installation OpenFOAM
Old   October 26, 2009, 09:53
Default installation OpenFOAM
lynda
lyna is on a distinguished road
Hi !
please can you help me to install the OpenFOAM in the fedora linux distribution
thank you
lyna is offline   Reply With Quote
Old   October 26, 2009, 12:55
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
What is the problem?
Please be more specific or you won't get any answers.
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   October 27, 2009, 05:29
lynda
Hi
first can I used the fedora distribution instead of the ubuntu or suse distributions
to install OpenFOAM code
thank you
Old   October 28, 2009, 02:57
Gijsbert Wierink
gwierink is on a distinguished road
Hi Lynda,
Yes it is possible, my OpenFOAM is very happy on Fedora . Here are some basic instructions that worked for me (it is for OpenFOAM-1.5, but works also for 1.6, just the file names are different). Hope that solves your trouble.
Cheers,
Gijsbert
gwierink is offline   Reply With Quote
Old   November 2, 2009, 06:05
lynda
Hi Gijsbert
Mon .bashrc is in /root /.bashrc directory.
When I copy the following line:
/ home/OpenFOAM/OpenFOAM-1.6/etc/bashrc
in / root/.bashrc file, I have a problem when I turn on my PC or when I open a new terminal because I find the following error message:
Permission not granted (Permission non accordée)
please help me
Old   November 2, 2009, 06:19
Gijsbert Wierink
Hi Lynda,
You need to put the line
. $HOME/OpenFOAM/OpenFOAM-1.6/etc/bashrc
in $HOME/.bashrc (in case you don't know, "$HOME" is another way to put the path to your user home directory, in my case /home/gijsbert/). This is your user .bashrc, not root's .bashrc . Just open a terminal and type
gedit .bashrc &
and paste the line above in it (notice the "." at the beginning). Save and close gedit and source the terminal with (notice the "." at the beginning again)
. $HOME/.bashrc
or just close it and open an new terminal.
Hope this helps.
Regards,
Gijsbert
Old   November 2, 2009, 06:48
lynda
Hi Gijsbert
I did all the steps in your message, I've copied a terminal to see better things
terminal
bash: ./root/OpenFOAM/OpenFOAM-1.6/etc/bashrc: Aucun fichier ou répertoire de ce type
[root@localhost ~]# .$HOME/.bashrc
bash: ./root/.bashrc: Aucun fichier ou répertoire de ce type
[root@localhost ~]#
thank you
Old   November 2, 2009, 07:30
Gijsbert Wierink
Hi Lynda,
Ok, first of all you need to be in your user account in the terminal, not in root. It seems you are root
[root@localhost ~]#
It is better to use your user account (type "exit" to get out of the root account in the terminal). Also, there needs to be a space between "." and "$HOME/....", so not
.$HOME/.bashrc
, but
. $HOME/.bashrc
Let me know how it goes.
Cheers, Gijs
Old   November 2, 2009, 10:19
lynda
Hi Gijsbert
I opened another session and I redid all, but I had the same messages in
the terminal, it may be necessary to copy the OpenFOAM directory in my file LTPMP
is not it?
Here's what I got :
terminal
bash: /home/LTPMP/OpenFOAM/OpenFOAM-1.6/etc/bashrc: Aucun fichier ou répertoire de ce type
[LTPMP@localhost ~]$ . $HOME/.bashrc
thank you
Old   November 2, 2009, 10:36
Gijsbert Wierink
Hi Lynda,
Did you install OF as root? If so, it is probably located in /root/OpenFOAM/. It is better to install OF in your user account. In your case, I'm afraid, you need to reinstall OF in your user account, i.e. do the whole installation procedure as [LTPMP@localhost ~]$. And to keep things tidy I would delete the OpenFOAM directory from root.
Cheers, Gijsbert
Old   November 9, 2009, 09:56
lynda
Hi Gijsbert
I do not have Qt installed, I tried on the two methods listed in your''....................'' yum install or download package qt-x11-opensource-src-4.3.5.tar.gz, but it did not work. I downloaded this package and I followed the instructions through step 3
make when I typed in my terminal I have the following result;
[root@localhost qt-x11-opensource-src-4.3.5]# make
make: *** Pas de cibles spécifiées et aucun makefile n'a été trouvé. Arrêt.
THANK YOU
Old   November 9, 2009, 11:14
Gijsbert Wierink
Hi Lyna,
So
yum groupinstall "X Software Development"
did not work?
Did you do
./configure
after you unpacked qt?
And then
gmake
followed by
gmake install
Cheers, Gijs
PS If you need to re-make qt again for some reason you can clean by
gmake confclean
Old   November 11, 2009, 09:59
lynda
Hi Gijsbert
I installed QT, I tried to run the sample "cavity" I wanted to show the mesh and found the results, I typed "paraFoam" ParaView window opens but I do not knew how to get certified in Figure 6.1 User Guide (p U-160)
thank you
Old   November 12, 2009, 05:00
Gijsbert Wierink
I am sorry, Lyna, but I do not understand what you mean. Did you solve the problem? If not, what is the issue?
