[OpenFOAM.org] Mint 17 openfoam installation - can't even install libraries |
November 20, 2014, 06:46 |
Mike Hersee
Rep Power: 11 |
Hi folks,
I'm almost completely new to linux (even though I used to be General Manager of an ISP!!) and have just installed Mint 17 Cinammon 64 on an AMD quad-core Sempron with Kabini architecture (which is so new that Mint 16 / Ubuntu 13 wouldn't run on it). I have successfully downloaded and installed WPS office, and that works fine. I started following the instructions here: http://openfoamwiki.net/index.php/In...u#Ubuntu_14.04 (as Mint 17 is based on Ubuntu 14.04). When I got to this line:- "apt-get install build-essential cmake flex bison zlib1g-dev qt4-dev-tools libqt4-dev libqtwebkit-dev gnuplot \ libreadline-dev libncurses-dev libxt-dev libopenmpi-dev openmpi-bin libboost-system-dev libboost-thread-dev libgmp-dev \ libmpfr-dev" - the ending went like this:- Fetched 38.3 MB in 5min 3s (126 kB/s) E: Failed to fetch http://security.ubuntu.com/ubuntu/po...u2.1_amd64.deb 404 Not Found [IP: 91.189.91.14 80] E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing? So I tried it with '--fix missing' at the end, and at the end of the messages was: Err http://archive.ubuntu.com/ubuntu/ trusty-updates/main libcurl3 amd64 7.35.0-1ubuntu2.1 404 Not Found [IP: 91.189.91.23 80] Err http://security.ubuntu.com/ubuntu/ trusty-security/main libcurl3 amd64 7.35.0-1ubuntu2.1 404 Not Found [IP: 91.189.91.24 80] Unable to correct missing packages. E: Failed to fetch http://security.ubuntu.com/ubuntu/po...u2.1_amd64.deb 404 Not Found [IP: 91.189.91.24 80] E: Aborting install. So I'm wondering how to proceed. Any ideas? Any help or explanation as to what might not be working would be gratefully received. Thanks Mike Hersee |
November 21, 2014, 04:56 |
Mike Hersee
Rep Power: 11 |
Well, after a delay, I tried again and this time it went through fine. Seems like it was a temporary internet problem that stopped access to a specific IP. Now have a different problem....
linux mint 17 14.04 |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
[Other] Difficulties trying to install porousMultiphaseFoam on OpenFOAM for Windows 15.06 | JKoeleman | OpenFOAM Community Contributions | 0 | September 15, 2015 09:36 |
OpenFOAM 2.2.2 source pack installation on Xubuntu 13.10 | zordiack | OpenFOAM Installation | 1 | October 26, 2013 13:08 |
OpenFoam 2.0.0 installation | Jan_Peters | OpenFOAM Installation | 86 | April 27, 2012 05:32 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
