August 26, 2005, 05:44 |
I removed 1.1 installation by
Maka Mohu
Rep Power: 18 |
I removed 1.1 installation by changing the name of 1.1 installation folder.
I installed 1.2 as in README. foamInstallationTest gives OK OK but with two strange lines: User_config: /home/marwan/.bashrc Foam_config: /home/marwan/.OpenFOAM-1.1/bashrc sourced correctly. $FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes This means that it still sees the old 1.1 the main problem: runFoamX is not available, only runFoamXHB and it hangs? can you help? Regards, Maka |
August 26, 2005, 05:50 |
ReleaseNotes-1.2: http://foam.
Chris Greenshields
Rep Power: 17 |
August 26, 2005, 05:57 |
Thanks. It works.
Any idea
Maka Mohu
Rep Power: 18 |
Thanks. It works.
Any idea why I get .OpenFOAM-1.1 instead 1.2 in the following foamInstallationTest: Foam_config: /home/marwan/.OpenFOAM-1.1/bashrc sourced correctly. |
August 26, 2005, 06:55 |
See OpenFOAM Message Board: Op
Håkan Nilsson
Rep Power: 18 |
See OpenFOAM Message Board: OpenFoam-Bugs: Typo in foamInstallationTest, version 1.2
August 26, 2005, 11:18 |
Thanks!
Maka Mohu
Rep Power: 18 |
Thanks!
August 26, 2005, 17:17 |
Detailed procedur:
I instal
Maka Mohu
Rep Power: 18 |
Detailed procedur:
I installed both 1.1 and 1.2 together and thought that posting the following procedure may be of help to people that wants to keep two versions of OpenFOAM and switch easiely between them, (1) {platform} folder: you can put here any third party bindary that is needed for any version, since source set the right path; (2) {user}-{version} and OpenFOAM-{version} folders: are distinguised by their version, so once can include all versions he likes; (3) change $HOME/.bashrc to point to the required version; (4) source $HOME/.bashrc; Regards, Maka |
Removing solution from DEF after interpolation | Massimiliano | CFX | 0 | October 20, 2008 18:17 |
ICEM, Tetra removing | Mikhail | CFX | 1 | July 24, 2008 11:07 |
Removing lines from partitions | Josh | FLUENT | 7 | July 27, 2007 10:33 |
removing of linux and keeping windows | Anja | Main CFD Forum | 4 | August 23, 2006 07:01 |
removing conduction term | Philippe Salama | FLUENT | 1 | June 3, 2005 12:12 |
