Critical Error wxecuting foamInstallationTest
Old   April 22, 2009, 05:03
Default Critical Error wxecuting foamInstallationTest
Danilo
ziooscuro is on a distinguished road
I try to install openFOAM 1.5-dev. If i execute icoFoam, it works properly, but when i try to make the installation test i receive this error:
WARNING: gcc version does not match gcc supplied with this release of OpenFOAM
Supplied version: 4.3.1
User version : ../configure
4.3.1
Minimum required: 4.2.0
gcc ...figure
WARNING: Conflicting installations:
OpenFOAM settings : /nfs/home/bruno/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc
current path : /usr/bin/gcc
CRITICAL ERROR
gzip 1.3.12 /usr/bin/gzip
tar 1.19 /bin/tar
icoFoam 1.5-dev ...nFOAM-1.5-dev/applications/bin/linux64GccDPOpt/icoFoam
Actually there's already an installed version (1.5) on the server and i guess that this could be the "Conflicting installations"..... but how can i fix the critical error?
Thanks in advance
ziooscuro is offline   Reply With Quote
Old   April 25, 2009, 13:32
Samuele
StructureITA is on a distinguished road
I have almost the same error. Does someone have the solution, please? I'm searching in the whole forum, but I am not able to find an answer.
StructureITA is offline   Reply With Quote
Old   April 25, 2009, 14:06
Samuele
I tried this way: I opened setting.sh (conteined within OpenFOAM/OpenFOAM-1.5.x/etc) and I changed the line "compilerInstall" from OpenFOAM to System. In this way my "critical error" disappeared.
Old   May 2, 2009, 17:24
Question inconsistent path definition
Robert
ral007 is on a distinguished road
I have modified the settings.sh to System to compile the code with Gcc version 4.3.3 in Ubuntu 9.0.4 distribution, and the baseline installation was deemed to be ok by foamInstallationTest. However, when checking for the icoFoam executable path, there was one inconsistent path definition with FOAM_APPBIN and FOAM_USER_APPBIN. I have not figured out how to fix the problem yet.
icoFoam
OpenFOAM settings : /home/rlee/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccSPOpt/icoFoam
current path : /home/rlee/OpenFOAM/rlee-1.5/applications/bin/linuxGccSPOpt/icoFoam
CRITICAL ERROR
Does anyone know how to fix this ?
ral007 is offline   Reply With Quote
CRITICAL ERROR on installation OpenFOAM 141 nuovodna OpenFOAM Installation 19 March 22, 2010 22:36
Critical temperaturepressure of liquids for dieselFoam solver sebastian_vogl OpenFOAM Running, Solving & CFD 0 December 30, 2008 15:57
Critical errors gcc and icoFoam during installation of 15 quartzian OpenFOAM Installation 3 December 12, 2008 12:42
Critical errors on gcc and icofoam giuliano OpenFOAM Installation 4 June 25, 2008 13:31
Which is the fatal error when foamInstallationTest eddy OpenFOAM Installation 2 March 30, 2008 21:13
