Source FE3 bashrc on Parallel Run
Like Tree2Likes
  • 2 Post By wyldckat
Prev Previous Post   Next Post Next
Old   June 17, 2014, 12:37
Default Source FE3 bashrc on Parallel Run
cdm
cdm is on a distinguished road
I've recently compiled foam-extend-3.0 from source and distributed to a cluster where we have different versions of OpenFOAM already installed from the Ubuntu repo. We've been able to run any version of OF with no issue by sourcing the appropriate version's bashrc on the host and the appropriate arguments are passed to load that version on the slave machines when mpirun is called.
However, this is not occuring in foam-extend. I have to manually source the /opt/foam-extend-3.0/etc/bashrc in the slave machines' $HOME/.bashrc on the first line; however, this prevents us from running other versions of OF since every mpirun call automatically sources foam-extend on the slaves (overwriting the mpirun-called version sourcing).
1. Is there a settings file I need to modify in foam-extend-3.0 to source the bashrc upon mpirun call? Or is there a way of passing the source command during the mpirun call?
2. On a semi related note, foamJob does not appear to work with foam-extend-3.0, with an error thrown:
/opt/foam-extend-3.0/bin/foamExec: 398: /opt/foam-extend-3.0/etc/bashrc: [[: not found
/opt/foam-extend-3.0/bin/foamExec: 21: export: -pthread: bad variable name
Thank you for any help.
cdm is offline   Reply With Quote
bashrc, foam-extend-3.0, mpirun, ubuntu 12.04
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 01:22
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
[mesh manipulation] Cannot get refineMesh to run in parallel smschnob OpenFOAM Meshing & Mesh Conversion 2 June 3, 2014 11:20
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 10:08
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
