFOAM Installation 1 June 15, 2005 19:32
PVM or MPICH CFX User CFX 5 November 3, 2004 16:31
LAM/MPI or MPICH? Junseok Kim Main CFD Forum 0 January 15, 2004 07:10
PC configuration for CFD Fernando Sanz Main CFD Forum 17 December 19, 2001 07:29
MPICH Junseok Kim Main CFD Forum 1 November 5, 2000 22:07
