Problems installing OpenFoam on a 64bit machine
Old   June 4, 2007, 10:47
Default Hello ! I just installed Open
Jan Goebel
jango is on a distinguished road
Hello !
I just installed OpenFoam on a 32bit- machine and it works fine. So I processed with the installation on a 64bit machine. THe uname -a command deliveres the following output:
Linux 2.6.20-1.2952.fc6 #1 SMP Wed May 16 18:18:22 EDT 2007 x86_64 x86_64 x86_64 GNU/Linux
(Fedora Core 6, Multiprocessor)
I set the environment variable $WM_64 and processed the installation as described, but it doesn` t work. Processing the foamInstallationTest brings the following output:
Checking basic setup...
Shell: bash
Host: Goebel
OS: Linux version 2.6.20-1.2952.fc6
User: GoebelJ
User_config: /home/GoebelJ/.bashrc
Foam_config: /home/GoebelJ/.OpenFOAM-1.4/bashrc sourced correctly.
Checking main FOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/GoebelJ/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/GoebelJ/OpenFOAM/GoebelJ-1.4 yes no
$FOAM_JOB_DIR /home/GoebelJ/OpenFOAM/jobControl no yes
Checking the FOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/GoebelJ/OpenFOAM/OpenFOAM-1.4 yes yes yes
$FOAM_USER_APPBIN ....4/applications/bin/linux64Gcc4DPOpt yes yes no
$FOAM_APPBIN ....4/applications/bin/linux64Gcc4DPOpt yes yes yes
$WM_DIR .../GoebelJ/OpenFOAM/OpenFOAM-1.4/wmake yes yes yes
$FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes
$CEI_HOME /usr/local/ensight/CEI no no
$JAVA_PATH ...ebelJ/OpenFOAM/linux64/j2sdk1.4.2_05 yes yes no
$MICO_ARCH_PATH ...co-2.3.12/platforms/linux64Gcc4DPOpt yes yes yes
$LAM_ARCH_PATH ...lam-7.1.2/platforms/linux64Gcc4DPOpt yes yes yes
$MPICH_ARCH_PATH --------- env variable not set --------- no
Checking the FOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...AM/OpenFOAM-1.4/lib/linux64Gcc4DPOpt yes yes yes
$FOAM_USER_LIBBIN ...OAM/GoebelJ-1.4/lib/linux64Gcc4DPOpt yes yes no
Software versions
Software Version Location
gcc 4.1.2 /home/GoebelJ/OpenFOAM/linux64/gcc-4.1.2/bin/gcc
java 1.4.2_05 /home/GoebelJ/OpenFOAM/linux64/j2sdk1.4.2_05/bin/java
gzip 1.3.5 /usr/bin/gzip
tar 1.3.5 /bin/tar
icoFoam ...OpenFOAM-1.4/applications/bin/linux64Gcc4DPOpt/icoFoam
Checking file/directory permissions...
File/directory Set Reqd Crit
Checking networking...
Action Result Crit
Pinging_Goebel Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the Foam enviroment.
Base configuration ok.
Critical systems ok.
Starting FoamX brings the following error message:
nsd: error while loading shared libraries: libssl.so.0.9.7: wrong ELF class: ELFCLASS32
thank you for your big help,
Jan
jango is offline   Reply With Quote
64bit machine for CFX Ahlo CFX 1 February 7, 2008 16:30
Library problem on a 64bit machine wrong ELF class ELFCLASS32 jango OpenFOAM Installation 0 June 11, 2007 07:29
Problem installing on 64bit with ver13 jonititan OpenFOAM Installation 5 May 12, 2006 18:42
Problem installing on 64bit with ver13 jonititan OpenFOAM Installation 0 April 28, 2006 05:45
runing Fluent with a 64bit machine Rucy FLUENT 1 November 17, 2005 08:51