Old   November 12, 2009, 07:59
lynda
Hi Gijibert
yes,I solved the « qt-x11-opensource-src-4.3.5 »problem.
I want to rebuild the paraview ( the next step of the 'qt-x11-opensource-src-4.3.5') unfortunately, I can't run the last step (builparaview) and even (makeparaview)
Old   November 12, 2009, 10:55
Gijsbert Wierink
Hi Lynda,
It seems that you are using OpenFOAM-1.6, am I right? If so, you need to do the following:
cd $WM_THIRD_PARTY_DIR
rm -rf paraview-3.6.1/platforms
makeParaView
as explained in section 7 of the README file. What is the terminal output if you try makeParaView?
It may be that you need to specify the location of Qt and Mesa in lines 37-60 of $HOME/OpenFOAM/ThirdParty-1.6/makeParaView. Mine looks like this:
# User options:
# MPI support:
withMPI=false
MPI_MAX_PROCS=32
# Python support:
# note: script will try to determine the appropriate python library.
#       If it fails, specify the path using the PYTHON_LIBRARY variable
withPYTHON=false
PYTHON_LIBRARY=""
# PYTHON_LIBRARY="/usr/lib64/libpython2.6.so.1.0"
# MESA graphics support:
withMESA=false
MESA_INCLUDE="/usr/include/GL"
MESA_LIBRARY="/usr/lib64/libOSMesa.so"
# extra QT gui support (useful for re-using the installation for engrid)
withQTSUPPORT=true
# Set the path to the Qt-4.3.? qmake if the system Qt is other than this version
QMAKE_PATH=""
If you need to know the qmake path, just type
which qmake
Cheers,
Gijs
Old   November 16, 2009, 05:49
lynda
Hi Gijibert
Yes, you're right. I use OpenFOAM-1.6.
I have problem with the command « makeParaView »; the output terminal don't find this command,
Please, I don't know in what file are the 37 and 60 lines and how to specify Qt and Misa.
Thank you
Old   November 17, 2009, 02:34
Gijsbert Wierink
Hi Lynda,
First find out where qmake is located by
which qmake
This will give you the QMAKE_PATH, in my case it is $HOME/tmp/qt-x11-opensource-src-4.3.5/bin/qmake. Then, open the file makeParaView with
gedit $HOME/OpenFOAM/ThirdParty-1.6/makeParaView &
and check that the openGL libraries (MESA), python, and qmake are the right paths (make changes if needed and save). Mine looks like this (line 37-60):
# User options:
# MPI support:
withMPI=false
MPI_MAX_PROCS=32
# Python support:
withPYTHON=false
PYTHON_LIBRARY=""
withMESA=false
withQTSUPPORT=true
QMAKE_PATH=""
Old   November 18, 2009, 03:37
lynda
Hi Gijibert
after the change the path in to lines (37-60), shows in the following lines :
code ;
# MPI support:
withMPI=false
MPI_MAX_PROCS=32
# Python support:
withPYTHON=false
PYTHON_LIBRARY="/usr/lib64/libpython2.5.so.1.0"
withMESA=false
MESA_LIBRARY="/usr/lib64/libOSMesa.so.6.5.2"
withQTSUPPORT=true
# Set the path to the Qt-4.3? qmake if the system Qt is other than this version
QMAKE_PATH="/tmp/qt-x11-opensource-src-4.3.5/bin/qmake"
Because, I find the qmake Mesa and libpython libraries paths, the output terminal is ;
[root@localhost ~]# find / -name 'libpython*' -print
/usr/lib/libpython2.5.so
/usr/lib/python2.5/config/libpython2.5.a
/usr/lib/python2.5/config/libpython2.5.so
/usr/lib/libpython2.5.so.1.0
/usr/lib64/python2.5/config/libpython2.5.a
/usr/lib64/python2.5/config/libpython2.5.so
/usr/lib64/gnome-vfs-2.0/modules/libpythonmethod.so
[root@localhost ~]# find / -name 'libOSMesa.so*' -print
/usr/lib/libOSMesa.so.6.5.2
I want to rebuild the paraview. unfortunately, I can't run "maKeParaview", the output terminal don't find this command,
thank you
Old   November 18, 2009, 09:06
Retired Super Moderator
Bruno Santos
Hello Lynda,
In Linux, to run scripts from a local folder, usually you have to use "./". For your case:
./makeParaView
I know, it's a bit weird, but that's how it works.
I hope it finally works. Best regards,
Bruno
Critical errors during OpenFoam installation in OpenSuse 11.0 amscosta OpenFOAM 5 May 1, 2009 14:06
OpenFOAM 1.5 installation on OpenSUSE 11.0 bigphil OpenFOAM Installation 16 April 29, 2009 06:28
Problem installing OpenFOAM 1.5 installation on RHEL 4. vwsj84 OpenFOAM Installation 4 April 23, 2009 04:48
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
