What flags to set in cshrc
Old   June 8, 2005, 04:39
Default I have compiled version 1.1 on
Marco Kupiainen
kupiainen is on a distinguished road
I have compiled version 1.1 on linuxAMD64. I want to run in parallell. But trying to do so I get the following error:
+ lamboot -prefix /afs/nada.kth.se/home/nada/marcok/OpenFOAM/OpenFOAM-1.1/src/lam-7.1.1/platforms/ linuxAMD64Opt -v
/var/easy/f-pop/user/hostlist/marcok/SPnodes.060713442336
n-1<19866> ssi:boot:base:linear: booting n0 (d14n05.pdc.kth.se)
base: cannot open /afs/nada.kth.se/home/nada/marcok/OpenFOAM/OpenFOAM-1.1/src/lam-7.1.1/platforms/ linuxAMD64Opt/etc/lam-conf.lamd: No such file or
directory
hboot could not parse the boot configuration file. A number
of problems can result in this error messages:
- Is the configuration file installed properly?
- Did you specify a file name that does not exit when
using the -c option to lamboot?
n-1<19866> ssi:boot:base:linear: Failed to boot n0 (d14n05.pdc.kth.se)
n-1<19866> ssi:boot:base:linear: aborted!
lamboot did NOT complete successfully
It seems that the Allwmake script missed to do something vital with the lam-library. My question is what flags should I set in order to solve the above problem.
best regards Marco
kupiainen is offline   Reply With Quote
Old   June 8, 2005, 04:49
Default wmake is not used to build lam
henry is on a distinguished road
wmake is not used to build lam the Allwmake script in OpenFOAM-1.1/src simply calls the configure make scripts supplied with lam. You will have to check the build of lam yourself. Does the file
exist? If so what is in it? What are the permissions on it? If it does not exist try building lam yourself using the configure options from the Allwmake script and see if this missing file is created.
henry is offline   Reply With Quote
Old   June 8, 2005, 07:56
Default I built lam myself manually an
Marco Kupiainen
I built lam myself manually and now it works.
Thank you for taking your time.
Compilation of decompositionMethods with debug flags fabianpk OpenFOAM Bugs 0 July 4, 2007 07:35
How to compile OpenFOAM from scratch bashrc and cshrc danieltourde OpenFOAM Installation 2 December 15, 2006 09:30
Compilation flags for SGI Goldman Main CFD Forum 1 September 15, 2003 09:56
