Tow Critical Error about GCC amp icoFoam
Old   May 25, 2005, 10:19
Default How to correct them? others ex
Martin/Run DU
chnrdu is on a distinguished road
Send a message via Skype™ to chnrdu
How to correct them? others except them is ok.
I want to run OpenFOAM on FedoraCore 3. Thanks.
following are errors:
gcc 3.4.3
WARNING: Conflicting installations:
foam settings: /home/ndt/OpenFOAM/linux/gcc-3.4.3/bin/gcc
current path : /bin/gcc
CRITICAL ERROR
java previous
libgcj)
foam settings: /home/ndt/OpenFOAM/linux/j2sdk1.4.2_05/bin/java
current path : /usr/bin/java
gzip 1.3.3 /bin/gzip
tar 1.3.3 /bin/tar
icoFoam *** not installed ***
CRITICAL ERROR
rdu
Martin/Run Du
chnrdu is offline   Reply With Quote
Old   May 25, 2005, 17:07
Default The message means that you do
Mattijs Janssens
mattijs is on a distinguished road
The message means that you do not have gcc installed in the correct place. (/home/ndt/OpenFOAM/linux/gcc-3.4.3). You can download the gcc from the OpenFOAM site.
Same for java.
mattijs is offline   Reply With Quote
Old   May 25, 2005, 21:22
Default but icoFoam *** not install
Martin/Run DU
but
how to install icoFoam
rdu
Martin/Run Du
Old   May 26, 2005, 05:10
Default You have probably not installe
Eugene de Villiers
eugene is on a distinguished road
You have probably not installed the Foam binaries in the correct place.
If you type "ls $FOAM_APPBIN" you should see all the appplication binaries (including icoFoam). If they are not there you have not installed them properly.
eugene is offline   Reply With Quote
Old   July 8, 2005, 06:14
Default but how to install them proper
ztdep's Avatar
p ding
ztdep is on a distinguished road
Send a message via Yahoo to ztdep Send a message via Skype™ to ztdep
but how to install them properly. thankyou very much.
ztdep is offline   Reply With Quote
CRITICAL ERROR on installation OpenFOAM 141 nuovodna OpenFOAM Installation 19 March 22, 2010 22:36
Critical error chris_j_meyer OpenFOAM Installation 2 February 13, 2009 02:39
Critical errors gcc and icoFoam during installation of 15 quartzian OpenFOAM Installation 3 December 12, 2008 12:42
Critical errors on gcc and icofoam giuliano OpenFOAM Installation 4 June 25, 2008 13:31
Installation problem 1 critical error Ervin Adorean (Adorean) OpenFOAM Installation 14 October 23, 2006 03:44
