Install openFOAM 1.6 on debian 32bit - blockMesh: command not found |
August 27, 2009, 09:29 |
#1 | |||
Alex
Rep Power: 16 |
Hi there!
First of all: I've read a lot of threads, tried a lot of solutions, but nothing helped. I have installed openFOAM 1.6 according to the readme.html. Running the foamInstallationTest says: Quote:
- Changing the link of \usr\bin\gcc to the openFoam-gcc according to the error-message - Running the ./Allmake (no errors) - Doing everything of the readme (bashrc, directories,..) - Eating a lot of chocolate - Saying my boss 20 times "It will work in a minute" My Enviroment Debian 5.0 i386 Please help me - Thank you |
August 28, 2009, 04:06 |
Solved
Alex
Rep Power: 16 |
Yahoo! Finally I found the solution in this Thread:
http://www.cfd-online.com/Forums/ope...foam1-6-a.html The order of installing seems to be VERY important. |
blockmesh not found, installing openfoam 1.6 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
Problems Installing OF 1.6 32 bit | bucksfan | OpenFOAM Installation | 19 | August 4, 2009 01:36 |
OpenFOAM15 installables are incomplete problem with paraFoam | tryingof | OpenFOAM Bugs | 17 | December 7, 2008 04:41 |
Problem of compilation OF 14Allwmake command not found | erik_d | OpenFOAM Bugs | 13 | September 13, 2008 21:45 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
