LibPstreamso
Old   June 27, 2005, 11:27
Default Hi, I am trying to get OpenF
Radu Mustata
r2d2 is on a distinguished road
I am trying to get OpenFOAM to run on our cluster that uses MPICH and myrinet so I´ve modified the parallel variables in .bashrc and .OpenFoam-1.1/bashrc to point to my version of mpich (1.2.5..11) and the gm2_3.3. Now I generated a libPstream.so and rebuilt the utilities to have a starting point for doing some meshing. Problem is that when I use for instance the blockMesh command I get a message like:
error: .../libPstream.so: symbol
errno, version GLIB_2.0 not defined in file libc.so.6 with link time reference
Is there any way of sorting this out?
Cheers,
Radu
r2d2 is offline   Reply With Quote
Old   June 27, 2005, 11:38
Default Are you using a binary release
henry is on a distinguished road
Are you using a binary release of OpenFOAM or did you build from sources?
It looks like you have a library compatability problem and you need to build everything consistently, i.e. with the same compiler and including the same libraries. The easiest way would be to rebuild the myrinet mpich but I guess you don't have sources for that so you will probably have to rebuild OpenFOAM.
henry is offline   Reply With Quote
LibPstreamso mark OpenFOAM Installation 4 March 27, 2008 12:34
