OF1.6+paraviw3.6.2 on ubuntu 8.1
Old   February 12, 2010, 05:55
Default OF1.6+paraviw3.6.2 on ubuntu 8.1
Cean
shirazbj is on a distinguished road
I tried to installed paraview3.6.2 on OF1.6. It worked a little, but still have problem.
OF1.6 has paraview3.6.1 included, but it doesn't work on my unbutu 8.1. Since I haven't worked out how to connect to internet with my dial-up under ubuntu, I have to download under window. I tried to install the qt4.3.5, but with no luck. So I decide to try paraview 3.6.2.
1. I downloaded paraview-3.6.2-linux32-x86.tar.gz and extracted it under the ThirdParty-1.6\paraview-3.6.2-linux32-x86 folder.
2. I edited the bashrc file under OpenFOAM-1.6\etc\apps\paraview3
* changed the ParaView-VERSION to 3.6.2
* changed ParaView_INST-DIR to the paraview-3.6.2-linux32-x86 folder
* changed the ParaView_DIR=ParaView_INST-DIR
3. After reboot (or maybe just execute the bashrc), I tried the cavity demo project. When run paraFoam, paraview started, but popup a "Open data with" window. I choose the "OpenFoam files", paraview aborted. It shows some error:
Read float past end of buffer
terminate called after throwing an instance of 'std::length_error'
what(): basic_string::_S_create.
It seems I need a FoamReader.
I haven't succeded in compliling PV3FoamReader.
I'll keep try.
Cean
shirazbj is offline   Reply With Quote
Old   February 12, 2010, 06:08
Retired Super Moderator
Bruno Santos
Greetings Cean,
Might I suggest trying the other foam reader, the "Parallelized Native OpenFOAM Reader for ParaView", available here.
Best regards,
Bruno Santos
Old   February 14, 2010, 04:54
Default use foamToVTK
Cean
Hi Bruno,
I tried that Reader, but have erroe during ccmake. It need the paraview.cmake file. The paraview3.6.2 file I downloaded does not include the sources.
Anyway, I tryied to use foamToVTK and finally I can see mesh and result in paraview.
For the cavity project, before running paraFoam, I run foamToVTK to convert foam data into VTK format.
So for a clean Ubuntu installation (8.1 or 9.04), install the OF1.6 and extract paraview 3.6.2 anywhere. Run foamToVTK before run paraview.
Thanks
Cean
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 14:43
[OpenFOAM] Paraview 3.4, ppa.launchpad.net and Ubuntu francois ParaView 1 May 29, 2009 09:07
debian package of openfoam-dev for ubuntu deepblue17 OpenFOAM Installation 0 May 22, 2009 04:49
Problem in running fluent 6.3 (64 bit) on ubuntu 8.1 (64 bit) Mir5 FLUENT 3 April 29, 2009 10:32
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
